Question about Brother P-touch PT-90 Personal Label Maker
Won't turn on after changing to new batteries
LED read low battery. I changed to 4 brand new ones and now it won't turn on.
  • Pam Baker
    Pam Baker Mar 20, 2014
    That was the first thing I tried after I put in the new batteries. They arein correctly,
  • Brother Master
  • 10,291 Answers
Did you put the batteries in correctly? It could be that simple.
Posted on Mar 20, 2014
  • Lawrence Oravetz Mar 23, 2014
    Ok, Is there any white stuff growing on the springs that the batteries connect to? You can clean them with some vinegar on a Q tip. Do you have a wall adapter for the printer? Does it come on when connected ? Have you tested the new batteries for the correct voltage?
Olympus Camedia E10 won't power on with AA NI-MH batteries but works fine with AA ALKALINE, what can I do?
Always charge batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Always charge sets of batteries (2 or 4) together.
Make sure your rechargeable batteries are all good. One defect in a set is killing for the whole set
Don't use barrettes from different sets or brands together.
I had one brand good NiMH batteries and a very expensive charger from the same brand. The charger destroyed all my rechargeable (more than 60 now). When I first discovered the batteries were dropping out, I stopped using the charger, but it did not prevent all batteries to die in the following months. Every time on dropped out I had to change the set. I tried using up the others by grouping the ones with the same Ri, but not longer then a few months and I had a box full to trow away.
Never use a quick charger, capable of charging them within an hour or faster. Us a charger that indicates the Ri is still low enough, so you can see what batteries are bad.
Check you are using a charger for NiMH batteries.
I would try another set (new) because buying Alkaline is also not cheap.
I used 2700 mAh and later 2600 mAh rechargeable, all dead now. since a few weeks I'm now using 2300 mHh from another brand, costing 1/5 of the "best" I had before, and they are doing great. I won't charge them with the quick charger.
Never use manganese (Zinc-Carbon) batteries in electronic devices.
These batteries are only to be used in flash lights.
Apr 20, 2015 | Olympus Camedia Cameras
Harbor breeze remote not working
That's a low-end store brand for Lowes. You probably need a new transmitter if you can find one.
Sep 01, 2014 | Dryers
TV remote won't work after changing batteries
When battery is changed, all the previous settings will be lost from the remote control. You should once again set it to your device, using codes.
Jan 10, 2013 | DISH Network Televison & Video
Inspiron 6000 flashing orange light for three batteries. I took apart two, made one using three groups of three cells that were fully charged and rebuilt another with brand new cells, and both get the...
The flashing orange LED is a Battery Critically Low indication.
If the Windows Battery Meter and the BIOS do not show the batteries charging then there may circuit problem in your battery.
If you can, try battery in another system, if you can't, I'd try a new battery before doing any hardware changes to the system
Dec 24, 2009 | Dell Inspiron 6000 Notebook
My canon a75 continually says low battery after changing them
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Jul 16, 2009 | Canon PowerShot A75 Digital Camera
Battery light 4 times is red and one time green in all the time
the battery LED is indicating an internal battery failure. While the battery may still work, the LED indication will not change until you replace the failing battery. It can be an indication of a Failed Cell, low voltage etc. Something in the battery is no longer meeting specification and that triggers the LED indication.
ONLY RESOLVE, NEW BATTERY
Apr 11, 2009 | Dell Latitude D610 Notebook
Beeping camera
Mine did the same thing for forever and was brand spankin new... When the batteries go dead once, I guess it glitches... You can put brand new ones in and it will Still say low battery or act like it anyway. Give it some time. Then try to turn it on again and it will be fine. Also it will say you have a low battery if you are taking too many pics at a time... like snap snap snap and it will shut down... turn it back on in twenty minutes and its fine... full battery. If you can't deal with this... Get a battery charger and rechargable batteries. I am using them now with none of these problems
Jul 07, 2008 | Samsung Digimax S730 Digital Camera
Brother P-touch PT-90 Personal Label Maker Logo
890 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
