Question about Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I have no sound in tv speakers
It happen over night the s.s works fine please help. my power went out last night now the tv sound jumps off and on. the s>s still works fine thats the only way I get sound.
    Genius:
  • 1,139 Answers
Hello mel45y
This might be a settings issue so first I want you to check the audio settings and make sure that the TV is first set to use the TV speakers.
After that is done you may want to see if the speakers are not damaged (physical inspection).
Now here is the part you are not going to like. If the settings are ok and the speakers are physically ok, then this denotes a problem in the audio circuitry. What I can do is give you an idea of what might be wrong and then offer ways to troubleshoot this problem. If you have a background in electronics then this becomes just a task of telling you where to look for the problem. If you do not have a background in electronics, I would advise you taking the TV to a qualified TV Repair Technician for servicing.
Now with that being said you will have to determine where the audio signal is dropping at. Begining at the audio IC using an oscilloscope find the audio signal. Once the signal is found trace it to the path where the audio connects to the TV speakers, along this path you will see where the audio drops. if not right at the audio output stage of the audio IC.
This is how to find the problem, and unless you have specific equip you will not be able to take out and replace the old component.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Jun 14, 2009
Muffled Sound From Speakers.
Please illuminate me explaining the word "Muffled" means and i will be glad to help you out...
Feb 10, 2013 | JBL *new* Jbl Jrx115 15" 2-way Speaker...
My 46" SONY LED has no sound coming out now.
Hi this sounds very much like a dry or bad solder joint probably on the power supply PCB, if you have the necessary soldering skills and a magnifying glass you maybe able to fix this yourself.
The picture below shows an example of what a dry joint(s) looks like, if you are able to solder and understand the risks in taking apart your TV you could save yourself a good few bucks!
Always make sure the TV is unplugged and please be aware that voltages can still be stored even when the tv is turned off, if in any doubt or you are unsure about attempting a repair please consult a qualified TV technician.
Hope this helps
Midge.
Feb 10, 2011 | Sony BRAVIA XBR46HX909 46 in. 3D HDTV
Our power went out last night and now our speakers won't work. we get power to them but no sound coming out.
Chances are that either the soundcard or speakers on your pc have been damaged by the sudden power/surge outage.
Suggest you try youy speakers on another pc or connect to your TV to test them. If they work fine, try putting some earphones/headphones into your pc (same connector as the speakers) to see if they work there.
Either way, from the above you will be able to tell what's broken. If the soundarc on your pc is damaged, you will prob need to take to someone to see if they can fix or replace the part. They may need to replace the whole motherboard.
Hope that helps, pls rate the solution
Nov 23, 2010 | Logitech Z Cinema 2.1 2.1 Speakers
No sound on my Sanyo LCD 32" flat screen tv
I had this same problem this morning. Luckily, when I reset the whole thing and did the channel search again the sound returned. I have no idea why it fixed it but it did. Hope this helps you.
Feb 12, 2009 | Sanyo DP32746 32 in. LCD Television
Television won't come on
Could be as simple as a blown fuse, but if you know so little about TV's, go see a serviceman!
Mar 27, 2008 | Durabrand DWT1905 TV
Polaroid FLM-323B LCD TV with no sound
Same issue....went to bed last night Polaroid tv worked fine....woke up NO VOLUME>>>
Jan 13, 2008 | Polaroid FLM-3232 Television
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
Tv will not turn on
your tv needs to be repair again power supply problem or circuit.good luck.
Apr 04, 2007 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
94 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
