Question about Cartoni K499 C40S Wedge Plate Assembly with Wedge Plate
Kalimar k-499 parts
Need the suction cup
Need replacement suction cup for window attachment.
Contact the radar detector manufacturer for replacement suction cups. You didn't mention which make and model radar detector you have so we can't provide more information.
Jul 16, 2015 | Vehicle Parts & Accessories
Can you get spare parts for go 700 mount?
I'm afraid they don't sell spare parts for these models anymore. I managed to by a complete mount, a few months ago, for a few dollars, because the model is overdue.
Try to find one on Ebay or that way.
Jul 15, 2014 | TomTom GO 300 700 Locking Suction Cup...
Need new rubber tank gasket for Holmes humidifier Model HM4600
after scouring the INTERNET AND FINDING PLENTY OF SITES THAT WOULD SELL ME THE WHOLE CAP FOR 24.00. I MAD MINE USING SOMETHING FROM ace hardware THAT COST 2.50 Small suction cups with the hook [CDBL-7500S11] PART NUMBER 7500 .CAN BE MODIFIED INTO MAKING YOUR OWN GASKET. IT WORKED FOR ME ..REMOVE HOOK FROM SMALL SUCTION CUP. cut off nib with sharp pair of scissors. THEN DRILL HOLE THROUGH CENTER OF CUP WITH 7/64 DRILL BIT. re insert plunger part of cap through cap with spring and re- attach suction cup instead of gasket. MINE WORKS FINE ON A HOLMES 3700
woodinvirginia
Jan 23, 2011 | Holmes Products HM4600-U 11 Gallon...
Can't assemble suction cup mount that came with Nuvi 350
They fit tight together. Sometimes you need a little force.
Sep 13, 2009 | Garmin 010-10723-03 Suction Cup Mount...
LG GPS not suctioning to windhield
You must clean the window area using windex, or other cleaner, and wipe until dry. A clean winshield area provides the best suction, from the mounting bracket.
Slide the mounting bracket switch to Off & On a few times, make sure the suction cup is able to move(slightly) and that the small tap is facing the area with the notch in the metal.
After putting the switch to the middle, moisten the suction cup slightly
(saliva works bestter than water for some reason)
press it to the window with a slight amount of pressure
then move the switch, (Which should be set to Center!)
to lock it on firmly.
If this doesn't work, then there is a good chance the suction cup has become hardened by the sun. If that is the situation, you'll have to contact LG
(or a place that sells "knock off" brackets to get a replacement.)
I never leave my LG GPS in the car, when not in use. Even the bracket comes out, as I've seen what the sun can do to damage those plastic suction cups, fortunately, I learned it on a $5 replacement set for a Radar detector/Emergency Vehicle Alert device, and not a more expensive bracket.
Dec 07, 2008 | LG LN740 GPS
Attaching to windscreen
I have a spare window mounting bracket as new , but I need SmartST 2006 SE CD Rom. If you want to do a swap , that is you send me a copy of SmartST 2006 SE and I send you bracket email me at
fuddlebarklard45@hotmail.com
Aug 29, 2008 | Navman NavPix N40i GPS Receiver
Installing Garmin 350
It should be a round hole with three little notches, just stick it in and push (flat surface required!) Then there is a lever on the suction cup to **** it against the windo, just snap close that when you're sticking the hip joint into the socket!
Jun 04, 2008 | Garmin nuvi 350 GPS Receiver
The screen mounted garmin nuvi sat nav now wont stay attached to windscreen
sounds like you need a new suction cup assy, check the garmin webshop
Apr 18, 2008 | Garmin nuvi 350 GPS Receiver
Holder
wet the suction cup a little, press down firmly before flipping the switch to lock it down
Apr 18, 2008 | Garmin StreetPilot c340 GPS Receiver
Suction not holding on window
wet the back of suction cup. it will hold alot better
Jan 14, 2008 | Garmin StreetPilot c340 GPS Receiver
Cartoni K499 C40S Wedge Plate Assembly with Wedge Plate Logo
57 people viewed this question
Top Cartoni Photography Experts
Tony
Are you a Cartoni Photography Expert? Answer questions, earn points and help others
