Question about RCA RT2911 1000-Watt HDMI Home Theater System
Lost manual, I need to adjust individual speaker volume and bass, mid and treble response.
I'm not happy with the pre-set options like hall, jazz, etc. Can I adjust bass, mid and treble individually? Can I adjust bass down, and how?
4 Suggested Answers
SOURCE: No sound from mids and bass
there is prolly just a short in the wire somewhere
Posted on Jan 14, 2008
SOURCE: need owner's manual to set time
i can't set the time i need help
Posted on Oct 24, 2008
SD Tech
  • 14553 Answers
SOURCE: rca56wh78 has 3 individual pictures color is ok convergen is working set at 4.3 format unable to change. zoom is at 16.9, set to cmp1 what adjustments are needed?
If you are trying to change the 4x3 format sometimes the signal source determines that and not the set===the box will set the format for certain programs.
The other thing to be sure of is component one HD?
Not real clear what your issue is so let me know if possible.
Posted on Mar 14, 2012
How do I adjust the treble and bass on sony str-dh520?
See EQ Mode on page 59 of the owners manual to set the bass and treble for the front speakers, presumably for 2 channel mode. For multi-channel mode there are several pre-programmed audio modes listed starting on page 43 and music mode starting on page 44.
https://docs.sony.com/release/STRDH520.pdf
Mar 02, 2015 | Sony STR-DH520 A/V Receiver
I have a jvc kdhdr50......and I'm wondering how to adjust the bass and treble also how to turn the loudness on
This is discussed on page 26 of manual. Press and hold MENU and select USER for EQ. Under EQ you will have options to adjust SUB BASS, BASS, MID BASS, ULTRA HIGH, HIGH, MID HIGH, AND MID
Aug 10, 2014 | Car Audio & Video
Thanks for the answer - If we have 3 controls as Bass, Mid and Treble. If we keep those in 12 O Clock position, will the output level be equal. In using the Bass and Treble control only (if we have...
If all are in 12 o'clock position they are "flat" (nothing has been added or subtracted foam input signal) If you only have bass & treble, yes adjusting will affect "mids" but Mids change can go both ways dependent on increase or decrease of Bass and /or treble. By increasing bass you will pull some mids up also. By increasing treble you'll subtract some mids.
Mar 17, 2011 | Audio Players & Recorders
When the truck is turned on the speakers make a boom sound then they buzz??
is this afetermarket stereo if so check you ground on the amps
Feb 09, 2011 | Car Audio & Video
How to turn sound on phillips plasma 32 inch tv
Hello
I thinks that you want to tune your TVs sound parameters, and answers. As you know, when the TV is switched on it will display picture as well as sound, according to the volume level setting. If you want the qulality of sound much more better, by pressing Menu button and higlight the opton 'Sound'. As you select, there will be a 'tick' mark appears, indicating that sound option is selected. On to the right side, there will be Bass, Treble,and balance control displays. Use "Cursor Up" button to go box 'Bass", and increse or decrese Bass lavel as you likes. If you wants to adjust treble, use "Curser Right" button and do as previous to your taste. Come to the "Balance" option by using "Cursor Up or Dn' keys and set it to mid position. There will be indication for its mid position, and it should be in that position, so that you can hear sound from both speakers equally.
All jumpings and adjustments can be done with 'CursorUp, CurserDn, CursorLeft, CurserRight' Ok.
Oct 31, 2010 | Philips 32PT6441/37 32" TV
How to adjust bass and treble
this is kinda vague i hope this helps! first turn the equlizer to flat make sure eveything is equal. then turn he volume about 3/4 of the way up. this is around the point where th radiostartsto send distortion to the speakers (the easiest way to blow speakers) . thenstartwith the bass. eeryones ears are different i usually tue the bass to a notch or so below half ao if the radio ges to +12 i wouldput it on 4 or 5. next the mids are usully set at about +2 or 3. then thetrebbel is set a hairhigher than the bass. make this your maximum listenig volume so you dong damage the speakers. Hope this helped! let me know
Sep 15, 2010 | JVC Car Audio & Video
Can't adjust bass and treble
The only adjustments available on the unit are Volume and Bass (Subwoofer Level). There are no Mid-Bass or Treble adjustments.
Sep 20, 2009 | Jasco GE 98903 2.1 Speakers
BASS,TREBBLE,MIDS SETTING
Hello 1rocknroller,
Press the mode button repeatedly to select BASS, TREBLE, SUBW, BALANCE, FADER, DEFEAT, AND VOLUME. When subwoofer mode is set to off, it's level cannot be adjusted. If DEFEAT is set to ON, the player returns to factory defaults. Turn the volume control to adjust the setting. If no adjustment is made within 5 seconds after selecting, the player returns to normal mode.
Hope this helps.
May 29, 2009 | Alpine CDA-9856 CD Player
I need to find out what buttons control the bass and treble
Press in on the volume control repeatedly to step through the menu of audio functions. The
first option is Volume, followed by subwoofer (only if the subwoofer feature is currently
activated), Bass, Treble, Balance, Fader and back to Volume. When adjusting audio functions,
the unit will automatically exit audio control mode after five seconds of inactivity
If you need the user's guide, click her to download.
Feb 21, 2009 | Jensen MP7610 CD Player
RCA RT2911 1000-Watt HDMI Home Theater System Logo
37 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
