Question about Kitchen Ranges
Mcclary stove unfinished woodstove needs work. whats it worth
I have a McClary Charm A2746 wood stove.I wanted to know what year it is?
Kathy, There should be a certification plate on the stove some where, listing make, model, year of manufacture, etc., open doors/drawers etc. to see if tag is riveted on inside panel or frame. Check the attached links they may help determine the age of your stove, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
McClary Charm A2746 wood stove Google Search
Antique stoves for sale
Ernie Woodstoves Durham Ontario Canada Repairs Restoration Sales
Strong on Stoves
mcclary wood stove history Google Search
Jul 15, 2016 | Home
Kingsman woodstove wh 968541
Kingsman may be able to supply a manual.
Jun 29, 2014 | Kingsman Home
I NEED A STARTER STOVEPIPE OVAL TO 8" ROUND FOR A
In as much as that model stove is over 30 years old, it's unlikely you'll find an exact match to what you need. However, locating a Simpson Duravent dealer, may provide some alternatives.
Hope this helps you and thanks for choosing FixYa.
Sep 11, 2011 | Heating & Cooling
Fan on woodstove not working regularly. Model no WOODSTOVE 1800/2400. Thanks, Brendan
Brendan, if you can access the blower remove it and clean it. Note if any lubrication of the fan's shaft needs lubrication (light weight machine oil will work). Also, check the outlet that the fan is plugged into, to make sure it' still has power. If it's an automatic fan that has a senor to turn it on and off, that sensor may have failed and will need to be replaced. Depending on the age of the wood stove and the blower assembly plays an big role in this. They don't last forever.
Apr 26, 2011 | Heating & Cooling
We installed a Woodchief wc 100c woodstove and i
Hello, I have the same model. The plate on the back say's,install with min installation clearance's side and rear wall 18 inches fire door end 36 inches front 48 inches above 51 inches flue pipe 18 inches install on non combustible and non conducting base of 9/32 inch min thickness that extends 6 inches beyond the sides and 18 inches beyond fire door side. circulating fan type FF-100
Feb 23, 2010 | Heating & Cooling
I just got a Whitfield Quest pellet stove from a friend. Do I need a fresh air pipe if I use it in my house/ basement? Also where can I get a repair/owners manual. Thanks Kurt Willem
Some people plump in fresh air but you can also punch out the fresh air in take out on the back of the stove and recirculate the air within your home.I would think twice about installing it in your basement . Basements have a tenancy to create a negative pressure, which means that it can become very difficult to create and up draft through the chimney , which causes the smoke to seep out of the stove into your home. The only way I have found to over come this is to run a torch in the stove for 5 mins before starting a fire, this creates an up draft which eliminates the problem.
Aug 19, 2009 | Napoleon Auburn Pellet Stove Heater
What do you need to do to put a woopellet stove pipe thru wall
I'm confused by your question. If you are asking what is involved in installing a pellet stove well it varies greatly from model to model. Generally speaking, most pellet stoves will horizontally terminate behind the stove itself as opposed to running thru the roof like a woodstove does. Pellet stoves require the use of electricity for numerous functions, one of which is power venting thru this rear terminated pipe. As far as clearances to combustables, you will find that pellet stoves are very forgiving in that department, with minimal clearances required. Once again all stoves are different and they all are rated indepentently so my best advice to you is find a quality pellet stove dealer and go in and see them. They will be more than happy to answer your questions. Avoid the big box stores as they have pellet stoves at a good price but offer NO service or installation and believe me, I am in the business, you will need professional service at some point during the life of your stove so don't save a couple bucks by going cheap. You will be happier for it down the road. Good luck.
Mar 12, 2009 | Napoleon Auburn Pellet Stove Heater
Kitchen Ranges Logo
13 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
