Question about Panasonic PT-AE900U Multimedia Projector
Auto go shutdownn
Projector auto gos shutdown after start
Why do i need when the projector is getting automatically shutdown
Sounds like an auto-shutdown or auto-sleep setting. Go into your System Setup>Basic Menu and check the settings.
Manual can be found here: http://benq.co.in/support/downloads/download.cfm?file=projector/manual/mp515 st/projector_um_user manual_20100524_151409mp515st 525st_en.pdf
Mar 13, 2014 | BenQ MP515 DLP PROJECTOR SVGA Projector
Why does Infocus IN102 projector auto shutdown after a few minutes and indicator light blinks red.
Is it possible to repair the controller board some how? Replacement is not an option because I have approx 100 projectors of this model and X16 lying with me, requiring immediate repairs...
Jan 07, 2012 | InFocus IN102 DLP Projector
LP70 is experiencing auto shutdown if connected to a laptop
shutdown connected or not is shutdown. this is likely a grounding problem between the main board and the power supply.
Jun 03, 2010 | InFocus LP70+ Multimedia Projector
I have set the auto shutdown to maximum, however, the projector keeps shutting after 20 minutes. What is causing this?
Check to make sure that the auto shutdown is turned off. This should prevent any further problems.
Aug 04, 2009 | ViewSonic PJ506D DLP Projector
Shutdown & error led blinking 2 times
Shut off your projector by swith on the back near the AV inputs, leave it off for about five minutes. Then switch it back on, manually press the power button, let it start for about 5-10 seconds then continue to hold power button until picture appears. It worked for me, good luck to all.
Mar 24, 2009 | NEC HT1100 Multimedia Projector
Auto shutdown sharp xg-p25x projector
This would seem to be heat-related as these lamps get hot rather quickly. The first quick and dirty solution - try cleaning the filter which is under a panel on the bottom of the projector. Another fix - be sure the projector is plugged into an image source; i.e. computer or DVD player. Sometimes these units will go into standby mode without a signal. More difficult fix - be sure the fan is runningn. When it shuts down, the fan should keep running until the lamp cools, then it will shut down. If the fan isn't working the temperature build-up with shut the projector off. Replacing the fan may be a job for a tech.
Jan 10, 2009 | Sharp Conference Series XG-P25X Multimedia...
Auto shutdown on Mitsubishi XD series projector
Stripped projector ( including removal of bulb ) and cleaned internals
re assembled and all A1
RR
Aug 24, 2008 | Mitsubishi XD480U Multimedia Projector
Does the 3M 8647 Projector requires a UPS for proper shutdown
look at the amount of va the projector can handle and then decide from there on
Feb 06, 2008 | 3M MP 8647 Multimedia Projector
Panasonic PT-AE900U Multimedia Projector Logo
27 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
