Question about Blackburn Atom SL 6.0
NO SPEED OR CADANCE INDICATIONS
NOT TRANSMITING
Can the speedometer being loose cause the car have shifting issues ...buick century 3.1
shifting is determined by the TCM unit that gets speed indications from the vehicle speed sensor (VSS) that also controls the speedo readings
at this point and from your question I would suggest that you determine the exact cause by taking it to an authorized transmission specialist shop for a proper diagnosis and quote
Sep 15, 2016 | Cars & Trucks
I have a 1996 jetta ao spedo meter i replaced the cluster and speed meter does the cluster need to be the exast year
EXACT PART NUMBER AND NEEDS TO BE CODED CORRECTLY OR U WILL GET FAULTY INDICATIONS AT THE SPEEDOMETER.....
Feb 27, 2015 | 1996 Volkswagen Jetta
Abs light, brake light staying on, and speed odemater not functioning until reaches 20 mph
The problem is the speed sensor in the rear differential housing. Replace it and all the indications will correct themselves.
Jan 31, 2014 | 1999 Dodge Dakota
What is 1X, 2X,4X,8, 16X WRITE SPEED
HI. These settings are indications of the rate of speed that the actual CD-ROM disk will spin at. The rotation speed can be adjusted to the lowest, which is 1X, and the highest, which can be up to 54X; Depending on your brand of CD_ROM drive. Adjusting the settings to a 16X or higher rate, will decrease the burn time.
  • NOTE_ A high spin rate speed will decrease burn time, but it will also increase the chance of a writing error, as well.
Aug 19, 2010 | Computers & Internet
An army contigent of 616members is to march behind an army band of 32 mebers inaparade.the two group are to march in the same number of columns. what is the maximum number of columns in which they can...
being in the millitary you cant form a formation more than 6 columns but we dont care about the extra straglers tagged to the end.
does this include squad leader? squad leader removes one person from each formation and they call out marching orders and cadance.
but for your question
the common factors of each number is
2,5,3 (32)
and
2,2,2,7,11 (616)
you take it from there.
Jun 11, 2010 | Mathsoft StudyWorks! Middle School Deluxe...
Wireless stops working
plug the drive into your computer or laptop directly and youll have more control over the files you transfer and more reliability plus youll be able to transfer files faster too with no interruptions either
the speed of transfer rate for ...
usb 2.0 is about 400mb/sec and
sata drives about 1.5gb/sec
safer that way incase your wireless fails again
or reset your wireless connection and test again
caution
dont forget to record all your settings before you do that otherwise youll have to ring your isp to assist with reconnecting to the internet again
Mar 28, 2010 | Arris SURFboard SBG900 Wireless Router...
Hello, We were watching a move and the TV just went black. The power button kept flashing and the picture did not return. Can you help?
It is a good chance you need a new bulb. Is there any cadance to the flashing like 1,3 flashes or 2,3 2 flashes. etc
Mar 22, 2010 | JVC HD-52G786 52" Rear Projection HDTV
Recently had a speed sensor replaced, now I need the cv joint replaced same spot. Coincidence or related?
Depending on where you took the truck to be serviced, they may have just repacked the wheel bearing and inspected the cv joint when they replaced the speed sensor, but if it was going bad already that would have to have been a major overlook. Unfortunately, if the boots on the cv joint are good and not cracked or loose, there are no other indications of a bad joint other than noise in the front end while driving. Are you sure the cv joint is bad? What are the indications you are having?
Jun 23, 2009 | 2000 Chevrolet Silverado 1500
Erronious speed indications(0 at 50mph, 30 at 70mph...)
look at the tail housing of the transmission.it's bolted in and 2wire connector.
May 26, 2009 | 1993 Chevrolet C1500
Blackburn Atom SL 6.0 Logo
81 people viewed this question
Top Blackburn Cycling Experts
Donald Ayers-Marsh
Paris Johnson
Paris Johnson
Level 1 Expert
Tafi Nami
Tafi Nami
Are you a Blackburn Cycling Expert? Answer questions, earn points and help others
