Question about Lenovo IdeaPad Z560 Notebook
How to chkdsk without starting windows - Lenovo IdeaPad Z560 Notebook
How to activate auto chkdsk after improper shutdown
To do that:
1. Click Start button
2. Click Run
3. Type CMD
4. Type "chkdsk/ f" at the command prompt
CHKDSK Starts when Windows restarts from an improper shutdown.
Chkdsk is part of Windows - it is a utility to analyse and fix HD errors.
Hope this helps!!! Let me know if you need more help
-Nadeem
Dec 25, 2012 | Computers & Internet
Disk fragment
You need to run chkdsk...
How to run Chkdsk
Notes
Chkdsk requires exclusive access to a volume when it runs. Therefore, if one or more of the files are open on the disk that you want to check, Chkdsk displays a prompt asking if you want schedule the disk check for the next time that you restart your computer.
Chkdsk might take a long time to run, depending on the number of files and folders, the size of the volume, disk performance, and available system resources, such as processor and memory.
Chkdsk might not accurately report information in read-only mode.
How to run Chkdsk at the command prompt
Click Start, and then click Run.
In Open, type cmd, and then press ENTER.
Use one of the following procedures:
To run Chkdsk in read-only mode, at the command prompt, type chkdsk, and then press ENTER.
To repair errors without scanning the volume for bad sectors, at the command prompt, type chkdsk volume:/f, and then press ENTER.
Note If one or more of the files on the hard disk are open, you will receive the following message:
Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)
Type Y, and then press ENTER to schedule the disk check, and then restart your computer to start the disk check.
To repair errors, locate bad sectors, and recover readable information, at the command prompt, type chkdsk volume:/r, and then press ENTER.
How to run Chkdsk from My Computer or from Windows Explorer
Double-click My Computer, and then right-click the hard disk that you want to check.
Click Properties, and then click Tools.
Under Error-checking, click Check Now. A dialog box that shows the Check disk options is displayed,
To run Chkdsk in read-only mode, click Start.
To repair errors without scanning the volume for bad sectors, select the Automatically fix file system errors check box, and then click Start.
To repair errors, locate bad sectors, and recover readable information, select the Scan for and attempt recovery of bad sectors check box, and then click Start.
The disk check could not be performed because the disk check utility needs exclusive access to some Windows files on the disk. These files can be accessed by restarting Windows. Do you want to schedule the disk check to occur the next time you restart the computer?
Click Yes to schedule the disk check, and then restart your computer to start the disk check.
The following table lists the exit codes that Chkdsk reports after it has finished:
Exit code Description
0 No errors were found.
1 Errors were found and fixed.
2 Disk cleanup, such as garbage collection, was performed, or cleanup was not performed because /f was not specified.
3 Could not check the disk, errors could not be fixed, or errors were not fixed because /f was not specified.
Aug 19, 2012 | Computers & Internet
Bad sector issue
How to run Chkdsk
Notes
Jun 30, 2012 | Western Digital Caviar Computers &...
Windows can't recognize
You need to run chkdsk......
How to run Chkdsk
Notes
Dos command promt in windows 7 in order to do chkdsk
You can click on the start button and just type "cmd" into the search box (without quotes).
You can also find it in the start menu under "all programs" then in "accessories."
Sep 12, 2011 | Dell Inspiron 530s Desktop Computer
Hello my acer laptop is giving a message disk error hit alt ctr del for start up i do that but the screen stays black with a with small white blink - in the left hand upper corner
How to run Chkdsk loadTOCNode(2, 'moreinformation'); Notes
  • Chkdsk requires exclusive access to a volume when it runs. Therefore, if one or more of the files are open on the disk that you want to check, Chkdsk displays a prompt asking if you want schedule the disk check for the next time that you restart your computer.
  • Chkdsk might take a long time to run, depending on the number of files and folders, the size of the volume, disk performance, and available system resources, such as processor and memory.
  • Chkdsk might not accurately report information in read-only mode.
How to run Chkdsk at the command prompt loadTOCNode(3, 'moreinformation');
  1. Click Start, and then click Run.
  2. In Open, type cmd, and then press ENTER.
  3. Use one of the following procedures:
    • To run Chkdsk in read-only mode, at the command prompt, type chkdsk, and then press ENTER.
    • To repair errors without scanning the volume for bad sectors, at the command prompt, type chkdsk volume:/f, and then press ENTER.
      Note If one or more of the files on the hard disk are open, you will receive the following message: Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)Type Y, and then press ENTER to schedule the disk check, and then restart your computer to start the disk check.
    • To repair errors, locate bad sectors, and recover readable information, at the command prompt, type chkdsk volume:/r, and then press ENTER.
How to run Chkdsk from My Computer or from Windows Explorer loadTOCNode(3, 'moreinformation');
  1. Double-click My Computer, and then right-click the hard disk that you want to check.
  2. Click Properties, and then click Tools.
  3. Under Error-checking, click Check Now. A dialog box that shows the Check disk options is displayed,
  4. Use one of the following procedures:
    • To run Chkdsk in read-only mode, click Start.
    • To repair errors without scanning the volume for bad sectors, select the Automatically fix file system errors check box, and then click Start.
    • To repair errors, locate bad sectors, and recover readable information, select the Scan for and attempt recovery of bad sectors check box, and then click Start.
    Note If one or more of the files on the hard disk are open, you will receive the following message: The disk check could not be performed because the disk check utility needs exclusive access to some Windows files on the disk. These files can be accessed by restarting Windows. Do you want to schedule the disk check to occur the next time you restart the computer?Click Yes to schedule the disk check, and then restart your computer to start the disk check.
Collapse this tableExpand this table Exit code Description 0 No errors were found. 1 Errors were found and fixed. 2 Disk cleanup, such as garbage collection, was performed, or cleanup was not performed because /f was not specified. 3 Could not check the disk, errors could not be fixed, or errors were not fixed because /f was not specified.
courtesy of Microsoft.com
Oct 14, 2010 | Acer Aspire 5315 Notebook
Bsod
if your having a blue screen error. Try to load your operating system CD and perform a CHK DSK by repeatedly press F8 on the pc, then boot to safe mode with command prompt..
Then perform this steps manually:
Manual steps to run Chkdsk at the command prompt loadTOCNode(3, 'moreinformation');
  1. Click Start, and then Run.
Hope this helps...
May 08, 2010 | Microsoft Windows XP Professional With...
When installing the computer back to its original settings. The systems will freeze when it gets to the point of checking the mouse. But in the beginning of the process the mouse is fine. I was told that...
Sounds like a virus. You might have to erase your hard drive and reinstall windows. If you have a boot disk that came with your computer, it will reinstall the entire system as it was when you bought it. You will need to save any files you want to keep first on a separate drive or burn to CD before you do it though.
Another option is to run check disk. Here is the instructions:
Manual steps to run Chkdsk loadTOCNode(2, 'moreinformation'); Notes
      Note If one or more of the files on the hard disk are open, you will receive the following message: Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N) Type Y, and then press ENTER to schedule the disk check, and then restart your computer to start the disk check.
Manual steps to run Chkdsk from My Computer or Windows Explorer loadTOCNode(3, 'moreinformation');
    Note If one or more of the files on the hard disk are open, you will receive the following message: The disk check could not be performed because the disk check utility needs exclusive access to some Windows files on the disk. These files can be accessed by restarting Windows. Do you want to schedule the disk check to occur the next time you restart the computer? Click Yes to schedule the disk check, and then restart your computer to start the disk check.
For more information about Chkdsk, visit the following Microsoft Web sites: For more information about Chkdsk, click the following article number to view the article in the Microsoft Knowledge Base: 314835 (http://support.microsoft.com/kb/314835/ ) An explanation of the new /C and /I switches that are available to use with Chkdsk.exe For help with common system maintenance tasks in Windows Vista, visit the following Microsoft Web page: Fix problems with common system maintenance tasks (http://support.microsoft.com/gp/system_maintenance_for_windows)
Dec 07, 2009 | Gateway Computers & Internet
Please run Chkdsk utility
open run type cmd type chkdsk c:
Oct 08, 2009 | Google Chrome
I have used 2 different sd cards in my Pentax Optio T10 and both have become corrupt and I cannot view the images
If you have a card reader on your computer, insert the card, take note of the drive letter windows gives your card, then go to:
Start > Run > type "cmd" without the quotes, hit enter.
When the command window comes up, type "chkdsk y: /f" without quotes, and replace 'y' with your card's drive letter.
If you have windows Vista, check out this article
http://www.winvistatips.com/vista-chkdsk-a126028.php
Jul 02, 2008 | Pentax Cameras
Lenovo IdeaPad Z560 Notebook Logo
14 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
