Foxconn 915M08 manual
Pc 915m08 g 8ks ex
acer web site support the type in your board at the search bar then download all update at the same time ok
Dec 26, 2013 | Acer Computers & Internet
Manual for Foxconn G33M02
Hi you can find the manual here
http://www.foxconnchannel.com/driverdownload/Motherboard/Intel/Socket775/G33M/manual/Easy%20Guide/%283A2505E00-000-G%29-G33M_easyguide.pdf
Feb 06, 2013 | Foxconn Dell Vostro 400 Motherboard ,...
Power front panel conectors on acer 915m08
This Foxconn 915M08-G-8KS motherboard made for Acer Veriton desktop computers?
http://www.sella.co.nz/general/computers/components/motherboards/other-motherboards/b1jnj6/
Do not know what the Front Panel header pinout is.
(Front plastic part of computer tower is the Front Panel.
Area of contact pins on the motherboard, that the wires (Cables) from the Front Panel connect to, is the Front Panel header )
CAN see by clicking on - View full size image - that the Front Panel header is to the Top Left corner of the motherboard, by the CMOS battery.
(View of mobo is upside down, in relation to how it actually sits in the computer tower case)
Shows me it is just the normal two rows of contact pins used in a LOT of desktop computer mobo's. (MOtherBOard)
If it were I, I would use one of the LED lights connected to two wires, and touch across each two sets of pins.
Looking at the motherboard as it sits in the computer case, there is a row of pins on Top, and a row of pins on Bottom.
In your mind start at the LEFT side of the pins at the TOP.
Number them from Left to Right.
Example, Pins 1, 3, 5, 7, and 9.
Now number the pins on the Bottom, from Left to Right,
Pins 2, 4, 6, 8, and 10.
Computer plugged into power, touch the two wires of the LED light, to Pins 1 and 2.
Computer doesn't start? (Power Supply turns on)
Go to the next set of pins.
I am willing to bet Pins 5 and 6 turn the Power Supply on.
No? Keep experimenting.
What will happen if you touch the WRONG pins?
N-O-T-H-I-N-G
You will NOT hurt the motherboard.
When you get to the correct pins, the Power Supply will turn on.
These pins are for the Power On switch.
Now go back through the pins with the Power Supply on, but DO NOT touch the pins that turned the Power Supply on.
When the LED light STAYS on, you have the pins for the Power On LED light.
If the LED light BLINKS, you have the HarDDrive activity LED light.
If Windows starts to load, and you touch the Restart switch pins, the computer will restart over again, and Windows will load again.
(IF this computer has a Restart switch. I do NOT use one, even for the older computers. Just press CTRL, ALT, and DELete keys at the SAME TIME, to restart the computer, or use the Task Manager option)
One pin left all by itself? That is for 5 Volts, and only used by the factory. Leave it unconnected.
There may also be a blank spot on the Front Panel header, where it looks like a pin is missing. This is the KEY pin, and is not used.
It is just to orient where the other pins are.
Worried about getting shocked?
There may be a small spark, as you connect the wires, I will gramnt you that.
But the voltage is 5 VOLTS DC.
In comparison two D cell flashlight batteries produce 3 VOLTS DC.
The harmful AC voltage is contained in the metal enclosure, of the Power Supply. Can't get you unless you pour water on it close up, or stick a metal rod through one of the ventilation holes, in the Power Supply enclosure.
Regards,
joecoolvette
By the by. You could be a lot of people's hero, if you came back, and posted the pins for what they do. Post in a Comment.
Jun 08, 2012 | Acer MB.V1509.002 VERITON 7700G VT7700G...
Acer 915m08 front panel conectors
http://forum.novatech.co.uk/showthread.php?45-Generic-front-Panel-Wiring-Guide-Updated
here's a recent link fix for your information.
Jun 08, 2012 | Acer Veriton 7700g Power Button & Led...
RS740M03A1-8EKRS2H. NECESITO IDENTIFICAR EL DETALLE DE CONECCION DEL PANEL FRONTAL DE ESTE MOTHERBOARD MARCA FOXCONN QUE PERTENECE A UN EQUIPO ACER, PERO EN LA PAGINA DE FOXCONN NO ME APARECE EL MODELO...
I have the same motherboard. Its a Foxconn A74MX-K 's motherboard which also adopts AMD® 740G + SB700 chipset. get the drivers/manual from foxconn website
Jan 25, 2011 | Acer Aspire M1201 Athlon X2 320 Gb PC...
I lose my motherboard diver for 915m08 intel
install driver detective on your system then it will automatically install all driver on your system.
http://download.cnet.com/Driver-Detective/3000-18513_4-10175742.html
May 09, 2009 | Computers & Internet
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
