Question about RoadPro 1500 Watt DC to AC Inverter
No out put
Alarm no out put
We replaced the battery on my mazda cx9 2009 put the cables on neg then positive alarm went off. then we put the cord on the port positive then negative. no alarm. Now the car won't start. We checked
Forgot to use a memory saver,did ya?
See an alarm specialist/car stereo shop . Re-connect cables and try again.Find car alarm wires and disconnect. Car alarm is designed to NOT let the car be started,if power is lost.
Nov 11, 2014 | Mazda CX9 Cars & Trucks
Nissan altima key fob broke when dropped
The alarm will sound if the alarm was set before you dropped the key fob. Just put the key in the ignition and start the car, the alarm should turn off.
Jan 15, 2014 | 2002 Nissan Altima
2006 buick alarm can not be shut off.....
After the key is put into what? The OEM alarm is armed and disarmed through the driver's door key cylinder. Insert the key into the key hole of the driver's door, turn to unlock, this disarms the factory alarm. Turn to lock, this arms the factory alarm. Now, if you have an aftermarket alarm this procedure does not apply.
Oct 07, 2012 | 1998-2002 Park Avenue Door Lock & Alarm...
I bought a Chevy Trailblazer, used, had keyless remote access Viper Alarm after manufacturer. Had trouble with transmission and alarm....took to Chevy dealer they replaced transmission. Now the remote...
You need to find the black push button called the valet button. That is the overide. Get in the car turn the key to IGN as the alarm is going off and then you have either 5 or 10 seconds to push that button once and then 2-5 seconds later the alarm is shut off. To put the car into valet mode which means no alarm at all you put the key to IGN push that button once then pull key out at which point the blue light should turn solid blue.
Or option two is you open a door and hit the lock, then unlock, then lock button again on the remote and the blue led will be solid which means no crazy alarm.
Mar 08, 2010 | 2004 Chevrolet TrailBlazer
Does not cherp
Is your perhaps alarm in "valet mode"? I've got a Checkmate on my Honda, and I can turn valet mode on/off by putting the key to Accessory, then pushing the black button under the left of the steering wheel. The alarm chirps when you switch the mode.
May 23, 2009 | 2000 Buick LeSabre
Car alarm wont turn off
Try changing the batterys in the remotes mate
Feb 16, 2009 | OEM Systems Vehicle Parts & Accessories
Car alarm how to reset a cobra alarm after fitting a new batt.
i put a new battery on my car and now the alarm will not work
Dec 16, 2008 | 2006 Mitsubishi Colt
Changed the battery. The alarm went off, tried to reset but will not work. When driving push on the brakes and the car shut down. Is this an alarm issue or an electrical engine issue. Don't know what to...
Yes this is an Alarm issue that's why your vehicle is shutting down as soon as you press on the brake pedal. Is this an aftermarket alarm or stock alarm? Sounds like aftermarket alarm to me and if it is, the way fix this issue is as soon as you put the red n black terminal on the battery and the alarm goes off press your alarm key right away to turn it off. If this doesn't work put your key on the ignition after you have installed the battery and just put it on the "ON" position engine OFF then click on your alarm remote once again.
Sep 23, 2008 | Mitsubishi Eclipse Cars & Trucks
Alarm
The 'mazda' setting is supposed to look like an analog clock, and that's for setting the time. The key position puts the clock in operating mode, as opposed to clock set or alarm set modes.
I've only had the clock for a day, but if you want the alarms to shut off and alarm again the next day, use the OFF switch on the top right of the unit. If you want to disable the alarms completely, use the 1 and 2 buttons behind the OFF switch to cycle each alarm through the settings: none, bell, music (radio)
Sep 06, 2007 | RCA RP5420 Clock Radio
RoadPro 1500 Watt DC to AC Inverter Logo
24 people viewed this question
Top RoadPro Electronics - Others Experts
jdthefixer
deton8 von Splosion
Are you a RoadPro Electronics - Other Expert? Answer questions, earn points and help others
