Question about Optoma EP721 Projector
Reset security code
I have lost my code to an EWS 762. How do I factory reset the projector?Thanks
I lost my security password how to recover
You have to reset the phone to factory defaults by using a flash box like Z3X.
Nov 21, 2014 | Cell Phones
How to reset to factory default settings on projector sony VPL-DX126
here's the user manual of the prjector:
https://docs.sony.com/release/VPL-DX126_DX146_DW126.pdf
i've readed it and i guess you should push the reset bottom in the remote.
Nov 21, 2014 | Sony Office Equipment & Supplies
Error code 2f44 bmw won't start tried to clear but comes back after every crank
Fault code: 2F44 EWS preventing manipulation.
This is a common fault code flagged by BMW vehicles when the EWS (also known as the CAS module or immobilizer) no longer communicates with the DME.
Some of the most common causes, for this condition, is battery failure or ignition key failure.
Many times, a customer will bring a BMW into the shop or have it towed into the shop, and explain that "the car just won't start, suddenly". Upon further investigation, it is common for a technician to find poor battery condition or a failed ignition key.
In the case of poor (low) battery condition. A low voltage level has caused the immobilizer (CAS/ EWS) to lose its alignment with the DME.
In the case of a failed key, the immobilizer (CAS/EWS) cannot "see" the key in the ignition and therefore will not allow the vehicle to start. This is the "no crank" part of this fault.
So where do we start?
Using a factory level scanner, connect to the vehicle. After identifying the vehicle, proceed to the immobilizer module (CAS/EWS) and investigate if the key can be identified. If the key in the ignition slot cannot be identified and the key slot/ receiver is functioning correctly, then the key must be replaced. Typically, at this point, the first thing we want to do is ask the customer if another valid key is available. If so, let's try this first! If not available, a NEW key FROM THE DEALER, must be purchased.
NOTE: Aftermarket keys will not work i.e. E bay etc. The keys for these cars are VIN specific and need to be supplied by the dealer only!
A new key will work "right out of the box" from a dealer. Simply put it in the ignition, allow the vehicle to identify it (give it about ten seconds) and try a startup.
After replacing the key and regaining key identification the immobilizer (CAS/EWS) must be aligned with the DME.
Using a factory level scanner, perform the DME to CAS/EWS immobilizer alignment procedure. Clear fault code(s).
So, what about the battery?
All the above information is based on having strong battery voltage. In regards to BMW vehicles, 11.0 volts is NOT good voltage. These vehicles are designed to operate in the 12.4 to 13.0 (average) voltage area.
Before attempting to start the engine, a technician should perform a battery load test. When working with BMW vehicles, if the battery is marginal or too old (more than three years old) replace it.
NOTE: New batteries for later model BMWs (CIP vehicles from approx. 2004) will need to be registered. With a dealer level scanner, a tech can perform this function.
Note: As time passes BMW will change the way immobilizers are aligned. Typically, this happens when BMW changes manufacturers. If performing a standard CAS /DME alignment does not work, A later procedure is available. With late model (EWS 3 type onward) immobilizers, the tech must perform a three-step procedure. Using a dealer level scanner, carry out 1) CAS reset, 2)steering lock counter reset 3) reset the starter interlock.
May 04, 2014 | Cars & Trucks
How do you reset an LG Rumor 2?
Hey buddy,
For soft reset, simply switch off your phone. Take off the battery from your phone for a couple of minutes, then put it back in and slide up the back cover.
Follow the instructions below to hard reset your cell phone.
Menu button > go to settings/tools > settings > More > go to security.
Enter your security code > select Reset/Erase > then reset > Press OK.
If you do not know your security code, press 0000 or contact your network service provider. You can alternativley get the code from this web site -
http://www.unlock-zone.com
http://www.mobileunlockguide.com/mobile-phone
Let me know if this helps. Thanks!
Dec 09, 2010 | LG RUMOR Cellular Phone
Acer projector P3150 locked with passwd
Read some Acer manual and it says:
Administrator Password
The "Administrator Password" can be used in both the "Enter
Administrator Password" and "Enter Password" dialog boxes.
• Press "Play" to change the "Administrator Password".
• The factory default of "Administrator Password" is "1234".
If you forgot your administrator password, do the following to
retrieve the administrator password:
• An unique 6-digit "Universal Password" which is printed on
the Security Card (please check accessory in the box). This
unique password is the number which will be accepted by
projector anytime no matter what the Administrator
Password is.
• If losing this security card and number, please contact with an
Acer service center.
Jan 28, 2010 | Acer P3250 DLP Projector
Nokia 1200 reset my security code
my imei 352903024024357 plz help me reset my security code tnks
Dec 17, 2008 | Nokia 1100
Lost password Benq MP610
Hi, i have a problem with MP610 i lost password and i can give you the code num 21600 15444 7626 10061
Please send to : tnhhue@yahoo.com thanks
Jun 07, 2008 | BenQ MP610 Multimedia Projector
Decode
i lost my password
my code is: 21344 13898 6789 8507
May 20, 2008 | BenQ MP610 Multimedia Projector
Color difficulties
Have you tried using the video inputs, Is it able to show red then ?
If not & you have reset the factory settings the prisim or mirror's may have gotten out of alignment in shipping, Or it may have a bad lcd panel or the red lcd may have a bad connection or driver circuit.
Feb 13, 2008 | Office Equipment & Supplies
Optoma EP721 Projector Logo
37 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
