Question about Motorola Cell Phones
My phone keeps cycling, do i need to master reset the phone?
  • Official Brand Answer
  • 3,100 Answers
Yes possibly. What model?
Mark
Motorola Support
Posted on Feb 07, 2015
I want too master reset my lg-p500h
Goto the settings,privacy,factory data reset and press it.The phone will be master reset and will switch on.But keep in mind to backup your data before resetting as you may loose the data by using master reset
Apr 13, 2012 | LG P500 Cell Phone
My cherry mobile nova android phone keeps on powering on and off every 5-15 seconds, what should i do to stop it? i can not use my phone because it will keeps on restarting
Your phone is stuck in a "Boot Loop". This was most likely caused by a newly installed update, program or an unfortunate virus. Start by removing the battery for about 30 seconds. Push down on the power button while the battery is out, to release all memory from the board. Re-install the battery and turn the phone back on. If it is still stuck in the boot loop, you will need to perform a master reset.
WARNING!!! A MASTER RESET ERASES ALL DATA ON THE PHONE AND RETURNS IT TO THE ORIGINAL FACTORY SETTINGS!
PROCEED AT YOUR OWN RISK!
Master Reset for your device is done by turning off the phone. Then press and hold the camera button + volume up + power button. Keep holding even when the phone turns on. Navigate with the trackball, scroll down and click on Wipe data/factory reset. Hit yes to confirm everything and let her rip.
Dec 20, 2011 | HTC G1 Cell Phones
What is the password of master reset in samsung device?
HI M'praveen kumar so you know the last 4digit of your phone number usually service as a reset code on the non- smart phones for the samsung devices. A smart phone has the master reset in the settings.I 'm keeping it very simple.
Nov 12, 2011 | Cell Phones
Nokia 1203-2 security code type :RH-112
If you forgot the security password, then you need to master reset the phone. I recommend you to contact your service provider to get the master reset code.
Aug 13, 2011 | Nokia 1100
No signal
1.Turn the device off and back on. Most service issues are due to old, timed-out registrations that have dropped you from the network. By power-cycling the phone, a new registration is acquired and signal should be restored.
2.Perform a Master Reset. If power-cycling did not restore your service, the problem may be due to a software issue. Doing a master reset will revert the software back to factory standards, restoring your service by removing bugs that may have developed over time. Generally this is done by pressing "Menu," "Settings," "Initial Setup" and "Master Reset." However, steps may vary from device to device so refer to your user manual for different steps if needed.
3.Perform a Master Clear. If the master reset did not restore your service, the software issue at work may be severe. In this case, it is necessary to completely wipe all information from the device and install a fresh copy of the operating system using the Master Clear function. Press "Menu," "Settings," "Initial Setup" and "Master Clear." Again, steps may differ from phone to phone, so consult your user manual as needed.
4.If the software resets did not restore your service, it's possible that the cellular radio has ceased functioning correctly. Contact your carrier for repair, replacement or exchange if it is still under warranty. Your carrier can advise you of the options you may have.
Apr 15, 2011 | Cell Phones
Not able to make or recieve calls
Hello
Check if there is network on your phone,if there isnt you may just have to go to a n area with clear network or maybe it is just a network problem
Oct 02, 2010 | Cell Phones
No service
  • Turn the device off and back on. Most service issues are due to old, timed-out registrations that have dropped you from the network. By power-cycling the phone, a new registration is acquired and signal should be restored.
  • Perform a Master Reset. If power-cycling did not restore your service, the problem may be due to a software issue. Doing a master reset will revert the software back to factory standards, restoring your service by removing bugs that may have developed over time. Generally this is done by pressing "Menu," "Settings," "Initial Setup" and "Master Reset." However, steps may vary from device to device so refer to your user manual for different steps if needed.
  • Perform a Master Clear. If the master reset did not restore your service, the software issue at work may be severe. In this case, it is necessary to completely wipe all information from the device and install a fresh copy of the operating system using the Master Clear function. Press "Menu," "Settings," "Initial Setup" and "Master Clear." Again, steps may differ from phone to phone, so consult your user manual as needed.
  • If the software resets did not restore your service, it's possible that the cellular radio has ceased functioning correctly. Contact your carrier for repair, replacement or exchange if it is still under warranty. Your carrier can advise you of the options you may have.
  • Sep 27, 2010 | Cell Phones
    Could you please pass reformatting info my way?
    try a master reset of the phone
    MENU
    SETTINGS
    INITIAL SETUP
    MASTER CLEAR - 000000
    MASTER RESET - 000000 - security default code
    Jun 12, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
    Cell Phones Logo
    Top Motorola Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
