50 is 20 percent of what number
Please show steps on how to solve this problem
  • 457 Answers
You need to find out what number x is 100%.
Start out with the facts known, 50 is 20% of this x, and write it down in mathematical symbols. This is just a translation of the words in your problem to the shortcut equation language used in math, the meaning is exactly the same, and with a little more experience you will easily move between these two.
50 = x * ( 20 / 100 )
Remember, 'percent' is from latin "per one hundred".
Multplying left and right side of the equation by 100 yields:
50 * 100 = x * ( 20 / 100 ) * 100, consolidation results in:
5000 = x * 20. Divide both sides by 20:
5000 / 20 = x * 20 / 20, consolidate:
250 = x.
This is your result, 250.
Posted on Mar 20, 2014
Help using HP17 bII+ to solve for annuity?
If the interest is 1 percent per month, then it's 12 percent per year. Thus I/Y = 12. You're making monthly payments so P/YR = 12. With N = 48 and PMT = -632, I get $23,999.54 .
Select FIN from the main menu, then TVM. Press [SHIFT] [CLEAR DATA] to clear. Press OTHER, enter 12 P/YR and select END if needed. Press [EXIT] to return to the TVM menu. Enter 48 N. Enter 12 I%YR. Enter -632 PMT. Press PV to see the result.
Feb 29, 2012 | HP Computers & Internet
If the interest rate is 1 percent per month then it's 12 percent per year. You're making monthly payments so the payments per year is 12.
From the main menu, press FIN then TVM to enter the Time Value of Money mode. Press [SHIFT] [CLEAR DATA] to clear. Press OTHER. Enter 12 P/YR and END. Press EXIT. Enter 48 N. Enter 12 I%YR. Enter -632 PMT. Press PV to see 23,999.54 .
Feb 29, 2012 | HP 10b Calculator
Formula for converting fractions into percentage.
Simplest method
  1. divide the top of the fraction by the bottom
  2. Then multiply the result by 100
  3. add a percent sign to the answer so people know it is a percentage (i.e. per 100)
  • e.g. 3/5 *100 = 0.6 * 100 = 60%
Alternative method Since percent means "per 100", you can try to convert the faction to the form ?/100
follow these steps:
  1. find a number that you can multiple the bottom of the fraction by to get 100
  2. multiple both top and bottom of the fraction by that number
  3. write down just the top number with the % sign added to the end
  • e.g. 3/5 as a percentage
  1. we can multiply 5 x 20 to get 100
  2. multiple top and bottom by 20 = (3*20)/(5*20) = 60/100 = 60%
I hope this helps and good luck! If you have more questions - ask away! Please take the time to rate this answer.
Don.
Sep 08, 2011 | Computers & Internet
300,000 is 86.2 percent of what number? Could you please provide me with the formula for calculating this? Thank You
set the problem up like so:
300,000 86.2
_______ = _____
x 100
To solve for x, take 300,000 * 100 / 86.2
The answer is 348,027.84
Good Luck,
Rodrick
Apr 22, 2011 | HP 12c Calculator
How to calculate a percentage - whole numbers
Say you want to know what percent x is of y (or To find out x is what percent of y).
We take x / y and times 100. Depending on what x and y are this might not always be a whole number,
we could round the number off to a whole number. An example: 81 is what percent of 135? To solve this
take (81 / 135) * 100 = (0.6) * 100 = 60 percent.
Mar 29, 2011 | Office Equipment & Supplies
I have a pc having intel d945gclf motherboard. I have problem with sound card. while installing audio driver it shows error code 10. please tell how i could solve this problem? secondly, can i install...
I Was also facing the same audio problem . To resolve it
1. Download Universal Audio Architecture From here. Download and install it . By doing this your motherboard will recognise audio controller.
2. Download Latest Audio driver from here.
Works 100 percent Enjoyyyyyyyyyyyyyyy.
Works 100 percent Guaranteed
Dec 05, 2010 | Intel D945GCL Motherboard
How do you figure out percent on the TI-84Plus Program. Calculatr
To figure out the percent, you simply divide your number by 100. Or, multiply your number by .xx (xx being whatever percent you want to find).
For example, if I want to know what 20% of 50 is, I would enter this:
.20 x 50 =
The answer is 10. So, 10 is 20% of 50.
As for the divide button, look for a "/".
If this helps, please take the time to give this response a positive rating. Thanks!
Mar 18, 2009 | Office Equipment & Supplies
Plz help...
A firmware update. Same happens to my friend's unit yp-u2(x) a 512 mb model.
In XP OS.
1. Download and install firmware updater.(manufacturer's support site)just key in model number and type.
2. Run updater, press and hold play button until its been detected fully by the updater.
3. Check the format box(My friend's unit firmware ver is 1.xxx to 2.xxx something when updated).
4. Hit the update button or something like that. do not detached the unit until its done. Unmount the unit using unmount method "Safely remove hardware".
5. Turn on the unit it should pass the 20 percent mark. When its good it has no file yet coz of format option. Just load your song.
I think it happens when too much file is upload in the unit. 60 percent of its capacity may be enough.
Hope it helps............
Jan 16, 2009 | Samsung YP-U2X Digital Media Player
Stops formatting at 99 percent
My ps3 won't show an icon for any disc that is in, it loads forever and still nothing, aparently my laser is broken, looking on the net and the problem you are having is related to the problem I have according to most people's blogs. If you still have a warranty, call the Sony customer care line on: 08705998877, I called them today, I just had to give my name address phone number and serial number on back of ps3, my new ps3 is being delivered by courier, free of charge tomorrow!
Good luck.
Feb 09, 2008 | Sony Playstation 3 (PS3) Console
78 people viewed this question
jasbo
jasbo
