Question about Spirit Esprit ET4 Treadmill
Calibration need to recalibrate treadmill
Treadmill incline not working
The incline system may need to be calibrated. To initiate the calibration routine follow the steps below.
Step 1
Place the key into the machine. The key's slot is located on the bottom of the console, below the start and stop buttons.
Step 2
Press any of the incline buttons and then remove the key from the machine while the incline is changing. Pause for a few seconds and then put the key back into the slot.
Step 3
Wait as the treadmill automatically shifts to the highest possible incline and then descends to the lowest level. The treadmill should now be recalibrated.
May 30, 2014 | Nordic Track NordicTrack Treadmill, A2550
High speed and error 91 and treadmill stop
Please recalibrate the machine with software calibration, for easy diagnose, troubleshooting and fix it
If the problem persist, you must need some basic parts or need service for repair. See hte block diagram attached.
God bless you
Jan 07, 2013 | Kettler TX1 Treadmill with FREE INSIDE...
Sportsart 1200 treadmill E-6 hoe do you recalibrate it?
read the instruction under HOOD motor and proceed according . OTherwise go to the instr. manul and follow the steps for how to enter the s. calibration
if you do not have the manual go to www.fitness.manualsonline.com
God bless you
Nov 30, 2012 | Exercise & Fitness
Have Spirit SR247 Treadmill. Feels like it's going faster than what is displayed. What causes this?
The machine need recalibration., is by the use simple.Now you must use the calibration software.Go to below the hood and proceed with your steps. and owner manual. for fix it.The calibration soft will be fix it your problem. Sincerely. Merry Christmas.ernesto cuadra managua, nicaragua c.a.
Dec 19, 2011 | Exercise & Fitness
Speed is off on nautilus exp 1000x treadmill
Please use your calibration software for recalibration your fitness according with your owner manual. See the instruction too below the hood. and proceed for fix it.
ernesto cuadra
managua, nicaragua. c.a
Dec 10, 2011 | Exercise & Fitness
I have a vision T9500 treadmill. My husband was recalibrating and it got stuck in the highest position and is displaying E5 in the window. Any ideas how to get it down?
hi,
Try AUTO-CALIBRATION first. For that do the following.
With the safety key in place, turn the treadmill ON . Press and hold SELECT. Now you can perform auto-calibration by pressing START.
(The treadmill will run through minimum and maximum speed and elevation. This will take 3 to 5 minutes. Let the treadmill perform this complete function. "END" will appear when auto-calibration is complete. When auto-calibration is complete, it will take about 30 seconds for the treadmill to reboot and return to the start-up screen)
If it doesn't help then the motor control module is faulty. You have to replace or repair the motor control module.
OK
Aug 27, 2011 | Dmm Vision Fitness T9500 Treadmill
Hello, WE have the model 4100i treadmill and the elevation is stuck in the highest position and won't reset to zero. How do I fix this or who can I call for this repair? Thanks, Tom
Try the calibration procedure found in the troubleshooting section of your manual first. Here are the basic instructions.
With the key in the console, press one of the Incline buttons. While the incline is changing (or the numbers on the console) , remove the key. After a few seconds, re-insert the key. The treadmill will automatically rise to the maximum incline level and then return to the minimum level. This will recalibrate the incline.
If it still doesn't move, remove the cover. Find the incline motor. You will see a slot in the end of the motor. Using a drill with a standard slotted screwdriver bit, spin the motor counterclockwise (if it is having difficulties spinning, turn clockwise instead) for just a couple seconds. Now do the calibration procedure again.
I have had machines that got stuck before. Once released and recalibrated, the operation was OK.
The service number for your machine is found on the model number sticker on the frame of the treadmill.
Feb 26, 2011 | Nordic Track Nordictrack Apex 4100i...
Incline not working,but lever works
Try recalibrating. There is a trouble shooting guide under the hood (motor cover) of the treadmill. It will have the calibrating proceedues there.
Nov 15, 2009 | Proform Crosswalk 500 Treadmill
Treadmill wont incline all the way
With the key in the console, press one of the incline buttons. While the incline is changing, remove the key. After a few seconds reinsert the key. The treadmill will automatically rise to the maximum incline level and then return to the minimum level. Thi will recalibrate the incline system.
Sep 30, 2009 | Reebok 8050 ES Treadmill
Spirit Esprit ET4 Treadmill Logo
19 people viewed this question
Top Spirit Exercise & Fitness Experts
Mister G
Mister G
Level 1 Expert
Richard Warren
Richard Warren
greg kinsley
Are you a Spirit Exercise and Fitnes Expert? Answer questions, earn points and help others
