Question about Copystar CS-2114 Copier
CS-2114 Problem Our copier started blinking replace unit, we have already replaced the toner in the copier. Do not have a manual and need to know why it's blinking and how to stop it. Thanks...
  • cindy3030 Dec 15, 2008
    My service tech told me that he cannot get the "unit" anymore when my "replace unit" light goes on. Is this true? Do you know where I could order a "unit" and how much it will cost?
  • 51 Answers
"Our copier started blinking replace unit" you need to replace the PROCESS unit...not the toner, and you surely don't need to go pokng around the back of a live copier with a multi-meter!!! I just relaced one for a customer, they are the blue things where you open the front door. They were available in june of '09, e-mail me and I'll get you one (don't know price off-hand) and tell you how to reset the unit once replaced.
Posted on Sep 10, 2009
  • 36 Answers
The toner hopper motor was modified for this problem some time ago. Was this one updated? There was a tech bulletin on it.
If it was, you will have to bite the bullet and replace the DV unit.
Posted on Nov 01, 2007
I had the same problem, and replacement toner cartridges are expensive. Also might need to change the drum. Copier is rigged to detect a new cartridge and the copier will soon stop copying at all. The blinking light changes to a steady light, and it will make no more copies. Solution: If you are still getting good enough copies try t his: I took the back cover off. At the bottom right you can see the back side of the toner cartridge connection (5 wire plug as I recall.) I grounded the negative on a multi tester to the copier frame and tested each connection for voltage with the positive probe and found none. Then I tested the bottom two wires, grey I think by sticking the neg and pos probe from the multi tester in them. Still nothing, but funny thing; the copier replace unit light went out and it makes great copies again!! I was in simulation mode while I was doing this but am not sure if that was necessary or not. Do a search on CS -2114 and you can see where a tech tells you how to do it. I think it started working again because I fooled it into thinking I had put in a new cartridge. Some cartridges are rigged so that
a fuse blows just after they are inserted, new, into the copier, and this tells the copier brain that it is a new unit and it resets. Some how, just fooling around sticking probes into that toner connector, I was able to accomplish the same thing. Try it; definitely not hard. Hardest thing was getting that back cover off as there is a turn screw thing at the top that blocks it. I just cut out the plastic around it so that t he cover would come off. Good luck. Save you a few hundred dollars.
Posted on May 05, 2009
How to change the drum cartdrige.
Remove the imaging unit ,remove the charge corona assy,remove the OPC drum,remove 2 screw and dump the developer out.Reinstall the imaging unit ,pull out the toner cartridge and push in toner cartride ocation the developer cartridge.Turn on the copier and wait then the copier perform the new developer initialization.Whwn the Start button in ready(green light),change the developer cartridge to toner cartridge.
Mar 05, 2013 | Minolta EP1031/1031F CS/PRO Copier
I am a tech and have to replace the drum on a copystar CS 1635. The service manual has been lost so I need the instructions.
open front cover, remove toner cartridge and waste toner tank. unscrew the screw below the developing unit and release the dev unit by pulling the lever. open left cover. from the front remove the screw on your left holding the drum unit. gently pull out the drum unit and replace the new unit using. the reverse procedure to be used.
Apr 20, 2011 | Kyocera Copystar CS-1635 Copier
Waste toner reservoir overflow
problem (when the total number of
copies is 100 thousand sheets or
• After E31 is displayed, 1,000 sheets
are copied. Or waste toner exceeds
5 g.
Defective waste
toner sensor or
engine PWB.
Shake the process unit from side to side
and turn the power switch off and then on.
If the problem cannot be solved, replace
the process unit.
After replacing the process unit, turn the
power switch off and then on. If the problem
cannot be solved, replace the waste
toner sensor or the engine PWB.
Mar 30, 2011 | Copystar CS-2030 Copier
Copy star cs2114
C-30 means scanner motor problem.
If there is no continuity on the motor coil - replace with a new one
The home position switch may be disconnected, or defective test for continuity, replace as needed.
check for scanner pylly bindng, and lube scanner rails with light oil.
Good Luck!
Feb 28, 2009 | Copystar CS-2114 Copier
Sharp SF 2114 H-4 Error: Fusing Unit Not Heating
Replace fuser lamp and check the condition of thermistor and rectify.
Jan 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
Cs-2114 all dark copies
if you replace drum meanwhile you have to replace developer too, after you replace then you have to simulated follow these steps;
1, power off,hold down"print"&"stop/clear" key while you turn on.
2,press"stop/clear" key within 2 second.
3,enter 60, press print,pess "'stop/clear" key
4,enter 73, press print, enter000000 press print
5, mode 1, enter 03 press print mode 2 & 3 all enter0 press print
Dec 12, 2008 | Office Equipment & Supplies
Mita cs-2114 copier with flashing "replace unit" light
after you see "---" within 2second press"stop/clear" again thenyouwill see"00" show out then enter 60 press print
Dec 09, 2008 | Office Equipment & Supplies
Error C63
That is the same as a Kyocera Mita DC 1470.
Error C63 is a fuser related error:
Broken fixing unit thermistor wire
• The fixing unit thermistor output voltage does not exceed 0.039 V DC within 7 s after fixing control has started with the fixing temperature remaining below 100°C/212°F (fixing unit thermistor output voltage: 1.71 V DC).
I can provide for you a full service and parts manual from Mita in PDF form for a nominal fee. Contact me for more info here.
Jan 07, 2008 | Copystar CS-2114 Copier
Copystar CS-2114 Copier Logo
125 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Adorjani Laszlo
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
