Question about Proscan 32LB30QD 32 in. LCD TV
How to get out stuck dvd out of proscan 32lb30qb
How do I get dvd that is stuck in the tv
Hi, Need help with ProScan TV mo#32LB30QB.
T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts.
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jul 25, 2016 | Proscan 32LB30QD 32 in. LCD TV
My dvd is stuck inside of the TV. How can I get it out?
If the motors want unload it then you will have to take the player and walk it out by hand. Sound like some bad problems with the dvd player.
Col. Dana Gillespie
Oct 07, 2014 | Proscan Recertified - PLCDV3213A 32" Black...
Dvd won't eject from tv/dvd combo stuck
Try looking for a small hole where the DVD goes in the TV about the size of a paper clip. Some of the times like on a computer there is a small hole that you can put a paperclip in and push on an internal button and this will release the DVD.
Jan 06, 2014 | Proscan Televison & Video
I have the Proscan TV/DVD combo. The cable remote works for the TV, but NOT for the DVD player. And ever since I got cable, the Proscan remote no longer works (for tv or dvd.) Long story short, I have...
Did ever worked properly?Is it wright one for unit that you have,you can check that in your owner manual,if not I will go back to dealer and ask for replacment.
Aug 23, 2011 | Proscan 32LB30QD 32 in. LCD TV
There is a dvd stuck in the drive of my proscan 26LB30QD. how do i get it out?
There is no easy way to get the stuck DVD out.
According the owners manual you will have to call PROSCAN customer support for help with this problem. The telephone number for customer support is 1-888-977-6722. You can also go to The website and use the customer support there. The website for PROSCAN is www.oncorpus.com. I hope this has helped you with your problem.
Jan 07, 2011 | Proscan 26LB30QD 26 in. LCD HDTV
Dvd stuck in tv dvd player
Mar 12, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
DVD input channel reads "no signal" when I try to play a DVD
First I would run a dvd cleaner in unit! Second you could take tv apart and look to see if signal cable is loose. the power wire seem fine as it powers up, and accepts an eject dvd.
Feb 28, 2009 | Proscan 32LB30QD 32 in. LCD TV
No signal from my dvd player
Can you tell me how to connect my dvd player to my 42 inch proscan hdtv ? There are no yellow,its blue and there are two rows of the same colors.
Feb 03, 2009 | Proscan 32LA25Q 32 in. LCD TV
PROSCAN PS35130
I got an old (1995) 36" proscan without a manual, and it's been a pain to get it working. Nice enough TV once you do, though.
The weirdest thing is that S-video shows on channel 91, and the AutoProgram function won't find it. That's right; they just randomly picked 91, and you're stuck with it.
Pressing Menu on the front brings up the menu. Pressing it again cycles through choices, and the plus and minus buttons to the left of it activate the choices.
Good luck finding any more info; hope this helps
Sep 04, 2008 | Proscan PS36500 36" TV
Proscan 32LB30QD 32 in. LCD TV Logo
20 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
