Question about Golds Gym Cycle Trainer 390 R Recumbent Exercise Bike
I moved,so I took the bike apart.can't find a plug or wire to plug it in
Where are the wires to plug it in
You have to buy an adapter the plugin is behind the right side battery panel if you're sitting on the bike
Posted on Nov 03, 2014
LG front loader washer model #wcvh6260fgg, we replaced the door boot seal, put it all together and now it won't run! It does light up and the laundry big dial select button works, my cycle and/favorites...
I had the same problem with my whirlpool and when I took it apart a wire had come out of the connector took it apart and put wire back in. problem solved. look for any loose wires also if u unplugged any connectors make sure u plug them back in where they were
Apr 04, 2014 | Washing Machines
I own a 1997 fatboy 1340 evo with 26,000 miles on it,, i have straight pipes no baffles and a nice custom air cleaner and a screaming eagle power comander under the seat,bikes been running fine for a year...
that maybe part of it but the carb needs ajustin and cleanin--backfire is from a rich condition-so the float level can be wrong or the jets have issue--also make sure ur gitten proper spark voltage cause if low then not all gas is burned
Jul 21, 2011 | Harley Davidson FLSTF Fat boy Motorcycles
Took bike to mechanic for tire an after he test drove it an ever since bike wont charge the baterry an in back of bike where tail light is there is two black wiring plugs that look like they should go...
dont know what bike you have, but there is no wires at tail light that will affect charging.
Most bikes have a stator that produces AC voltage powered by magnet in the flywheel, this then goes into a rectifier\regulator, which converts to DC and regulates voltage and then to the battery
The regulator will have 1 or 2 plugs and 5 wires 1 red 1black and 3 yellow or white
The plugs you describe sound like indicator or earth wires , a power wire wont have a male bullet
Jul 06, 2011 | kawasaki ZX 10 Motorcycles
How to change the spark plug
i'm not sure what kind of bike your working on but here we go, older sports bikes and in line motors:the best thing to do here is remove the body (if it has one) sometimes you can get the socket in without removing the gas tank. best if you do tho it WILL make it easier.New sport bikes: start with the seat remove it then the tank now the airbox, after you have all this apart you should be able to get into the spark plug caps. Be careful here because most of the new bikes use a cap the also acts like the coil, it will have a plug with two wires remove that from the cap and remove the cap from the motor. take your time do one at a time and put it back together they the you took it apart. v twin bikes like harlys and bikes that look like then will have the spark plugs on the side of the motor sometimes under covers that may pull off or have screws. World of powersports is a site that shows micro phish. this is a part break down that you can use to find part numbers and where things are at in the bike.
Good luck my friend
M.Woodring
Apr 19, 2011 | Factory bike Chrono SM 250 Motorcycles
My cousin X BOYFRIND took it apart to clean it so dum dum took the wiring apart to also there a safty swicth under the seat my bike ran before he did that and now it dont
First check +12v to seat switch going in and activate swith to get +12 out. Start there. Maybe more wires were pulled. Might have to get a mc manual and follow wiring in circuit - Sorry, don' kill him, it happens.
Oct 15, 2009 | 2006 Vento V Thunder XL
Our polaris sportsman 500 6x6 won't start
Polaris seems to have a problem with this issue. I had the same problem with my bike and was able to fix it . I found a bad resetable fuse link located under the front cover. It looks like a plastic case with wires at both ends. cut the case and check the condition of that part. I found it was badly rusted . I removed the part and wired in a 10 amp fuse with a holder. wrapped it up to protect it and the problem was gone. lights worked fine as well as the cluster. Ed.
Oct 11, 2009 | Polaris ATV
79 gs550 - uh ohs in wiring...
When you reassembled the bike did you pinch any of the wiring harnesses? Trace the wiring through the bike and make sure everything has a solid connection between their respective power sources and activation switches. Alot of time bikes run wiring under the gas tanks so you need to make sure that you didnt cut anything when pputting it back on (if you removed the tank)
Jun 15, 2009 | 1979 Suzuki Gs 550 L
Precor C846 Recumbent Bike - heart monitor not working
You can test the HR grips to see if the wiring is good all the way from the contact grips to the upper board by doing a test with your meter. Get a meter that can test fuses and beeps if the fuse is good.
disconnect the 4 pin brown connector at the console board, on one side will be some metal contacts.
Touch one end of the meter lead to one wire and the other to the HR contact plate on the handlebar. try all the contact plates on the handle bar until it beeps, then move the lead to the next wire and repeat until all contact plates beep. It all of them beep then your wiring is ok and the problem is in the Heart Rate board in the console or the connection point on the board.
Let me know how it turns out.
Santafe
Apr 06, 2009 | Precor Exercise & Fitness
There is power to switch
I have a youth atv eng.152fmh right below that # is*51019044* dis.107ml om front is lhjschl1458009086 i need to wire it back up has been took apart where can i fiend a ezy wiring die.
Mar 22, 2009 | Quad 47 cc / 49 cc Pocket Mini Bike...
Golds Gym Cycle Trainer 390 R Recumbent Exercise Bike Logo
167 people viewed this question
Top Golds Gym Exercise & Fitness Experts
nursedeb1989
Level 1 Expert
Steven's...
Steven's...
Are you a Golds Gym Exercise and Fitnes Expert? Answer questions, earn points and help others
