Question about Jandy Laars Lt 250,000 Btu Heater
My Laars LT heater comes on as if it calling for heat but...
The mode control has no response. I can't adjust the temp, nor does it ever satisfied. The heater runs constantly, as if it is still calling. The only peculiar thing is that light next to the "pool" mode flashes constantly. There are no other lights lit to indicate a problem. The only way to shut it down is to unplug the heater all togehter from the power source. Is there a proceedure to check what is wrong with it? Nothing in the manual covers this situation.
    Champion:
  • 246 Answers
Change the board
Posted on Oct 16, 2009
Jandy Laars LX/LT Low NOx pool heater not initiating heat cycle
check safety circuit then pressure switch and wires to tight should be 24 volts ac if under 10 pressure switch not enough voltage to keep open also check copper tube to switch for calcium
May 17, 2018 | Jandy Pool & Spa
I have a laars jandy 250 lt gas pool heater that only heats luke warm. The heater cycles normally then heats up but stops before reaching operating temp. No service lights and thermal switches are g
I do not have a handy but mine has a temperature setting at the heater and one on the remote. it is possible that one of the settings is low. the pool or spa temp is sensed at the heater and with the water temp located in the pool lines. so both the control board and the heater are sensing the water temperature.
Oct 09, 2014 | Jandy Laars Lt 250,000 Btu Heater
Laars LT - "red" light
means calling for heat if heater doesn't come on check safety circuits
Feb 12, 2011 | Jandy Laars LX Pool Heater / 400,000 BTU /...
The pool heater temp is set at 84 deg F, yet the pool water is at 78 deg F. What's wrong? Please send answer to: janapavlov @yahoo.com Thanks, Vlad
what is the tem at the heater do you have a automatic control what is the temp here may need new temp sensor but dont have all info
Jul 15, 2009 | Jandy Laars Lt 400,000 Btu Heater
Pilot is lit but when i turn the thermostat up the heater will come on. installed new thermostat but still will not heat pool?
do you change the sensor that come with the termostat? do you have a automatic control may be a temp sensor is bad ? last the pool take one degree per hour to heat are u give enough time?
Jun 16, 2009 | Jandy Laars Lt 400,000 Btu Heater
Laars Lt heater will not start- pressure switch light
it is time to check your filter make sure is not dirty and if your filter is clean and still doing this then the problem can be with one of the safety sensors they do have 2 hight limit switch located in the heater heather they re round with two wires on each one turn power off to heater and get a voltemer reader and check the hight limits for continuty they should read zero on your metter it can be your temp sensor heaters are so complicated that it is always good to have a pool tech service it I was a pool tech in california but now I am located in georgia
Jun 13, 2009 | Jandy Laars Lt 250,000 Btu Heater
Heating problem with laars lx400 boiler
replace or adjust pressure switch to have heater go off when pump is off
May 29, 2009 | Jandy Laars Lt 400,000 Btu Heater
Laars Lt spa heater service light
replace temp sensor its by the plumbing inlets or mounted to top of heat exchange
Feb 22, 2009 | Jandy Laars Lt 250,000 Btu Heater
Heater will only heat spa water to luke warm.
sounds like it may be the thermostat on the heater. You are correct to check the filter first. if it is clean then it is probably the thermostat
Dec 19, 2008 | Jandy Laars Lt 250,000 Btu Heater
Jandy Laars Lt 250,000 Btu Heater Logo
132 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
jhalston
Level 1 Expert
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
