Question about 2003 Ford F350 Truck Super Duty Grille All Chrome
Door ajar light stays on - 2003 Ford F350 Truck Super Duty Grille All Chrome
    Sergeant:
    Champion:
  • 253 Answers
Check the light button switch, maybe it just came loose
Posted on Aug 14, 2014
How do I fix my door ajar light stays illuminated
its a bad door ajar switch. which one? you would need a scan tool. but the drivers door does get used more.....
Sep 26, 2014 | 2004 Ford F150
What fuse is for the door ajar on a ford f-350 super duty
http://www.f150online.com/forums/electrical-systems/193352-if-your-door-ajar-dome-light-staying-read-2.html
worked on my f-250
Aug 20, 2012 | Ford F-350 Cars & Trucks
Doorajar liht and beeper sounds
It can be issue with faulty sensor or a wiring issue.Troubleshooting is required.
Click the help link shown below:---
Door Ajar Light and Dome Light Remains ON? http://whoisbyme.blogspot.in/2012/06/2003-mercury-sable-door-ajar-light-and.html
Door ajar light stays on? http://technoanswers.blogspot.com/2012/01/door-ajar-light-stays-on.html
Thanks.
Jun 26, 2012 | 2002 Ford Explorer
My light is on in the dash it said door ajar dont go off
For troubleshooting this problem,click the help link below :---Door ajar light stays on? http://technoanswers.blogspot.com/2012/01/door-ajar-light-stays-on.html
-------Thanks.
Feb 19, 2012 | Cars & Trucks
Door ajar light and buzzer stays on when I'm driving my 2006 ford focus
This problem is caused by one of the door ajar sensing switches being defective, it is a common fault in Many Ford cars and light trucks. Each door has a switch and two at the tail gate door. The switches are attached to the side of the door latch and very hard to replace, since you would most likely have to detrim at least two doors to find the bad switch the most prudent thing to do is have the dealer scan the door ajar waring system, the scan will indicate exactly which switch has the problem.
Jan 25, 2012 | Ford Focus Cars & Trucks
My door ajar light is on but all doors are closed and the overhead lights keep going on and off
You have a bad door ajar switch on one of the doors. It is shorting out and causing the lights to flicker and the door ajar light to stay on.
Feb 01, 2011 | 2002 Ford Explorer
2001 Sequoia, door ajar light goes off, but dome light stays on. Door ajar light comes on with slight pressure against closed door. Can replacing the door jam switch solve this problem? Why would the door...
To temporarily solve the light problem, I taped a washer to the inside of the door where the door hits the plunger on the light switch. A permanent solution would be to drill a hole in the door at this spot and put a self taping screw in that will trigger the switch sooner. I figured out the reason the dome light stayed on is due to the courtesy light timer and the lights would have eventually gone off.
Nov 12, 2009 | 2001 Toyota Sequoia
2005 f150 "Door Ajar Light Always On.. Even with all doors shut..
What happens when you remove both switches, and wires? What happens when you use a jumper wire acros both wires, on both doors?
Feb 25, 2009 | 2005 Ford F-150
2003 Explorer door ajar light stay on when all doors are closed
I had this problem on my 2003 explorer and took WD40 and gave the lock mechanism a good dose where it meets the clasp on the door jam. Then open and close the doors a couple of times to get them working. They get gummed up and sometimes have a tendency to stick.
Dec 29, 2008 | 2003 Ford Explorer
Door ajar indicator stays on
you may just need to adjust your door jams they may not be closing properly, the other thing you can try is opening one door at a time and putting your finger on the switch usually in the lower l/h corner of b piller and see if the light goes off if not this may be the problem and replace the switch
Dec 18, 2008 | 2003 Toyota Corolla
2003 Ford F350 Truck Super Duty Grille All Chrome Logo
Top 1A Auto Parts Vehicle Parts & Accessories Experts
Tom
Mike Stager
Mike Stager
Are you a 1A Auto Parts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
