Question about Brighton Professional LTX-12 Hand Soap Dispenser; Touch Free, 1200ml,
Brighton Professional LTX-12 Hand Soap Dispenser refill
How do I open the dispenser to put in a new refill?
Your web site is useless
Why do you say that?
If you have trouble with your dispenser, then contact manufacturer's website!
Good luck.
Jun 10, 2014 | Brighton Professional Touch-Free Foam Soap...
How do I open the soap dispensor for the Brighton Proffesional hands free?
pull it open from the top... squeeze the top sides of the lighter part and pull it down like a drawbridge. If they installed it correctly, it wont rip off the wall.
May 27, 2014 | GoJo GO-JO INDUSTRIES NXT Lotion Soap...
How do you open brighton professional hand soap dispenser to refill
OUR BRIGHTON TOUCH FREE BLACK 700 ML HAND SOAP DISPENSER WILL NOT DISPENSE THE SOAP
Aug 14, 2013 | Brighton Professional LTX-12 Hand Soap...
Our 2 soap dispensers have stopped working. They have new batteries in them and full soap refills. Help
You might try taking out the batteries and wiping the area dry. It may be that the batteries are not getting a dry connection. Also, make sure the batteries are replaced correctly. There is usually a diagram with the battery placement on the lid where the batteries are installed. Also, sometimes the soap dispenser can get clogged. In that case, make sure to take the batteries out and then run hot water thru the area where the soap comes out. Hope this helps out.
Feb 23, 2011 | GoJo Purell 2720-12: TFX ? Touch Free...
How do I open the dispenser?
how do you open the provon soap dispenser so that you are able to refill the soap. We cannot open the dispenser. What is the trick?????
Jan 14, 2011 | SP Richards Go-Jo Provon FMX-12 Foam Soap...
When I refill the dispenser the Purell pours out and dose not stop. It isn't even foaming up.
when you put soap in do not cut tip or poke hole inbag just slide plastic tip in holder and close should work hope this helps
Sep 21, 2010 | GoJo Purell 2720-12: TFX ? Touch Free...
How do you open the soap dispenser
We have this Gojo soap dispenser and can't figure out how to open it to refill it. there are no directions on the refill package and no obvious release buttons to press. Help?
Dec 10, 2009 | GoJo GO-JO INDUSTRIES NXT Lotion Soap...
Brighton Professional LTX-12 Hand Soap Dispenser; Touch Free, 1200ml, Logo
161 people viewed this question
Top Brighton Professional Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Brighton Professional Health and Beauty Expert? Answer questions, earn points and help others
