Question about Moultrie GameSpy M-880 Game Camera
No photos on Moultrie M-880 32 g card, batteries and card work.
Batteries are good, card checks out, camera switched to on position, but not taking photos.
  • 296 Answers
SOURCE: Moultrie DGS160 Game Camera Error 20000
Forget calling Moultrie...I think their answering system is permantly set for "off-hour" times...you may have to e-mail them several times be fore (after4-5 days they get back to you.
You're error should read error"0200000"...flash error or flash charging...getting this during system diagnosis probably is that you failed to cover sensor during ck.
I f this is a constant error...turn cam on; remove batteries; turn system off; insert batteries and try again. .
Posted on Feb 17, 2010
  • 296 Answers
SOURCE: Moultrie I450 Game Spy
Before installing a sd card, internal memory MUST be erased. From setup,use the up/down buttons near the select button until the display reads "ERASE ALL PICS(MEMORY)? NO" toggle up or down button to get"YES", press the select button and wait until until it says "DONE".
Go to setup screen, power off, intall sd card...should be good to go.
Posted on Mar 06, 2010
getyourfix
  • 43 Answers
SOURCE: camera won't come on
1. Replace batteries with new alkaline batteries.
2. Sometimes an SD card may malfunction. Remove the SD card and turn the camera on. Check your manual for proper use of SD card.
3. Still having issues? If you bought the trail cam within the last 12 months, send it to Moultrie for repair.
Here is the link with a return form an procedures for the return.
For more information about trail cameras, visit my Hunting Supplies Website
Posted on Jul 31, 2010
SOURCE: my Moultrie camera turns itself
Don't know what causes it, but I have 2 cams that are doing the same thing. Batteries are 95%. Don't know if has anything to do with cold weather. Haven't had this problem in the past.
Posted on Dec 31, 2010
SOURCE: Moultrie cdc - 5.0
According to Moultrie you can try a hard reset.
Take out batteries, and SD card, hold on button for 2 min.
Replace batteries and try, haven't tried it yet, but will
Posted on Oct 11, 2011
There is no button on front to release battery compartment
No, it is on the bottom
Page 3
Slide the UNLOCK switch on the bottom of Camera and use the knob to pull the slide-out
Battery Tray. Install eight (8) AA size alkaline or lithium batteries with polarities as
indicated in the Battery Tray. Re-install the Battery Tray and insert your SD card.
We recommend that you format the SD card inside the camera before taking pictures
http://images.ebsco.com/pob/moultrie/catalog/m-990i_manual-english_web.pdf http://images.ebsco.com/pob/moultrie/catalog/m-990i_manual-english_web.pdf
May 08, 2016 | Moultrie Game Spy M-990i
How do i stop my moultrie camera from taking multiple photos per minute? I have 2 and they both take 3 pics every minute of every day.
not sure if you formatted on computer or camera, you should always format on camera, also delete pics on camera, after you copy them to laptop.
Sep 11, 2014 | Moultrie MFHDGSD50 Game Spy Camera D50
Www moultrie com
Check contacts of the batteries and in the battery compartment of your camera. Dirty or oxidised contacts can be cleaned with a dry cloth. Never use sharp tools to clean contacts or anything in or on your camera.
Always charge the batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Also check if the battery door is closed correct. Most cameras do have a switch connected to the battery door. If the switch does not work correct, it could be you can't switch on your camera.
Do not use alkaline batteries unless it is absolutely necessary. In most cases, alkaline batteries have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in your camera. They can't deliver enough power and can start leaking, causing damage to your camera.
Jul 23, 2014 | Moultrie Game Spy 5 Mp D55ir Infrared Game...
Menu screen nothing but lines.
Turn camera off, remove battery's and sd card. With everything out turn it to the on position for about 2-3. After 2-3 minutes put batterys back in while on the on position. Once he says no card or no memory turn the camera off put sd card back in and test the camera.
Mar 02, 2014 | Moultrie Game Spy D555i Trail Camera
Camera shuts down after 1-2mins an does not take pics
Just to let you I had Moultire m-80 when I used a pny sd card it ruined my camera. They were kind enough to replace it for me. I just use what they recommended do not have any more problems. I only delete pic on my computer and not digital camera. Try doing a hard reset take everything out turn to the on position for about 2-3 minutes after 3 min put brand new battery's in it while on the on position should say no card at this time. If doesn't turn camera off put sandisk sdhc card in it. Test camera again if still not working Moultire will help you I have talked them great customer service.
Nov 26, 2013 | Moultrie Game Spy M-880
My pictures at night are nothing but a black picture
HARD RESET TAKE OUT BATTERIES AND SD CARD, TURN IT TO THE ON POSITION FOR ABOUT 2-3 MINUTES WITH NOTHING IN IT. AFTER 2-3 MIN PUT BATTERIES BACK IN WHILE WITH THE ON POSITION IT SHOULD SAY NO CARD. ONCE IT SAYS THAT TURN OFF THE CAMERA PUT THE SD CARD BACK IN TURN THE CAMERA BACK ON AND TEST IN THE DARK. IF THAT DOESN'T WORK SEND IT IN FOR REPAIRS TO MOULTRIE.
Nov 07, 2013 | Moultrie Game Spy D-333 Game Camera
Moultrie cdc - 5.0 Trail camera appears dead. New batteries, but will not turn on?
Aug 07, 2011 | Moultrie Cameras
Camera won't come on
Jul 28, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie GameSpy M-880 Game Camera Logo
29 people viewed this question
Top Moultrie Video Cameras Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Moultrie Video Camera Expert? Answer questions, earn points and help others
