I set up a password on the pump. now after a week the control will not accept my password. I tried the default password (1234). How can I reset to factory default.
please check that the control panel can control other things outside of the temperature. If this is the case, then maybe the pool components (ie thermostat) were not added properly or are incompatible with your control panel. If the control panel does control anything, then the full re-installation needs to be done. Thank you.
Program Lock Input the default password of 1235, the submenu of Parent will display if the password is correct.
(a) When changing the password, the changed password will be updated after four digits are input. The word "ok" appears after you input the same number twice, if the two passwords are different the word "Failure" will appear.
(b) When All Clear is selected, all programs are unlocked.
(c) After you exit from the Program Lock menu and switch to a locked channel, the picture and sound will be locked unless you input the correct password. The channel will remain unlocked until the TV is turned off. After the TV is turned on again, the password must be re-entered to view the locked channels again.
(d) If your program is locked, input the correct password to enter the Auto Search submenu. Operating Auto Search will cancel the locked status.
(e) The default password is always effective.
(f) Entering the default password allows you to go to the Program Lock menu, then change the password while the default password is still effective. This branch menu cannot be entered if a wrong password is keyed in, In this case, press MENU to return to the previous menu.
(g) There will be slight delays while using the Lock All and Clear All functions.
● Child Lock In Child Lock On mode, the buttons on the TV do not work. A prompt "Panel buttons are being locked" will be displayed. However, the remote control buttons will still function. When the TV is on and the Child Lock is on, a prompt "Locked, power off after 6s" will appear. Use the remote control to control the TV. Otherwise, the TV will automatically enter into Standby mode.
Having trouble with setting your Parental Controls (V-Chip)?
The factory preset password is 0000. This password must be used first before setting your own personal password. It is recommended that you keep your personal password in a safe place and away from children. In the event you loose your personal password the master password is 8202. The master password overrides all passwords. The master password can't be changed and should be kept in a safe place away from children.
go to aqualink take off front top panel turn off see if red 4 pin connector is connected and tight if so turn everything off then back on the controller should see it if not check the cable see if cut if ok then check to see if powersupply is working should have 24 volts to back of board
It locked to Security Code or Network Lock,what is Model,Brand ?Do You need To Unlock the Lock? Get the Network Unlock code at here Classicunlocking.com and Unlock from Network lock,get the master reset code there and Unlock from password or security lock,Nokia DCT and Alcatel Old Mobile Phone can be Unlocked from Security lock using the master reset code,Nokia Phone 0000 or 1234 is Default code. Try the Default code if not works get the master reset code,,then for Other Brand,Model get the Default reset code from service provider.To find out it locked to Network ,you insert other Sim card it accept means it's Unlocked,It's Not Accept that Sim means it's locked to Som Network...
The "Administrator Password" can be used in both the "Enter Administrator Password" and "Enter Password" dialog boxes. • Press "Play" to change the "Administrator Password". • The factory default of "Administrator Password" is "1234". If you forgot your administrator password, do the following to retrieve the administrator password: • An unique 6-digit "Universal Password" which is printed on the Security Card (please check accessory in the box). This unique password is the number which will be accepted by projector anytime no matter what the Administrator Password is. • If losing this security card and number, please contact with an Acer service center.
That set may have the general delivery mailbox attached to it. The mail box number for the general delivery mailbox is 100. you might try and resetting that mailbox to see if it gives you access.
Try the default password just in case the changes you made were not stored for some reason.
If this does not give you access, try resetting the router to factory default by pressing and holding the Reset Button on the rear of the router for approximately 10 seconds. Use a toothpick or similar as the button is small and recessed into the case to avoid accidental resetting. You will need to reconfigure all settings though.
The default way to get into the router is to type 192.168.1.1 into the
browser address, the user name is left blank and the password is admin
user manual is available from HERE You need to select the correct version number from the drop down.
With the pump set to off go to the outside controller box and hit it with your hand on the front of the box. It might take 2 or 3 tries. If the pump goes off the control relay is sticking and has to be replaced.
you need to remove the controller from the motor. their are four screws that hold the drive to the motor - remove those and lift off the cotroller, unplug the controller and plug it back in. this should fix it for you.
