Question about Lexmark Wheelwriter 1000 Typewriter
Stuck right shift key, and 4 lights continue to blink until I touch arrow up or down key.
Stuck right shift key, and 4 lights on right continue to blink until I touch up or down key
How to activate touchpad on acer e1-571
Hi
One of the toggle switches using the FN key turns the touchpad on and off.
<Fn> + <F7> Touchpad toggle. Turns the built-in touchpad on
and off.
If you go here :-
Drivers and Manuals
and selecting your model from the selections offered ie "Notebook" then "Aspire" then "Aspire E1-571" you can find all the documentation, drivers, applications, BIOS etc for your machine.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 16, 2014 | Acer Aspire Computers & Internet
Sc21-06
SC21-06 at power up.
Solution:
CAUSE: The transfer cleaning motor (M10) failed.
SOLUTION: To disable M10, perform the following:
1. Power the copier OFF.
2. Access the 25 mode (power the copier ON, while pressing the 2 and 5 keys).
3. Touch [1: Software SW setting] on the touchscreen.
4. Touch the left up-arrow three (2) times.
5. Verify that 3-0 is displayed. Use the right up/down arrows until 3-4 is displayed.
6. Touch the right up/down arrow one (1) time (3-4 will be displayed).
7. Touch [ON] (1).
8. Power the copier OFF/ON to exit the 25 mode.
9. Power the machine ON to see if SC21-06 occurs.
10. If SC21-06 does not occur, replace M10 (p/n56AA-3831).
good lock
Feb 29, 2012 | Office Equipment & Supplies
How do you set the clock on the Pioneer DEH-P3100 CD Player
For most older Pioneer single CD players, you can set the clock using the following steps:
  1. Press and hold the SOURCE button until the unit shuts off.
  2. Press and hold SOURCE again until the clock appears.
    *With some models you will press and hold the FUNCTION or AUDIO button instead of the SOURCE button.
  3. Press the left or right arrow to select the segment of time you wish to adjust.
  4. Press the up or down arrows to increase or decrease the numbers in the blinking segment.
  5. Once the clock is set correctly, press the SOURCE button to exit.
If you continue to have problems, contact our Product Support at 1-800-421-1404.
First push the source button until the stereo is off. Then hold the Program Function(PRG F) key(upper right corner of CD Player) down for ~2 seconds. This will take you to the Initial settings mode keep pressing the PRG F key until you get to the time setting mode. Then select the hour or minute with the left/right arrows located on the right side of the player and the up/down arrows will change the setting.
Apr 24, 2011 | Pioneer DEH-P3100 CD Player
The LED touch Pad underneath the stand does not slide out when touching the Pad. Happened after doing TV reset ( Pressed Remote " Exit" Key for15 secs). Samsung Model: UN46C9000
With your remote, go into Menu. Then scroll down to setup and press the right arrow. Scroll down with the down arrow until you reach General and press the right arrow again. Scroll down once on Slide Key and press the right arrow. Now turn this feature on if not already. If the slide key does not slide out then consult Samsung for repair.
Mar 23, 2011 | Samsung UN46C9000 46 in LCD TV
How do I put a fraction in??
Make sure you're in MathIO mode. Press SHIFT MODE 1 to select this.
Press the fraction key (the stacked boxes, just below the CALC key in the leftmost column). Enter the numerator. Press the down-arrow. Enter the denominator. Press the right-arrow to finish the fraction and continue.
For an improper fracxtion, press SHIFT then the fraction key. Enter the integer portion, right-arrow, the numerator, the down-arrow, the denominator, and then right-arrow to finish.
Sep 02, 2010 | Casio FX-115ES Scientific Calculator
Konica 7165 Service code SC21-06
Solution:
7. Touch [ON] (1).
good lock
Mar 13, 2009 | Office Equipment & Supplies
Lock on light flashing
I finally decided to calm down and use my head and managed to solve the problem. I read the instructions that are on the top of the dishwasher door. ( Smart move on my part HUH!) It said that when the door lock light is on everything is disabled. Hold the air/dry button down for 4 seconds and the lock light will go out. Guess what, IT WORKED. Here is what I learned from this. Always read all instructions. I spent $9.95 for an answer that was right in front of me. Humans can be so dumb I am!!!!
Jan 28, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Tv signal locked
A: The TV is in Showroom mode. The following steps will help you switch to Home mode. 1) Press Menu button from the remote,
2) Press Down arrow key until you see the word Picture, then press the Right arrow key,
3) Press Down arrow key until you see Mode, then press the Right arrow key,
4) Press Down arrow key until you see Power Up, then press the Right arrow key,
5) Press Down arrow key until you see Home, then press the Enter key,
6) Press Menu button four times to exit out from the OSD Menu.
Dec 10, 2007 | Olevia LT27HVX 27 in. LCD Television
Won't print
if your computer is in a foreign language - and you cannot understand the prompts. try the following.
1 press the setup button
2 press the right arrow key once
3 press the down arrow key twice
4 press the right arrow key twice
that should put you on the languages, scroll through the options until you find English (or your preferred language) and press the right arrow key twice once more - that should reset the language for you
Dec 04, 2007 | Epson ACULASER CX11NF All-In-One Printer
SHARP WIZARD OZ-590A DATA ORGANIZER
Turn on your organizer and touch the Clock Icon with your stylus. Just to the right of the bold heading on the top of the screen is a downward arrow. Touch the arrow with your stylus and a screen should come up with with six different modes of your choice. Touch the Home clock. Now touch the Edit on the bottom right hand corner of the screen. Touch the left solid arrow on the bottom of the screen enough times to bring you to the Country at the top of the screen. Touch the solid up or down arrow until you come the USA. Touch the solid right arrow unil you see the USA city field. Now touch the solid down arrow until you come to your city. Touch the solid right arrow once and the hour should be highlighted. Enter your hour. Now touch the right arrow to enter the minutes. Continue with the right arrow to fill in all the values and touch am or pm. Finally touch save or enter. The little smilly face is for daylight saving time which is touched on in the summer time. Hope this helps you, criszhill@yahoo.com
Jul 19, 2007 | Sharp Wizard OZ-590A
Lexmark Wheelwriter 1000 Typewriter Logo
27 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
