Question about Maytag MSD2656G Side by Side Refrigerator
Water is leaking from the freezer to thge floor. I is a side by side Maytag refrigerator
I had a simular problem - it is EASY to fix once you know what it is. "They" don't tell you that you should clean out the drain once a year..."they" would rather you call a repair man. Empty out the freezer side and remove the bottom panel inside the freezer. If you don't know how to do this google your fridge type and model number and you should be able to find directions to do so. In the very bottom is a drain that can get clogged with ice. Using a hair dryer and hot/warm water melt and gently break away all the ice. Poor hot/warm water over it till completely thawed out. What is supposed to happen with this drain is moisture is supposed to go to a pan under the fridge and evaporate. When it is clogged the water spills out onto the floor. If I can do this anyone can. I was about 50 years old and a woman when I first did this.
Posted on Jun 14, 2009
Msd2757ae freezer leaks water
Leaking Refrigerators Just What may Be Happening
I am pretty sure you are having a defrost drain blockage problem, and click here=>
Leaking Refrigerators! Let me know if helpful, Sea Breeze
Feb 23, 2012 | Maytag MSD2756G Side by Side Refrigerator
My Maytag MZD2766GES is leaking water to the bottom of my freezer, which, when it get alot starts leaking all over the floor. where is this coming from?
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps you to stop the leak,
Gene
Aug 18, 2011 | Maytag Refrigerators
I have a Maytag MSD2556AE Side by Side Refrigerator/Freezer. I keep getting a puddle of ice in my freezer and water leaks out of the freezer onto the floor. All this happens in spite of the water line to...
Sounds like you have a frozen drain line. I would unplug the unit at let the drain line thaw. This would be the easiest way to rectify the issue. Leave both doors open for 24 hrs. Hope this helps _MJ_
Jul 28, 2010 | Maytag MSD2756G Side by Side Refrigerator
Water leaks out of freezer bottom same time every day model rsd22
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jul 13, 2010 | Maytag MSD2756G Side by Side Refrigerator
Maytag side be side model msd2454gr
heatman101
Jul 10, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
My Maytag side-by-side refrigerator/freezer Leak
There is a pan and drain hose under the freezer coil that is there to catch any water when the freezer goes into defrost. I feel strongly that is where you will find your leak.
I hope this helps.
Apr 19, 2010 | Maytag MSD2756G Side by Side Refrigerator
Freezer malfunction
Drain hole is clogged behind the panel that covers the coils. I found a peice of solder blocking mine. Water was freezing on the bottom of the freezer and leaking out to the floor.
Aug 04, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag MSD2656G Side by Side Refrigerator Logo
185 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
