Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
I have a John Deere LT 1`33 lawn tractor with a 13
I have a John Deere LT 133 lawn tractor with a 13 hp Kohler engine. The bolts that hold the engine to the frame have all fallen out. What size and length bolts do need to replace them?
Paul - Saratoga NY
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 197 Answers
I believe they are 8mmX35mm.
Posted on Nov 14, 2009
Just wondering what the year of my John Deere 400 is serial number C400J123028M. It has the 20 HP Kohler motor in it.
JD 400 Garden tractors were made from 1975 - 1983.
Serial Numbers
1975: 30001
1976: 55001
1977: 70001
1978: 80001
1979: 95001
1980: 120001
1981: 155001
1982: 190001
Go to this site and you may be able to track it down.
John Deere 400 attachments
http://www.tractordata.com/lawn-tractors/000/0/4/41-john-deere-400-attachments.html
Be sure to read this discussion on serial numbers.
Tractor serial numbers
"Find the REAL serial number
There are usually a lot of different numbers on a tractor. The engine, front axle, and cab may all have their own serial numbers. Various components may have parts or casting numbers. Make sure you have actually found the tractor serial number, and not one of these other numbers."
Mar 18, 2015 | John Deere Garden
ADJUST THE GOVENOR ON MY LT 155 John Deere lawn tractor
This should be Kawasaki engine; although, it could a Kohler. The IPL on this doesn't specify which engine it has. It would nice if it did where I could look the engine's service manual but the following should be what you need.
You place throttle in full throttle position. You need to watch the linkage at the governor shaft for which it turns as you go to full throttle then you would continue turning the governor shaft in that direction until it stops. From there you tighten the retaining bolt or nut and you should be good to go.
Nov 08, 2014 | John Deere Garden
What point wires goes to hot and the ground on a john deere lawn tractor 214 kohler engine
The HOT wire goes to the contacts and the ground normally goes at the mounting screw
Apr 21, 2014 | John Deere Garden
I have a 214 kohler engine john deere lawn tractor, what point wires go to hot and the ground
if that is the Kohler 14 hp motor it may have the spark control untit on the motor cover. I recently ran into one like that and switched the coil out from a blown 20 hp kohler engine. I just taped up the excess wires and made sure they were not near any moving parts. The mower ran fine after that. Kohler wants about $160.00 for a spark control unit. There have been no repercussions since making the switch.
How hard is it to replace the starter on a john deere 420 lawn tractor it has an onan 20hp engine
Not hard at all, disconnect battery than remove battery cable from starter, should be just one nut.there's a smaller wire that should just unplug, than there there should just be two bolts holding the starter in place remove them and you should be able to slide the starter out.
Sep 13, 2011 | John Deere 420,1020,2010,2020,2510,2520...
I have a John Deere lawn tractor, LT 180. Recentl...
The person with the deep knowledge in gardening and machines can give you better suggestion of your problem. There are professionals too available that gives lawn mowing service and have knowledge about the machines used in the field too.
About Us
Jul 25, 2017 | Garden
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
1,084 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
