Question about Frigidaire Kitchen Ranges
What does a fault code of F11 mean on a frigidaire stove?
F11 fault code
4 Suggested Answers
SOURCE: Beeping F11 error on Frigidaire
Hi im an appliance tech and i had the same problem its not the EOC other words control board its actually the speed bake swith its stuck in the on position that why you get a stock keypad error code either f1 or f11 replace that switch or disconnect it and im positive that this will solve it .
Posted on Apr 22, 2009
mgprice
  • 744 Answers
SOURCE: I have a professional series frigidaire stove and
Hi here is the meaning of the F30 error code. If you have any other questions please feel free to comment. Mike
F30
F31
Open probe connection.
Shorted Probe connection.
1. (F30 or F31) Check resistance at room temperature & compare to *RTD Sensor resistance chart. If resistance does not match the RTD chart replace RTD Sensor Probe. Check Sensor wiring harness between EOC & Sensor Probe connector.
2. (F30 or F31) Check resistance at room temperature, if less than 500 ohms, replace *RTD Sensor Probe. Check for shorted Sensor Probe harness between EOC & Probe connector.
Posted on Jan 16, 2010
Macmarkus
  • 2605 Answers
SOURCE: Meaning of fault code F13 on Frigidaire range
Hello, welcome to FixYa.
I understand you have the Frigidaire CFEF372ES1 range, correct ? I also understand based on your post you're getting the F13 error message, correct ?
This range is built by Frigidaire as you know and a
ccording to their service manual, here's what it is and what you can do
...I will also add, **Fault codes are not a foolproof system. Never assume that a part has failed based on a displayed fault code. **
...If you pull/slide the unit away from the wall and unplug it or turn the house breaker off for 30 seconds to a minute the control should reset. That should do it...unless the EOC (electronic oven control) has failed.
Let me know how you make out and if you need anything further I'll be glad to help in any manner I can. Good luck.
Regards,
Macmarkus :)
Posted on Oct 27, 2011
Frigidair range I would like to know what f11 means
Hello, Floyd -
Without knowing the model of your Frigidaire range, I cannot look for the owner's manual for your particular model and find what F11 (a fault code) means for your specific appliance.
However, I did find a web page listing fault codes for newer Frigidaire ranges. See the information here:
http://www.applianceaid.com/newer-frigidaire-fault-codes.php
From that information, the EOC (Electronic Oven Control) may need replacing.
Dec 22, 2017 | Kitchen Ranges
How do I fix beeping F11 error code on my frigidaire stove?
The F11 error code stands is a shorted keypad. I suggest performing a reset on your range and you can do that by flipping the household circuit breaker off for at least 5 minutes. If that does not work you may need to have a professional technician
Sep 28, 2016 | Frigidaire Stove/Oven/Range Black Glass...
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Had power outage & when electric company put new transformer on, stove came on with this error f11 error, when open oven door it mesg goes off & on, oven wont work now
    I appreciate your post, Katherine!
    Based off the information you have provided your Frigidaire range is displaying an "F11" error code after a power outage. An "F11" error code stands for a shorted keypad. I would suggest performing a reset on your range and you can do that by flipping the household circuit breaker off for at least ten minutes. If that does not work you may need to have a professional technician out to provide proper repairs. This will prevent you from any unnecessary part purchases. Hopefully this is helpful. -Matt
    May 02, 2015 | Frigidaire Stove/Oven/Range Cooktop -...
    After a power outage, what is causing my Frigidaire stove to beep and display an F11 code?
    Thank you for your inquiry, Katherine!
    Based off the information you have provided your Frigidaire range is displaying an error code of "F11". An "F11" error code stands for a shorted keypad I would recommend performing a reset on your range. You can do that by flipping off the household circuit breaker for at least ten minutes. If that does not correct your issue it could be a possible problem with your EOC (Electronic Oven Control) or wiring harness. Hopefully this information is helpful for you. -Matt
    Apr 23, 2015 | Frigidaire Kitchen Ranges
    I AM GETTING F1 ERROR CODE ON FRIDIGEAIRE MODEL #CFEF372CS2 SERIAL # NF41924422, ONLY OVEN NOT WORKING
    I am 99% positive you need a new EOC based on the fact that you said you heard the all too common pop noise. EOCs usually cost around $200-$300 and sometimes more. The EOC in this is the same as your clock, if you took off the top back you will see burn marks on the back of the clock.
    Jul 04, 2014 | Frigidaire PLEF398AC Electric Kitchen...
    F11 ault code. what does that mean?
    Hello Polly, this is Z. I am happy to assist you!
    If you are receiving an error code F11 on your Frigidaire range, it typically indicates that your range has detected an issue with the runaway temperature (overheating). One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, at this moment I would suggest connecting a professional to proceed further. Most likely the EOC (Electronic Oven Control) or RTD Probe (Resistance Temperature Detector) will need replacing. I hope this information helps to some degree.
    Mar 19, 2014 | Frigidaire Kitchen Ranges
    How to fix the F13 error in this stove
    F11, 12 & 13) Disconnect power, wait 30 seconds and reapply
    power. If fault returns upon power-up, replace EOC.
    Apr 15, 2010 | Frigidaire FEF336BC Electric Kitchen Range
    The stove gives an error code F11
    this is a shorted key pad code.you can unplug the range for a few minutes.then plug it back in if the fault returns you need to replace the EOC.
    Feb 08, 2010 | Frigidaire FEF336BC Electric Kitchen Range
    Could you tell me what F11 code means?
    F11 error code means there is a problem with the Control panel. Could be melted wiring, etc, since you left the oven standing. However, you can try unplugging the device from the power socket for about 5 minutes and reconnect. If the error goes away, then well and good; if not, you may have to replace the panel control.
    Oct 13, 2008 | Frigidaire Kitchen Ranges
    Kitchen Ranges Logo
    80 people viewed this question
    Top Frigidaire Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Paul Carew
    Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
