Question about Arctic Cat 2012 F570 Base
2012 F570 Dies after hour of riding. Requires throttle to restart
It dies when stopped, after an hour or so of riding. It requires some throttle to restart it.
    Champion:
    New Friend:
  • 220 Answers
Clean the low jets in the carb if its not injected. If it is try a compresion ck.
Posted on Oct 02, 2014
My 2004 ford crown vic hesitates and wants to die on acceleration, It idles fine but when i press the throttle it dies. Now the mechanic wants to charge me for a new wire harness and computer?
Find another mechanic.. First, if the harness is bad, it is almost impossible to diagnose a bad computer. I diagnose cars. I start with power and grounds first. Then check wires for continuity. Check sensor and actuators for resistance. I get 1 hour to do this. Usually do it. Sometime the harness is bad. it requires more time. Being a ford... I would start with cleaning the maf sensor and the throttle body. Look at replacing the fuel and air filter.
Nov 12, 2016 | 2004 Ford Crown Victoria
Starts but won't throttle up it dies. Had to replace one intake hose for crack.
Hi, Dona I would love to help you but I need the year, make, and model of your motorcycle please ask your question again with this information in the details box. Good luck and have a nice day.
Mar 04, 2016 | Motorcycles
Huaqvarna chainsaw 240 runs then quits
when ??? dies at wide open throttle ??? dies at idle ??? dies it restart right away or take an hour or more ??? did you put the right 2 cycle mix in the gas tank ???
Nov 27, 2013 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Kohler cv15s
Your battery may bad. Unhook it,check voltage, charge it 24 hours. Check voltage, should about 12 volts. Let set 24 hours, check voltage , if not 12 volts, no good.
Aug 20, 2013 | Craftsman Garden
Chrysler towne and country dies when brake or let off of gas
vacuum leak, throttle body dirty, idle air control malfuction.
Apr 21, 2013 | 2001 Chrysler Town & Country
Engene dies when is started
It can be issue with fuel pressure,its low or the problem relates to faulty spark plugs.
There are few troubleshooting steps to confirm the problem.I suggest you few help links,with complete troubleshooting and solution for these types of issues.
1991 Toyota Trecel: Engine Starts fine but dies when gets Warm? http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
1994 Toyota Pickup: Starts fine but dies in few seconds?
http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
1994 Lexus ES300: Engine Idles Rough and Dies? http://whatisbyme.blogspot.in/2012/05/1994-lexus-es300-engine-idles-rough-and.html
Stalls And Dies At Stop Sign? http://www.howtobyme.blogspot.com/2012/07/stalls-and-dies-at-stop-sign.html
Car dies when gas pedal is pressed? http://schematicsdiagram.blogspot.com/2011/12/car-dies-when-gas-pedal-is-pressed.html
These help links will help you to troubleshoot and solve the issue.
Thanks.
Oct 21, 2012 | Cars & Trucks
B &S 16hp engine on a riding lawn mower. Engine model #303777 Type 0015-02. 420 hours on tach. Under load engine hestates and dies. Will restart immediately, run a few minutes and die again. Without...
check the fuel cap too,, it needs to be venting for better fuel flow, also,, when was the last time it got plugs,, it may be flooding out due to weak spark
Jul 07, 2011 | Garden
Battery runs down after about 5 hours and has to be removed and recharged. This leads me to believe that the battery is not being recharged in use. My supplier says nothinhg is wrong and I am stopping and...
Hi, has your supplier actually tested that the mower is charging? If you have a multimeter check the battery voltage with the mower running at about quarter throttle. It should be higher than 12.7 volts, usually somewhere around 14 volts. If it is not the charging system requires checking. Hope this helps, regards Phil.
May 19, 2011 | Garden
My Suffolk runs erratically at higher speed but when I try to reduce to idle it dies. I had it running half and hour in my work shop but when just about to start cutting it stopped. When running I pushed...
  • Carb jet/s filter and fuel bowl need cleaning. Also tank inside may need cleaning.
  • Air filter needs cleaning oe renewing,
  • Air fuel mixture screw adjustment required.
  • Governor spring need replacing or reconnecting.
  • Throttle cable connections and carburretor arm inspection and remedy.
Hope this helps.
Chris
May 10, 2011 | Garden
Arctic Cat 2012 F570 Base Logo
321 people viewed this question
Top Arctic Cat Winter Sports Experts
J.D. Browning
J.D. Browning
ka4iup
ka4iup
Arnie Burke
Arnie Burke
Are you an Arctic Cat Winter Sport Expert? Answer questions, earn points and help others
