Question about VTECH-ATT At&t Cl83201 Cordless Phone - Dect - Silver Black
Handset speaker not working on ATT CL83201
Does not work
So Frustrated, how do I unmute the ringer on an AT&T HDAudio phone model cl83201
Try Googling (AT&T)(cl83201)(manual) without parens for instructions.
Sep 13, 2017 | AT&T Lands Phones
Microphone on handset does work on outgoing calls
Check to see if you have pushed the "MUTE" button... it turns
off the microphone, another press of "mute" turns the mic back
on, etc.
Oct 17, 2013 | AT&T ATT EL52500 DECT 6.0 5-Handset...
Speaker works but handset does not. replaced
Make sure to use a new handset cord as well. Also, make sure the handset is plugged into the handset jack under the phone. The 3102 phone has a headset jack that will not work with the handset. There is also a button mapped by default in the upper right corner that toggles from handset to headset. If the light is on, then it is set for headset and the handset won't work.
Dec 18, 2009 | 3Com NBX 3102 IP Phone
Handset can not connect to base unit ATT E-2126
AT&T 2.4 cordlessE2126 handset will not reset to base
Apr 01, 2009 | AT&T E2126 2.4 GHz Cordless Phone
D51A PD IS DISPLAYED ON MY ATT E2562 HANDSET. ANY
My E2562 handset 1 would not detect base and displayed D51A PD whenever I tried to manually register it. This fixed it:
1. Remove battery from handset.
2. Unplug base and unplug phone connection(s). Wait 30 seconds.
3. Plug in base.
4. Plug in phone connection(s) to base.
5. Put battery back in handset. Handset 1 should then auto register with base.
Mar 15, 2009 | AT&T 2230 Cordless Phone
My att 5.8digitalbase phone only speaker phone works, How to fix?
If you want the manual, just go to http://telephones.att.com/telephones_ui/support/dsp_manuals_list.cfm then scroll down to your model 5840 Manual. It will download the manual for you.
Feb 10, 2009 | AT&T 5840 5.8GHz...
Panasonic KX-TG9341 (purchased 9/10/08)
I believe the problem is not the handset phone but the telephone line because the phones were working for a brief period again last night. As I said, ATT is supposed to send a repair man out today to check the lines. If the repair man says the problem is not the telephone line, I may contact you again. Thanks/
Nov 03, 2008 | Panasonic KX-TG1033S Cordless Phone
Phone handset not working unless on speaker phone
is this phone been dropped or wet? bring to a local service center to check if you have a physical damage on the phone.
Aug 17, 2007 | Motorola Mobility RAZR V3c Cellular Phone
VTECH-ATT At&t Cl83201 Cordless Phone - Dect - Silver Black Logo
26 people viewed this question
Top VTECH-ATT Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a VTECH-ATT Lands Phone Expert? Answer questions, earn points and help others
