Question about Bush 2871NTX 28" TV
Lcd26tv022hd Lost remote control. Can I tune in using only buttons on tv
I have a 19" sceptre led TV we lost the remote and have been using the buttons on TV. A message appeared that the buttons are blocked the only button that works is power is there a way to unlock them?
It probably is the tv that needs tuning in to use the buttons as opposed to them being 'blocked'.
However, why not buy a universal tv remote?
GE 24900 3 Device Universal Remote Control 24900 NOB
Have a look on ebay.com The link supplied is for reference only. There will be many to choose from. They're cheap enough
Jan 06, 2016 | Sceptre Televison & Video
How can i tune my tv using this remote. I have the remote working but now need to tune the tv with it?
Should be a menu button or on some universal remotes there is a sub menu accessed from the buttons on the side of the lcd screen.
Sep 25, 2015 | Universal Televison & Video
Doro remote and LG TV
If you wish to get setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search. easy.
Mar 18, 2013 | Doro HandleEasy 321rc Remote Control
Ferguson F1905lvd t/v no remote control and need to re/tune
As there is no Menu button on the front panel of your TV, to perform an auto tuning function, you must have its remote control. Without remote control, it is impossible to get in to this menu option.
Jun 12, 2012 | Televison & Video
I have an old TV Proline G1431B and I can not tune or install programms manually, as I can not see the buttons. Can you help how to install programms without TV remote controller?
No you can't tune without the remote control except you can search on PCB board whether the additional/optional button for Auto Tuning or Manual Tuning. If it is exist you can add the button and use it. Other wise, there is no way to tune, and you have to looking for the remote controller..you can try to use the Universal remote first.
Thanks, I hope this can solve your problem,
Agus Yustiara
Oct 25, 2010 | Televison & Video
Tuning SD-M1407
use the button's on the front of your tv or buy a universal remote it will help with some function's $5.00 anywhere or you can buy a refurb remote for $135.00 on the internet rocky
Jan 06, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
Sky remote tune to samsung
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Aug 13, 2008 | Samsung WS32Z308P 32" TV
Universal remote control
What is the make of your universel remote control.
Mar 14, 2008 | Televison & Video
Televison & Video Logo
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
