Question about John Deere 4020 Gas & Diesel Tractor Radiator
Out of Diesel
I ran my JD 4120 out of Diesel. Now it won't start. What should I do
    Problem Solver:
  • 5 Answers
This particular JD engine has an individual fuel pump for each cylinder. The injectors, fuel lines, and pumps are not accessible from outside of the engine. There is a hand primer pump built into the top of the fuel filter. Start by removing the rubber outlet line from the filter base and pump the primer pump until fuel come out of the filter base outlet. Ounce fuel comes out of filter reconnect the line and continue pumping by hand until the pump button feels solid, then crank engine until it starts. This works better if a helper is available to operate the starter while continuing to pump the hand primer. This is normally all that is needed after running out of fuel.
If fuel does not come out of fuel filter base there may foreign material inside of primer pump. Primer pump can be disassembled and cleaned. If fuel comes out of filter, primer pump become feels solid but engine does not start the fuel control rack inside of engine may be sticking in the off position. This may sometimes be overcome by clicking the key switch from off to on rapidly. If not you may have to have your dealer remove the governor cover to free the rack.
Posted on May 30, 2014
JD F 935 mower. Why won't it drive?
if you ran it dry or too low,then you have damaged the tranny,you need to call a jd dealer
May 26, 2015 | Garden
Hi, I have just replaced the cylinder head on my pajero 2.8 diesel. It started first time and ran for about 4/5 mins then cut out. It is attempting to fire but won't.....any ideas would be grate
Keep pumping the hand bleed pump on top of the fuel filter to remove all the air. when started and still a bit lumpy keep pumping and it should clear itself
Dec 03, 2012 | Cars & Trucks
My JD JS35 mower hit a stump and instantaneously stopped. It won't start. Occasionally it will fire once. What might be wrong?
Hi, it has most likely sheared the flywheel key and thrown the timing out. Also check that it has not bent the blade or crankshaft. Regards Phil.
Jun 27, 2012 | Garden
Ran out of diesel now vehicle won't start
This is not unusual on a diesel. What happens is there is air in the system. If this vehicle has an electric fuel pump loosen line where fuel enters injection pump then turn ignition key to the on position and watch for fuel to appear and then quickly tighten line before turning off key. Then try to start. If does not have electric fuel pump will need a second person. One will loosen line and watch while other cranks vehicle until you get fuel and tighten line before the other person releases ignition switch unless vehicle starts first. If that doesn't do the job do this where line hooks onto each injector. Probably will not have to do this to all injectors but could run rough until all the air gets out of everything. I have farmed with diesel tractor for 25 years and dad I drove the gm vehicles with the 5.7. You normally don't start a diesel without bleeding the air out of the lines although some will self bleed most won't. Hope this does the trick.
Jun 21, 2012 | 2004 GMC Sierra 2500
95 Courier with Mazda diesel is hard to start, runs rough, blows lots of blue smoke and won't go over 60kph in top gear
I'd get your injectors rebuilt, and tune up your injector pump. Run a little seafoam in the diesel tank, and in the oil. Should make it clear right up.
Mar 29, 2012 | Cars & Trucks
Have a JD STX 38. Put an ign light on it, no
have same tractor same problem mine was coil ran but when i shut off after mowing wouldnt start changed coil no problem since
Aug 17, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 4020 Gas & Diesel Tractor Radiator Logo
134 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
