Question about 1994 to 1998 Pontiac Grand Am Steel Thermostat Bypass Pipe for V6 3.1L
A/C clutch relay for 1998 grand am 3.1
A /c not cooling
  • 62 Answers
Do you have A/C gauges to check the Freon pressures on the high and low side? Check or have Freon pressures checked first. Has the system ever been worked on? Over time, if the system was never serviced, all the Freon will leak out.
Posted on Nov 02, 2014
What is the 4 small boxes that look like fuses that are behind the front bumber and what do they do?
Post a picture , an which engine does yours have ,3.1 L or the 2.4 L could have either one .Doesn't want to start how ? When you turn the key to the start position does the engine spin ,turn or nothing ? There are no relays involved in the starting circuit of your vehicle . Are the thing's your trying to describe a 1in. square box ? If so these are relays . When does it make noise ,when you turn the key on ? The fuel pump relay will energize for a couple of seconds when the key is first turned on .
(1)
A/C Compressor Clutch Relay
(2)
Fuel Pump Relay
(3)
Cooling Fan Relay
(4)
Blower Motor Relay
Feb 13, 2016 | 1998 Pontiac Grand Am
A/c clutch on '98 jeep grand cherokke won't
sounds as though there is a leak, check all connections on a/c lines, now you will need to see if the clutch is getting power, if it is then the clutch will need replaced, if not then check to make sure where the fuses and relay plug into are receiving power. Hope this helped Tim
Jun 07, 2011 | 1998 Jeep Grand Cherokee
Radiator fan will not turn off ever.
the usual culprit is a bad relay. Some cars have 2 or 3 cooling fsan relays, usually under the hood in a fuse/relay box. Look in owner manual for fuse/relay locations and pull the cooling fan relays one at a time & see if it cuts off. That could be the bad one. The engine computer usually controls the fan motor based on input from the coolabnt temp sensor or by when you have the heater controls set on a/c or defrost modes.
Mar 05, 2011 | 1998 Dodge Grand Caravan
Doe's it have fan for cooling , it's over heat, please help
Yes, they do have cooling fans. Some Grand Cherokees came with just an electric cooling fan, some had a hydraulic cooling fan driven off of the power steering, some had a mechanical clutch type fan, and some had a mechanical clutch type fan and electric fan. It really depends on what type off fan you have. It sounds like you have an electric fan that the fan relay has gone out. The fan relay is located under the right front portion of the bumper. Hope this helps.
Best of luck.
Jun 16, 2010 | 2001 Jeep Grand Cherokee
Fan still runs when key is out
It is a cooling fan,I assume?The problem is a coolant fan relay,if the relay is unplugged,the fan will stop,that is the relay to replace.
Jan 19, 2010 | 1998 Jeep Grand Cherokee
Where is my relay at to my fan ?
the relay should be in your main relay box under the hood or in you main fuse box
Aug 19, 2009 | 1997 Pontiac Grand Am
1998 grand marquis hot air. no cool air
try this - turn on the a/c. Disconnect the 2pin wiring connector from the a/c accumulator Small tank, looks like a thermos bottle.
Using a iwre or paper clip, jumper between the 2 pins in the connector. If the compressor clutch clicks and engages, it means you are low on freon.
Apr 04, 2009 | 1998 Mercury Grand Marquis
1994 to 1998 Pontiac Grand Am Steel Thermostat Bypass Pipe for V6 3.1L Logo
51 people viewed this question
Top AM Auto Parts Vehicle Parts & Accessories Experts
Todd Arndt
Todd Arndt
noagge
terry stevens
Are you an AM Auto Parts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
