Question about Lands Phones
Ac adapter for phone
I want a ac adapter
I gave 240 volt to my 120 volt uniden cordless phone. Smoke came out and obviously it is not working now. How bad I messed up? Any repair work can fix this? What needs to b replaced
Most phone systems use the same AC adapter (wall block) for the base as they use for the remote charging bases. You may have just fried the base AC adapter. See if that is the case with your system and try the working AC adapter with the base to see if it will work or not. Good Luck.
Jan 31, 2015 | Uniden Cordless Phone
Display says "base unit no power" Is this fixable?
this is not a battery issue the actual unit that plugs into the phone socket and has a radio transmitter has no power. Look at the AC adapter plugged into the power point of the radio base device. Most likely someone has unplugged it or the AC adapter has gone faulty.
It is fixable check the AC adapter is plugged in and the power point is switched on. you should be able to buy another AC - DC adapter if it has gone faulty.
Dec 31, 2014 | Lands Phones
Iphone won't charge from ac adapter
contacts on ac insertion tip slightly damaged check by having friend or simular product attempt to charge theres ? yes it works on others?thenits your female reciever entry on phone is damaged due to tip end on charger being inseted when not aligned perfectly lots of phones do it if that is the case check policy on damage w/out posting your idenity generic review ,your most likely not covered so 2 choices get old phone same exact sameis required and charge back-up battery to op phone but smart phones freak on O.S. BEING YANKED OFF NOT GOOD 2ND IS LOOSE IT OR TURN EYE WHILE BAR FLY POCKETS REPORT GONE CANT SEE WHO GET REPACEMENT WHEN IT DOES FAIL OR GET SCREWED BY PHONE CO. LIKE US BUY 2ND IPHONE 1 WEEK AFTER 1ST ONE CARRY 2ND LINE AND WAIT 6 MO. FOR CYCLE TO DROP NON USED AIR WE PAID 129 MONTH ON BOTTOM DEAL WENT TO 200 +EA. MONTH YOUR CHOICE CRAIGSLIST EBAY AUCTIONS PAWN ARE MOE HONOABLE THEN SENARIO I AIRED MY PAIN I WOULD NEVER LET THE CO. HAVE MY MORALS OVER PHONE ISSUES OR ANY MATERIAL GOODS GOOD LUCK I WISH YOU WELL
May 02, 2012 | Apple iPhone 4 Black Smartphone
Specifications for GE 5952EE3-A AC adapter? 9V----???
Hello there,
The specification for the GE 25952EE1 5.8 GHz Cordless Phone ac adapter is
INPUT AC 100-240V 50/60Hz
OUTPUT AC 9.6V----1A
Thank you for using fixya
Caseytech
Jul 06, 2011 | GE 25952EE1 Cordless Phone
Says No Link...Reconnect base AC Adapter
Disconnect the AC adapter from the unit, wait for 5 seconds, then reconnect. The plug may have become loose over time or not be fully inserted. If that does not work, try re- registering the handset.
Mar 06, 2011 | Panasonic KXTG4011 Cordless Phone
What could be the problem if my ip phone will not power on
Are you using an AC adapter? If so, there's only really one of two things, hardware wise, that could be the cause of your problem: The phone is dead, or the AC adapter is dead. The best way to check of course, is another AC adapter with the same voltage output, then you'll know exactly which piece needs to be replaced.
Feb 01, 2010 | Polycom SoundPoint IP 501 IP Phone
Lucent AT&T 7610 Cordless Phone power supply
It should be labeled on the side of the phone. My best guess would be AC/DC...as to polarity, you would have to look at the drawing on the side by the jack...
Jul 27, 2008 | Lucent AT&T 7610 Cordless Phone (22063)
Cordless phone 25881
Sounds like a power problem.
This model of phone will work as a regular corded phone when no ac power is available.
IE the cordless function is only available when you have electricity.
- is the ac adapter plugged into a working outlet.
- is the ac adapter working.
- is the ac adapter pluged into the base.
hope this helps
Nov 30, 2007 | GE 25881EE3 Phone
I get a message Ac OFF
Hi, Your assumption is correct. The phone is not sensing any external AC power. If you are sure that the AC cord/adapter is plug in to the mains, then it is either: 1. the walloutlet or where the ACplug/adapters is connected does not have any power; or 2. The adapter itself is defective. Hope this b e of some help/idea. Pls post back how things turned up or should you need further information. Good luck and kind regards.
Sep 26, 2007 | GE RCA 4-Line Speakerphone
Lands Phones Logo
10 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
