Question about Maytag Washing Machines
Need load capacity for A8650
I need the load capacity for Model A8650
Can you tell me what size capacity this front load washer is?
Good Morning Friend, that's a great question!
In order to provide you the correct size capacity of your Frigidaire front load washer, I would need your model number please. You can normally locate the serial tag (which lists your model number) on the upper front, as you open the door. Thank you and I look forward to further assisting you! - Z
Sep 05, 2014 | Frigidaire GLTF1670A Front Load Washer
Capacity frigidaire fwt445ges2 load
Good Afternoon Friend,
I understand you want to know the capacity of your Frigidaire washer, model# FWT445GES2. After researching your model, I found that the capacity of your washer is 4.5 cubic feet. Hope this is helpful.
-Best Regards-
WP
Jul 05, 2014 | Frigidaire GLTF2940ES Front Load Washer
What is the loading capacity of this model?
Please specify your model number so that i can help you with its loading capacity.
Mar 08, 2011 | Washing Machines
Dryer Maytag LDE 9316 ACE -what is the capacity of that model dryer? Thank you!
Capacity is a key consideration when shopping for a dryer. The more you are able to dry in a single load, the less time and money you will spend doing your laundry. Most importantly, look for a dryer with approximately twice the cubic foot capacity of your washer.
Typical dryer capacity ranges from approximately 3.4 cubic feet (for a compact model) to over 7 cubic feet for an extra large capacitor
In addition to saving time by drying on fewer loads, and money on lower energy costs, a large capacity dryer often means spending less time once the laundry is dry. There is typically less wrinkling when clothes have more room to move around inside the drum.
Whirlpool brand offers dryers with a range of capacity and flexibility.
Dec 16, 2010 | Dryers
Capacity
if this is a top loader. the capacity is that as long as ur load is moving freely when adgitating is a good load. if its not moving freely its too much laundry
Feb 05, 2010 | Kenmore Washing Machines
What is the capacity of Kenmore model
This may or may not help.
http://www.managemyhome.com//mmh/lis_pdf/OWNM/L0305295.pdf
Nov 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
White-Westinghouse model la450mxw1 top load capacity in Kg.
I called Frigidaire technical support, they informed me that the capacity is 2.7 c/feet.
Nov 26, 2008 | Westinghouse WWS833ES Super Capacity Top...
WHAT IS THE LOAD CAPCITY SIZE OF WASHER MODEL 110.20702990
On newer, and sometimes a little newer, Whirlpool and Kenmore (Kenmore is made by Whirlpool) considers a few things in determing capacity. Most of the inner baskets are the same size, but they also add in agitator action into the mix. A Kenmore with an auger top agitator would have higher capacity than a Kenmore with just a normal agitator, even though it has the same sized drum. So a super capacity washer would have theoretically less CLEANING CAPACITY than a super capacity plus. The agitator action is actually what determines capacity on these models. So, with that in mind, cubic load should be about the same on both units. Sorry that I had to go into "Bill Nye The Washer Guy" mode, but thats about the only way to describe. Let me know if I can confuse you any more haha. Seriously though, if you need further help or info, write back, and will try to get you some other information. Remember, this theory only works on top load "normal people" washers, not the front loaders.
Nov 22, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machines Logo
23 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
