Question about Epson WorkForce WF-7520 Wide Format All-in-One Printer
I have an epson 7520 and need to now how to copy two sided
How do I copy two sided
Correct setting for Epson Workforce 7520 printing on gloss paper
You need to start with photo glossy paper that's designed for an Epson printer. HP paper may not work well, and some other papers don't work either. Try some Epson paper, and that should work fine.
You can also try other paper settings, such as "transparency" or "matte paper", as the paper setting governs how much ink is laid down. I think getting the right paper is really what you need, though. Ink "puddling" is a common Epson complaint, and it's almost always the paper.
Nov 02, 2014 | Epson WorkForce WF-7520 Wide Format...
Epson wf 7520 "scanning negatives"
I also Have a Epson WF 7520 and I cannot scan any film I've tried every thin here listed I called Epson Support and they said this all in one can't do negatives but it has a slot for it don't understand how you all can Please need help
Apr 12, 2014 | Epson Office Equipment & Supplies
Epson wf-7520 power light, auto answer light & wi-fi light blink
As far as the wifi is concerned, try getting it connected to your home network. Once it gets connected, go into your network settings and try to get the IP address. If you can obtain that, you should be able to add a network printer using TCP/IP port. Also, see if you can factory reset the printer, and start the setup all over.
Feb 17, 2014 | Epson WorkForce WF-7520 Wide Format...
Epson WF - 7520
My EPSON 7520 printer can't print the 1m banner I buy for that purpose, it's new, I design the banner & set up to print, before print when I check for preview it's divided for 4 portion. how can I fixe it? the last size the printer it takes 27cm * 42cm long, but I need to print 27cm * 100cm what can I do? I need help.
Jul 07, 2013 | Office Equipment & Supplies
Epson stylus dx3800 driver for dell inspiron 7520
hello,
You can get the driver here: EPSON DRIVER
Make sure to select the correct operating system. You can find that in the left side below the product image.
After that, select the driver in the list.
I hope this helps.
Carlo
Nov 19, 2012 | Dell Inspiron One 19 All-in-One Desktop PC...
Epson WorkForce WF-7520 Wide Format All-in-One Printer Logo
12 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
