Question about Dell Inspiron 1501 PC Notebook
I have a Dell Studio laptop. Will power on with
I have a Dell Studio laptop. Will power on with either AC adaptor or battery, but will not boot with just battery. Dell advised hard drive problems and reinstallation of Vista system, this seems drastic as boots and works just fine when AC adaptor is plugged in. I could just keep using plugged in,my life is not that active, but it seems a shame not having it work to optimum.
  • 585 Answers
This should have a "battery check" button on the battery itself. Remove the battery and press the button. If it reveals that the battery is not fully charged, or you cannot get it to take full charge, perhaps all that you need is a new battery. If the battery is failing the check the system makes on it at boot, it won't.
Posted on Jun 14, 2009
Batery won't charge new battery n plug
You may have the wrong AC adaptor, Dell is very picky when it comes to Power adaptors, it must be original OEM Dell for the laptop to recognize it, any after market no name brand even though it has the right specs and is made for your model will power your laptop but the circuit to charge your battery will automatically be closed
Nov 17, 2012 | Dell Studio 1737 Laptop
I working on my sister Dell Studio laptop. Her son got a hold of it and pressed the power button several times while pressing several buttons. Now the laptop does not boot correctly. I power it up and the...
Remove battery and AC power, press power button for 30 seconds. reconnect ac power and try again.
Also check the hot keys (brightness) usually Fn and F6, see if that help
Dec 29, 2010 | Dell Studio 15 Laptop
DELL 1525 laptop boot issue. When switching ON it shows only blank screen. Grateful if you could help resolve this issue
Have you got an external screen you can plug in to prove the video? Try this check list:
Dead Laptop.
Try firstly removing the laptop's battery as it may be at a critical voltage and the system will not start because of it. Plug in your ac adaptor and monitor what happens. Does the power light illuminate? If it does it should then boot up, if it doesn't, try a known good ac adaptor before going any further.
If the adaptor is fine then you have a mother board fault and should contact a dealer/repairer for further advice.
Hope this helps.
Nov 09, 2010 | Dell Inspiron 1525 Notebook
My studio 15 laptop isn't turning on, so I'm using my sister's laptop to try to find a way to turn it on but nothing is turning on at all!
Try firstly removing the laptop's battery as it may be at a critical voltage and the system will not start because of it. Plug in your ac adapror and monitor what happens. Does the power light illuminate? If it does it should then boot up, if it doesn't, try a known good ac adaptor before going any further.
Hope this helps.
Nov 04, 2010 | Dell Studio 15 Laptop
My Acer Aspire 9805 battery was replaced. For
It could be an AC adaptor issue.
It should boot when connected directly to the power outlet through the laptop adaptor. If it is not boot, then the adaptor might not be supplying the needed power to boot it up.
If it is possible, try to isolate the issue. Charge your new battery using another laptop. Then plug it in your laptop to see if it works. If it will work, then it is the AC adaptor of your laptop that is defective. If the charged battery still won't make the laptop boot, then there is something wrong with your laptop hardware. If could be a motherboard issue of your laptop.
Feb 23, 2010 | Acer Aspire 9805WKHi Notebook
Post Boot message for my Dell Inspiron 1521 laptop. Message: The AC power adapter wattage and type cannot be determind. Please connect a Dell 65W AC adapter or greater for best system performance. To...
When you received the system as out of the box and you get this message "The AC power adapter wattage and type cannot be determind" let the Dell tech service know that they sent you a wrong or incorrect type of AC Adapter.
If this message not was not appearing before it just happened recently try to download and install the latest BIOS version from the support site.
If all fails remove the batt and check if laptop can work with AC adapter alone, because issues like AC not determine may not charge the battery and laptop may not work with AC as well, maybe laptop is already running on battery power.
Nov 11, 2009 | Dell Inspiron 1521 Laptop
Keeps powering on and off.
Keep in mind since you cleaned it out, only have the AC adaptor hooked up to rule the battery out. If the laptop stays on with only the ac adaptor hooked up and doesn't shut off then you know that the battery is faulty. If it still shuts off even with just the ac adaptor hooked up then it could be the ac adaptor.
Also check one more thing, with only the ac adaptor hooked up, wiggle the cord where it plugs into the laptop and see if the laptop shuts off, if it does then the dc jack on the motherboard is loose and needs to be resoldered back into place so it stays put.
May 13, 2009 | Dell Computers & Internet
I have a Dell D600 (PP05L), its not powering up no lights. I noticed on the power adapter the green light goes out when plugged into ac power. What could be wrong here? please help
Hook up your power adaptor to ac power without it being hooked up to the laptop and see if the green light stays on. If it does then you know your adaptor is okay. if your adaptor is only hooked up to ac power and the green light still turns off then you know your ac adaptor is bad.
Take out the battery from your laptop. Now hook up the ac adaptor to the laptop and if it stays green then you know your battery is bad but you also want to make sure you can get your laptop to turn on. Hopefully it will turn on with only the ac adaptor hooked up to it.
May 04, 2009 | Dell Latitude D600 Notebook
Dell inspiron 6400 system responding very slow on ac adaptor
FIRST REPLACE YOUR BATTERY, THEN ALSO CHECK VIRUS WITH AN UPDATED VIRUS CLEANER.
Nov 20, 2008 | Dell Inspiron 6400 Notebook
Dell Inspiron 1501  PC Notebook Logo
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
