Question about Lorex Home Security
Screen upside down
Switched and trouble stayed with camera
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 133 Answers
Try to connect using VGA connection or HDMI
Posted on Apr 25, 2016
My samsung galaxy tablet camera is appearing upside down
Scroll dowm from the top left corner, and you will get the option to rotate screen.
Dec 21, 2013 | Cameras
I got cryptic answer regarding the problem that the picture on the monitor on my camcroder GZ-HM400 is upside down.
There is a switch within the camera that controls the orientation of the LCD image. When the screen is flipped upside down, the switch is supposed to tell the camera to flip the image upside down as well. If this switch is damaged, the camcorder gets the wrong signal and the image will be displayed upside down. This can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Oct 25, 2010 | JVC Video Cameras
The image is flipped upside down and won't go back I think the camera might have been dropped
THIS IS A REPAIR SHOP TASK
normally there is a micro switch fixed at the awivl head of the lcd panel. when the lcd is rotated to 180 the switch gets engaged thus turns the image upside down. iF IT IS PERMANENTLY UPSIDE DOWN yhen most probably the switch has worn out.and its not resetting.
You could try a few gentle taps to see if it releases the micro switch
Please rate my help++++Thanks for using FIXYA
Nov 20, 2009 | JVC Everio GZ-MG130 Camcorder
Lens Error!
In My case, the lens was coming out part way a start up and pulling back in without camera coming on. Some times the screen would stay a dark blue and could not be shut off. Ensure batteries are new or remove and replace existing. Lens will come out part way and retract when the battery door is opoened and closed. Press "on" button and as the lens comes out touch and hold the lens, with a finger placing pressure on the side of the lens. The lens will stay out. With camera upside down blow into the sliding mechanisms of the lens. Grip the furthest most extened lens with two fingers and pull the lens all the way out with steading pressure. The pressure should be equivalent to lifting one to two pounds of bread with two fingers. Perform this with the camera upside down so that any dirt particles can fall out. A slight rocking (side to side motion) of the lens may help. Once fully extended, open and close the battery door. The lens should retract. Turn on the camera. A couple of ideas relatd to this problem 1) If the concentric circles of the lens are not even, this could indicate a large grain of sand. After lens is extended or partialy extended push the lens on the side where the largest gap is while the camera is upside down. This may provide a larger gap for the grain to fall out. 2) Dirty camera case. I turned my camera case upside down over a piece of white paper and was amazed at the particles of sand that fell out. I turned the case inside out and completely brushed and vacuumed the case.
Jul 13, 2009 | Nikon COOLPIX P60 Digital Camera
Image on flip screen upsdie down
There is a vertical position switch on these models. Probably needs to be replaced.
Jun 13, 2008 | Canon PowerShot A610 Digital Camera
Picture is upside down and backwards
I have the same problem. How and where does this come from? My camera was sitting in the dock when I noticed the problem!!
Nov 26, 2007 | Kodak EasyShare C315 Digital Camera
Sony handycam dcr-sr40 lcd display
flip switch is not working or stucked, a loose wire connected to this switch is also possible. you may open the unit and check for it. a pro fix is better.
Nov 06, 2007 | Sony Handycam DCR-SR40 Camcorder
Upside down screen....
1. please do restora factory settings, the default code is 12345.
2. if u r unable to do that then go to nokia care and flash ur handset.
Aug 16, 2007 | Nokia 7373 Cellular Phone
Home Security Logo
50 people viewed this question
Top Lorex Home Security Experts
Lawrence Oravetz
gbob59
Are you a Lorex Home Security Expert? Answer questions, earn points and help others
