Question about Cz Usa CZ 04101 CZ550 AMERICAN 6.5X55
Extractor claw does not hold the ammo
Spent casing is not ejected when working the bolt
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 243 Answers
It sounds like it's not seated in the bolt properly or the lip is broken off. (I've not seen a broken 98-type extractor in 50 years.) Pictures?
Posted on Aug 21, 2014
Why doesn't rifle eject shells?
Extractor claw spring or claw worn out of tolerance
Shell expanded to much in chamber and sticking
Chamber throat worn and neck of case moulding to lock in case to the chamber
Jan 18, 2016 | Optics
Mossberg 817 magazine
Not much can go wrong. Have you checked your extractor? If it's intact and not broken, try moving it with your thumbnail. Is it loose? That's a spring problem. If it's tight and intact, WITH THE BOLT OUT, try slipping a small diam wooden dowel down the barrel to see how hard it is to push a spent shell out. If it's tight, you've got a burr in the chamber or dirt/varnish buildup. Examine the shell for scratches. If the shell's good and no scratches, clean the chamber with a brass brush mounted in a drill.
Apr 21, 2014 | Mossberg Optics
22 semi auto rifle jamming
Often with semi-automatic rim fire rifles, the most common cause of jams/failures to feed are related to improper cleaning. Most of these low-powered rifles utilize a blowback action to fire, and thus require a clean breech and chamber to provide proper obturation of the cartridge. Give your rifle a thorough cleaning, including a detail strip and clean. If you are experiencing other types of stoppages such as failures to extract or failure to feed, you may be experiencing a mechanical issue such as a worn extractor claw, or a weak magazine follower spring.
Feb 28, 2014 | Marlin Model 60 .22 Cal Rifle
Shell does not eject slide jams..I pull clip, pull slide back a couple times , shell ejects what is my problem
Hi! Kevin.....bit hard to know !....assuming ammo is correct dimensionally & of good power., & extractor & ejector are in order & chamber is good & slide is free & full sliding......then my first guess would be sticky firing pin not retracting properly thus stymying ejector action.......any stickier & you might get full auto ?......are you puncturing primers ?.. if gas back escape is part of the picture , bullet may not leave barrel . I suggest you do full strip , incl firing pin , clean & remove any burrs ..... worthwhile to run some dummies by hand & see how they behave..........jimbanjo
Jan 16, 2014 | Smith & Wesson SWW-357-R
Pump shotgun not ejecting a spent shell
Sounds like your extractor is broken.
Apr 07, 2013 | Optics
After 1st is fired it seems to not eject the empty casing or next round misfires. Several times it will misfire. I'm using Federal Long Rifle, High Velocity, 36 Grain Hollow Points. My email address is...
First, listing a gun problem in the Toys section is kinda confusing. 36 grain, so i assume .22 caliber. Is this by chance a P22 or P99?
Next: ejecting vs extracting. Extracting is the act of the spent brass being pulled from the chamber as the slide moves backwards. Ejecting is when the spent casing is thrown from the gun, leaving a clear path for the next round to slide into the chamber.
The most common problems with .22 pistols is that they are dirty. Hands down, and I know this from working at a range. Strip that gun down, and clean the hell out of it. If you're not comfortable, have a gunsmith do it for you. Next, check for burrs (rough edges of metal) on the extractor. Also check for burrs or rough spots on the feeding ramp into the chamber.
If everything looks good, try different ammo. I've seen all different types of ammo fired through different weapons systems, some worked and some didn't. Wolf ammo hates American rifles, its just true. .22 LR is cheap, buy a few boxes of different brands, and see what your weapon likes to fire.
If this is still giving you problems, let me know, and i'll walk you through it step by step
Mar 29, 2011 | Walthers Toys
Why does my Sks rifle not eject shells properly?
check for fouling in the extractor claw clean it and the chamber and gas port
Nov 08, 2009 | SKS Uag Sks Rifle Hi-profile "see-thru"...
Sks jams,using wolf ammo
Wolf is a cheap ammo you dont pay much but you dont get quality ammo either. Make sure your gun is clean and the extractor spring isnt worn thats about all you can do in this situation.
Jun 12, 2009 | SKS Rifle High-profile See-thru Scope...
Cz Usa CZ 04101 CZ550 AMERICAN 6.5X55 Logo
49 people viewed this question
Top Cz Usa Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Cz Usa Optic Expert? Answer questions, earn points and help others
