Question about HP Pavilion dv6000z Notebook
Hp pavilion dv6633 won't start. Light up, then
Hp pavilion dv6633 won't start. Light up, then turns off. HELP!
  • janielwilson Jun 16, 2009
    Thank you all for your help. I am on vacation and was going to catch up on some work, but, now I can't. I'm terrified to tear anything apart. I will just have to take it in when I get thome.
    It had been "freezing" and I would manually shut it off. Most of the time I would put it on "sleep" mode if I was going to be away from it for a few minuters. I did this on Saturday night and it "froze". So, I powered it off, and it won't power back on. I've taken the battery out, but nothing else.
    I'd pay someone to fix it remotely, but they can't very well do that if it won't power on!
    Thanks again for all your help. But I guess this just isn't going to be a "quick fix", unfortunately. Too bad computers don't last more than 18 months! You can bet my next one won't be an HP!
    Thanks again, to all of you who responded.
  • 788 Answers
Sorry to here about your DV6633 start up problems.
1st. It would be good to know any other problems you may have had in the past either related or non related to you current problems..
I take it you are running with a charged battery? and the unit has not been dropped lately.?
2nd. If you are receiving a charge light on the front left of cover, your battery is charging and your power supply is in working condition.
3rd. I would remove any media from the CD/DVD and disconnect battery and with incoming power from supply.
4th. Flip unit over and remove the large Black cover, where you will find the Memory and CMOS Battery.
5ft. Carefully remove memory setting them side from contact with other components.
6st. Disconnect CMOS Battery found at the top right of memory. This is the battery backup for memory, system time and date and other features. This with have a white connector which connects to the board.
7th. Flip unit over and open case cover, hold down the power button for at least 30 seconds.
release the power button and close case. Flip back over to bottom again.
8th. Reinstall the CMOS Battery Connector, memory, cover.
9th. and last of all the Smaller Black Cover just to the left is where your Hard Drive is located.
remove the two screws and cover, on the Top of the Hard Drive you should see a Plastic Pull Tab to remove the Hard Drive.
Remove the drive carefully it is frag-il. Re-seat the drive and re-install cover.
Turn the unit over, re-install the battery, plug it in an turn it on.
Pressing the F-10 key will enter the BIOS setting, here you can change the time and date.
Note if you have not been prompted to change Time and Date, you did not remove CMOS battery.
If the unit will run in the BIOS setup, your problem is more than likely software related.
You should have a Utility for checking Hard Drive which in most cases takes about 1-hour, unless you have a failed hard drive, this will show in most cases within the first five minutes because the boot sector is the first and last to be checked by the utility.
If all checks OK you may want to reload your firm and software to factory specs.
This can be done buy hitting the F-7 Key at the start up. ( That is, if you haven't deleted the recovery partition.)
Good luck, keep the unit off the carpet and Bed as it will not vent or cool properly.
John Ray
johnrraycomputer.com
Posted on Jun 15, 2009
  • John Ray Jun 16, 2009
    Sorry to here you are still having problems with your HP.. If you are planning to bring unit in for repair, I would look for a tech or company, that offers a repair charge - only if the unit is repaired. Or NO FIX, NO CHARGE.
    Before you go thru all that, bring your charger to radio shack and ask them to check it for you.
    If you have gone thru all that I have listed before in text, you may have other problems, you may not have listed.
    If your battery is taking a charge or the charge light go out after a hour or so of flat charging,(unit not running, just charging battery) you may have a Hard Drive problem or worst.
    I am interested to know if the unit boots into the BIOS and runs for any length of time.??
    Pressing the F-10 key at startup will bring you into the BIOS.
    Let me know as maybe you have not completed all above or have.??
    Good luck
    john@johnrraycomputer.com
  • 33 Answers
It may be your power supply see if that is putting out the right volts first I think
HP Pavilion a 1250n won't turn on. Green light is on under the plug in the back but noghting else.
If the monitor power light is on or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
Sep 22, 2012 | HP Pavilion a1250n (EG194AA) PC Desktop
Please try the following:
1.remove the power cable an plug it again
2.check is the power it's on at the back of the source.
3.if you hear some noises write them down and search for the error codes on the net.
HP Pavilion dv6448se Notebook PC Won't Boot.
it restarts on booting screen or else at start up screen itself?
Jun 08, 2012 | HP Computers & Internet
My Hp Pavilion dv9831cl laptop quit working and won't power on, even with a full charge or plugged in. I press the start button, it lights for about a second then shuts off. Any suggestions? If I
Laptops use shared RAM, part of the main RAM is allocated as video RAM.
If the RAM is faulty then this could be the problem, get the RAM tested at your friendly computer repair shop.
Apr 06, 2012 | HP Pavilion dv9823cl Notebook
Hp m7590 fans won't start. Green light is on power supply
Try connecting the fan to another fan plug in on the mother board usually there are two or three of them . Then go into the BIOS [press delete while booting] and make sure it is turned on
Sep 06, 2011 | HP Pavilion m7590n PC Desktop
Hp pavilion a1217n tower won't power up...the green light in the back is blinking rapidly....help!
it could be 3 things eigther the hard drive failed or power supply went out or mother board went bad you can take it to a reputable computer repair store and they will check these for free
Jul 08, 2011 | HP Pavilion a1217n Desktop PC
Suddenly my hp pavilion a1217n tower won't turn on...the green light is blinking rapidly...
are you referring to the light on the back? if so the power supply has most likely failed, mother board can also cause this issue.
Hp pavilion a820n comp won,t turn on . rear power light blinking , turned all power off several times waited long intervals before repowering unplug all plugs and tried still no power up found when mother...
make sure nothing is plugged in to your front card readers slots:
If so PC will not boot. Other then that can you put a different power supply in it? Just to see if it is the Power supply..
Jul 26, 2010 | HP Pavilion A820n (PP165AA) PC Desktop
Hp pavilion dv6633 won't start. Lights up, then turns off. HELP!
Hmm.  The most common cause would be a battery that's not recharged.  This could happen if the power supply you plug into the wall has blown an internal fuse.  When plugged in, before turning the laptop on, there should be an indicator light showing that there's power coming to the unit (and another indicating the battery is charging, if it's not already fully charged).  You might try borrowing somebody's compatible power supply to check this (most laptops charge with about 18 volts, DC).  Replacement compatible power supplies can usually be had pretty cheap by checking on Froogle or the like.
Other possibilities are pretty ugly.  Like a BIOS setting got changed to something incompatible with your hardware (pressing F1 or maybe Esc or Del when turning on the unit would get you to the BIOS settings).  Or a memory chip got fried.  Or the CPU chip is overheating because its gotten a little loose from its heatsink.  Or the hard drive has developed a bad sector or corrupted data where the boot sector is located.  Describing exactly what appears on the screen (and any peculiar beeps) during the few seconds its on could help sort out these possibilities, but you'd likely need an in-person geek to fix any of these possibilities.
Best wishes,
SteveMDFP
Jun 14, 2009 | HP Pavilion dv6000z Notebook
HP Pavilion dv6000z Notebook Logo
258 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
