Question about Samsung SyncMaster P2270 22 inch Monitor
P2270 white screen
White screen
Check engine light is on autozone gave P2270 after checking it? What does this mean?
This P2270 trouble code refers to the post-catalytic converter O2 (oxygen) sensor on bank #1, sensor #2.
Check this site:
P2270 O2 Sensor Signal Stuck Lean B1S2
Feb 28, 2015 | Cars & Trucks
Hi, my syncmaster p2270 seems to have some kind of focus issue. Everything is sharp, but to the right of the visuals on screen there is a duplicate, reflection of whatever is being displated on screen....
Hi Jonhy, on the pc , try this steps:
1. At the mainscreen mouse rigth click and go to Properties
2. Go to Definitions and Advanced
3. A window with graphic board's properties will come up and the choose 3D setup/config (depending on graphic board mark)
4. Change from Direct 3D to OpenGL and then Apply and OK to close.
This procedure is to change from hardware aceleration to software aceleration of image on screen. As that it will be sent only one kind of image definition from the pc to the screen with no repeating or mirrowed data. Hope it will helps you.
Nov 04, 2013 | Samsung SyncMaster P2270 22 inch Monitor
What to the codes P2270 mean on my Cadillac
It's the O2 sensor attached to your exhaust pipe behind the catalytic convertor that has detected your exhaust is too lean. It could mean any of a variety of issues from simply the sensor is faulty, to the sensor being loose fitting, to a leak in the exhaust before the sensor, to a bad fuel injector ---- essentially, anything that can reduce the amount of fuel emission that "should" be present.
Nov 02, 2013 | 2008 Cadillac Escalade
Cadillac Escalade 2008 what to the codes P2270
Bank 1 Sensor 2 signal is indicating a lean condition, replace the O2 sensor. Right side (passenger) after the Cat.
P2270 code on my pontiac wave 2009
Use Google to look up the code
2009 Pontiac OBD Code P2270
Mar 27, 2013 | Cars & Trucks
2005 Honda accord code p2270 that is ?
DTC P2270: Rear Secondary HO2S (Bank 1, Sensor 2) Circuit Signal Stuck Lean
Is this the only code that is coming up? If so, replacing the Bank 1 Sensor 2 Oxygen sensor should fix it. If there are any other engine/drivetrain/emissions related codes, I would recommend ignoring this code for now and fix the other things first, then retest the vehicle to see if this code comes back.
For more information about locating oxygen sensors and repairing oxygen sensor codes, please review the following article:
Which Oxygen Sensor Is It?
What Else Could Be Wrong?
Sep 28, 2011 | 2005 Honda Accord
Reader show me a code P2270 im trying to find out what that for
P2270 - 02 Bank 1 Sensor 2 signal stuck lean
Switch Sensor indicates lean, this is on the passenger side after the Cat, you will need another sensor. It could be a bad sensor, bad wire connection, I would have replaced all, I know it would have been 200 dollars but now it only 150 to do the remaining three and still cheaper then going to the dealer plus you get four new sensors.
Hope this helps.
Jul 11, 2011 | 2004 Ford Freestar
P2270
Hope this helps.
Jul 11, 2011 | Ford Freestar Cars & Trucks
2005 Ford Ranger exhibiting code P2270
According to my book, it looks like a bad O2 sensor, the sensor behind the catalytic converter on the passenger side exhaust.
Bank 1, Sensor 2.
You can pick one up at the parts store for around $75.
Dec 17, 2009 | 2005 Ford Ranger
Samsung SyncMaster P2270 22 inch Monitor Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
