Question about Sunbeam Irons
Sunbeam repair manual
How to
How do I put water in the Sunbeam Steam Iron #GCSBBV-200
If the GCSBBV-200 is similar to other Sunbeam steam irons, fill the iron when it is cool and unplugged. With the ironing surface flat on the sole plate, set the Steam dial to dry and the Fabric Select dial to Min. Then use an easy-pour measuring cup to pour water into the opening at the top front of the iron. Make sure not to fill past the maximum fill level. (Tip the iron up as if you were resting it between passes with the iron to check the level.)
I hope this helps.
(Sunbeam has the manual for the GCSBBC-395 on their support site: http://www.sunbeam.com/service-and-support/product-support/instruction-manuals/garment-care/other/garment-care-other-manual.html . The direct link to the manual is http://demandware.edgesuite.net/aamb_prd/on/demandware.static/Sites-sunbeam-Site/Sites-sunbeam-Library/default/v1425126445413/documents/instruction-manuals/160253.PDF . Check how similar your iron is to the newer models.)
Mar 01, 2015 | Sunbeam Irons
How do I use the self cleaning on my sunbeam iron
You can download manual from www.manualslib.com.
Oct 19, 2014 | Sunbeam Irons
Smartek SB1800 - Sunbeam Compact Sewing Machine manual
I have a manual, but I'm not real good with making PDF files. I can scan this manual, for anyone who needs one, I can send a couple of Word files that you can print out. Sunbeam SB1800
Dec 28, 2012 | Smartek SB1800 - Sunbeam Compact Sewing...
Dropped the iron and stopped working...over? repair?
This must be included in the manual. For the manual ask here, they can get you virtually any Sunbeam manual.
Jun 28, 2009 | Sunbeam Heritage 4264 Iron with Auto...
Irons Logo
35 people viewed this question
Top Sunbeam Irons Experts
Tony
Wayne Fellows
Wayne Fellows
Craig Butler
Craig Butler
Are you a Sunbeam Iron Expert? Answer questions, earn points and help others
