Question about Scotsman Ice Maker CM3 30inW Cubed Ice Machine 900LB
First step to get running - Scotsman Ice Maker CM3 30inW Cubed Ice Machine 900LB
How to Optimize my PC Performance?
best way to keep a machine running at its fastest possible rate is not add a ton of programs and such onto it !! if you have the means its better to have one machine as a word processor and one as a game console , there never run better !!!
Oct 20, 2016 | Computers & Internet
Tip
How to create a daily enhanced Disk Cleanup task in Windows 7
So you want your Windows 7 Operating System to perform a daily enhanced Disk Cleanup? Well, so do I. So lets get this party started.
Step 1. Click on Start and then click Control Panel.
Step 2. In Control Panel change the View to Small Icons.
Step 3. Now click on Administrative Tools.
Step 4. Now double-click on Task Scheduler.
Step 5. On the right hand side of the Task Scheduler window, click on Create Task.
Step 6. In the Name field, you can type "I love crickets", but to make our task easier to find and manage, I would suggest you label it for what it is, ie., Daily Enhanced Disk Cleanup.
Step 7. In the Security Options area, you are asked to use the default account, which is the account you are currently logged in with. If your account is not an Administrator account you will not be able to create this task. Also, if your account does not have a password, you will not be able to run this account.
Step 8. We want to run this task while we are not actively using this machine, so let's select the "Run whether user is logged on or not" radio button.
Step 9. Leave the "Do not store password" checkbox unchecked.
Step 10. Select the "Run with highest priveledges" checkbox.
Step 11. Leave the Hidden box unchecked as well. We wouldn't want to make it harder for us to find the task if we have to edit it.
Step 12. Click on the Triggers tab.
Step 13. Click the New button.
Step 14. For Begin the task. select "On a Schedule".
Step 15. Select Daily to Recur every 1 days.
Step 16. Change the Start time to 2:00 AM
Step 17. Now check the Enabled checkbox then hit OK.
Step 18. Click on the Actions Tab.
Step 19. Click the New button.
Step 20. In the action dropdown menu, select "Start a program".
Step 21. In Program/script, type C:\Windows\System32\cleanmgr.exe
Step 22. For Add Arguments, type in /sagerun:1
(Please note: To utilize the /sagerun:1 argument, you must follow the steps outlined in my previous article located here.)
Step 23. Hit OK.
Step 24. Click on the Conditions tab.
Step 25. Select the "Wake this computer to run this task" checkbox.
Step 26. Hit OK to close the Create Task UI. You will be prompted for your password or the password you used to create the task.
Step 27. Now test your task.
Step 28. In the task Scheduler UI, click in Task Scheduler Library in the top left hand corner.
Step 29. Right-click on the task you just created and hit run. Your task should run silently in the background. After a few moments, you can click on the History tab and check the status of the task as it stands right now. You will either see running or completed successfully.
Though this task was built using Windows 7, the same steps apply to Windows Vista.
on May 01, 2010 | Computers & Internet
Tip
HOW TO START PROGRAMS IN WINDOWS STARTUP (XP)
Step 1 : Start --> Run --> type regedit and enter.
Step 2 : inside regedit go to HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run
Step 3 : On the right side window, right click and select NEW --> String value.
Step 4 : Now you can see a new file, Give appropriate name Here I'm using Internet Explorer.
Step 5 : Double click the created file and enter the path of the Program you wish to startup. Here i'm using internetexplorer path.
Step 6 : Close the registry editor and restart the machine.
Now you can see the Program was running after login.
Thanks
Current_Support
on Feb 18, 2010 | Computers & Internet
Increase internet speed
Hi,do the following step by step instructions to increase your Internet Speed:
Step 1 : First of all Click on start button.
Step 2 : Select the run button from the start menu or type Run and click on it.
Step 3 : Type gpedit.msc
Step 4 : Expand the Administrative Templates branch
Step 5 : Now expand the Network branch
Step 6 : Click on the Qos packet scheduler
Step 7 : Double click Limit reservable bandwidth
Step 8 : Check the enabled
Step 9 : Change bandwidth Limit to 0 %
Step 10: Click the Apply button and OK.
Step 11: Now restart your PC.
Step 12. check if its now better.
Before and after doing these steps check your internet uploading and downloading speed results in both MBps and Mbps units from Scanmyspeed.com .
Dec 23, 2013 | TP-LINK Computers & Internet
Tip
How to get your Dell 964 AIO printer to work correctly in Windows 7
Read through all the steps and get a good understanding of process before starting.
Step 1:
Perform manual Un-installation of OLD printer drivers Click Start > Devices And Printers, right-click on the Dell AIO 964 printer icon, and click on Remove This Device.
Step 2: Unplug the USB cable from the computer.
Step 3: Download the ZIP file R166225.ZIP from the Dell website here:
http://support.us.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R166225&formatcnt=2&libid=0&typeid=-1&dateid=-1&formatid=-1&fileid=224455
Step 4:
Extract all the files from R166225.ZIP intoa separate folder by themselves. Remember the location of the folder for later use. It would be best to create a new folder and extract the files to that folder to make it easier.
Step 5: Navigate to the directory you extracted the files to, locate SETUP.EXE, and run it. This will run the Dell Clean-Up Utility, which removes old printer drivers/files from your system.You may need to navigate to a sub-folder named "CleanUp_Utility" under the folder that you just created in order to run SETUP.EXE.
Step 6: Reboot the computer when prompted.
Step 7: Download the self-extracting file R146813.EXE here:
http://support.us.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R146813&formatcnt=1&libid=0&fileid=195111
Step 8:
Navigate to the file R146813.EXE, right-click the file name, click Properties, click the Compatibility Tab, and check off the following check boxes: Runthis program in compatibility mode for: (then select Windows VistaService Pack 2), and Run this program as an administrator.
Step 9:
Right-click SETUP.EXE, click Run as Administrator, and run SETUP.EXE.You might be able to get away with just running the executable withoutthis step, but I included it for redundancy and for safety's sake.
Step 10: Re-connect the USB cable to your computer when prompted by the Setup Utility. A small warning: when I did this step, Windows detected my printer and installed its own native drivers forthe printer, and a dialog box popped up attempting to print analignment page. I ignored this dialog box entirely. If this happens,you will be prompted by the Setup Utility to update the driver, which is what you want to do. Continue to run the Setup Utility as normal.
Step 11: Reboot the computer again.
Step 12:
After starting up Windows 7 and logging in, Click Start > Devices and Printers, double-click the printer icon. Click Customize your Printer, then the Ports Tab. Check off "Enable bidirectional support."
Step 13:
Verify that the printer is communicating with the operating system by printing a test page. You can go back to Customize your Printer and click Print Test Page.
Step 14:
If it still doesn't work try and reboot and try printing test page again.
Thank you and enjoy the tip.
-LeeTheDeuce
on Jan 30, 2010 | Office Equipment & Supplies
I cant install my Mcafee Antivirus
Kindly follow the below steps & update us on the status: Step 1: Clear all the Windows Temp Files: - (Navigation: Click Start > Run >Type Temp) and clear all temp files.Step 2: Clear all the Local Temp Files: - (Navigation: Click Start > Run >Type %Temp%) and clear all temp files of the local user.Step 3: Download and run the McAfee Pre-Install Tool using the below link: Step 4: Restart the computer and then try the Installation.
Thanks Ben
Nov 26, 2012 | Computers & Internet
When iTunes 10.5.2 is started, PC running Vista 32 Bit, monitor screen resolution changes
Sounds like a compatibility issue. You want to ensure that iTunes is not set to run in compatibility mode. To check this please follow the steps listed below: Step 1. Exit out of iTunes.
Step 2. On the Windows Start Menu select Computer.
Step 3. Browse to the following location: C:\Program Files\iTunes.
Note: Windows 7 (64 bit) users browse to C:\Program Files (x86)\iTunes.
Step 4. Right-click on the iTunes application (iTunes or iTunes.exe) and select Properties.
Step 5. Next select the Compatibility tab.
Step 6. Ensure that the options Run this program in compatibility mode and Run this program as an administrator are not checked. If they are checked please deselect these options, then select Apply, and OK. You should now be able to open iTunes with out receiving the error message about iTunes running in compatibility mode.
Dec 30, 2011 | Computers & Internet
Install wndows xp but i can not get sound for this model how i can get .
run motherboard software step by step... check audio and run continue downloading...
second option.. go to control panel/system security/device manager device mager/ scan device if you see a driver yellow icon like this(?) click it audio and update driver online. step by step. automatic run online...
thank you...
Feb 01, 2011 | Computers & Internet
VIRUS
Follow thegiven steps to remove virus:
As soon as you suspect that your computer has a virus, remove your computer from any networks it might be on, as well as from the Internet, so that you don't inadvertently spread the bug to others. Unplug your network cable if you have to.
If you have virus-scanning (anti-virus) software installed, run it.
If you don't have anti-virus software, you'll need to obtain some. If you can't get it from a network administrator or download it from an uninfected computer, you can mail-order it from a retailer. Start your computer (still not connected to a network) and follow the instructions that came with the anti-virus software.
Keep running the virus-scanning software until your computer comes up clean.
Reconnect your computer to the Internet and check with the anti-virus software's publisher to make sure you have the latest updates. If not, download them now.
After updating the anti-virus software, run it again until your computer comes up clean.
Jan 10, 2011 | Computers & Internet
Kitchen Appliances - Others Logo
32 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
