Question about Canon IR2535 Copy Machine
How to send scan files from canon ir2535 to computer
Scan settings ir2535 canon
4 Suggested Answers
  • 59 Answers
SOURCE: Canon imageRunner set up e-mail
This will be possible if there's a Send button ont he top line of the screen.
You should set up an email account on your emailserver. On the copier, as well as the Ipaddress, subnet and gateway addresses, set up the DNS server adress. Also in the network section on page 3/3 enter the email smtp server details.
This should now work after a reboot.
Please note I have found that within schools security can be tight so the system may be set to only send email from a computer. First port of call is the it dept.
Good luck
Posted on Sep 10, 2009
Testimonial: "thanks"
  • 78 Answers
SOURCE: scanning problems with canon imagerunner 5020i
if you are using the i send function check smtp server settings
scan to email etc.
if you are using old fashioned pull scanning check your network scangear setup
Posted on Sep 12, 2009
  • 552 Answers
SOURCE: canon ir2535 e00020 repair
Dear in most cases if toner refilled (or the life of the hopper assy.)the worm gear of the hopper assy. worn out. so the sensor at developing assy.detect no toner flowing to the developer from the hopper assy. where as the hopper assy. sensor detects toner. check the sensor, If you have knowledge enough to dis-assembly the the hopper assy. check the worm gear connected to a small motor driving toner gear. clean the sensor( may toner got inside the windows of sensor, clean it). check the harness, check the DC_CON pcb. Note if no experience donot open hopper assy. take assistance of trained engineer. Thanks.
Posted on Feb 21, 2015
My canon image runner can photocopy but can not print from the network or usb cable,it only gives a beep sound when i send a command.How do i resolve this promblem
If you are using a pcl driver please download the ufr driver for your machine as sometimes you need a pcl kit loaded for a pcl driver google canon drivers for your machine and try the ufr im sure it will work
Apr 28, 2014 | Canon IR2535 Copy Machine
How to solve Ir2535 copier E000002 error codes
canon ir 2535 Error E000003 How to removed
May 07, 2013 | Canon IR2535 Copy Machine
Setting up scan to e-mail on a new Canon imageRUNNER Advance 6065 printer. Have a Google e-mail server
communication setting
TX setting
2nd page
Edit standard Send setting
standard settings
store
file format: PDF
done (do not intialize)
Apr 27, 2012 | Canon Office Equipment & Supplies
Canon ir2535 error printing job aborted
i have a error e000020 in cannon ir2535. please solve my this problem. please..................
May 20, 2011 | Canon Office Equipment & Supplies
Need help to setup the scan fuction for Canon Image runner 4570
Do you have the send feature or just scan? If just scan you need to install scan gear to the computer you want to scan to and configure scanner, than can pull scan fro canon to any viewer installed on your computer. If you have the send feature, make a folder on the c drive of the computer , share the folder with all permissions. Touch send on screen, reg. new address, touch file, arrow down to smb file, browser button to see your network, highlight your network, touch down highlight your computer name, enter user name and password as shown, log in to your computer from canon and highlight the shared folder and hit ok. you should now be able to send to that shared folder
Oct 24, 2009 | Canon Office Equipment & Supplies
Scanning problems with canon imagerunner 5020i
scan to email etc.
May 20, 2009 | Canon imageRUNNER 5020i Copier
Setting PDF as default scan setting on Canon Imagerunner 3035
Additional Functions (hardware button on the panel)
Communication Settings
TX Settings
Scroll down to 2nd page
Edit Standard Send Settings
File Format: PDF
Scanning Mode: Black 300dpi
Mar 06, 2009 | Xerox CopyCentre C123 Copier
Scanning from a canon 3220
Yes, the type of scanning mentioned by the previous answer is called 'pull scanning' and you will have limited functionality. You have to load the document on the copier, turn on the scanner (nobody can use the machine now) return to your desk which I hope is not far from the copier because the doc stays there until you 'insert picture from scanner' then the machine scans the document and you run back to the copier to get it before someone throws it in the trash! It's a free system but limited. To have a fully functioning 'push scanner' where you send a doc as you stand at the copier to either a file on your computer, server or an email address you would need a universal send kit installed. If your machine has one you'l see the option tab called 'SEND' along the top of your screen. If you have this you're in luck. All you need is to enter the necessary network and email settings which can be done by any half decent network administrator vis the 'system settings' area from the addtional functions screen (accessed by pressing the head key with a star in it). Once this is set up merely select the 'SEND' tab and insert your document. In the top right hand corner will be a drop down menu reading either 'FILE' 'EMAIL' or 'FTP' If you want to send it to a shared folder on your network (anywhere) you select the 'FILE' option and then use the drop down menu in the centre of the screen to search the network for your shared folder. Select it and then press ok then the start key - IT'S GONE - IF YOU'RE LUCKY. To send to email you just select the 'EMAIL' option and enter the email address of the recipient and ok then start and you're in business provided that all the network and email settings are correctly entered and permissions for network access is set up. The machine needs a email account registered for it as well. I'm tired now - good luck.
Feb 17, 2009 | Canon imageRUNNER C3220 Color Copier
Scanning
joslloyd universal send is not available on the 3300 but it is on the 3300i.
You link to an old version of scangear software. Use http://downloads.canon.com/cpr/software/devicemanagement/NWSG_v2.21.exe
On the 3300 press System/Options button, One of four buttons far right, next to copy, fax, mailbox.
Press Online.
Read the manual included with ScanGear for how to set it up. Or ask if you are having difficulties.
Aug 27, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Canon IR2535 Copy Machine Logo
81 people viewed this question
old marine
old marine
