Question about Sparco High Volume Electric Three-Hole Punch 96003 SPR96003
Papers are sticking in hole puncher
Have to pull the papers to get them unstuck from the hole puncher area.
Is there a universal standard for hole punchers?
No there isn't, there are many different hole punchers that make holes at different spaces apart and different countries use different hole spacings.
Wikipedia has a chart of all the different hole punchers. http://en.wikipedia.org/wiki/Hole_punch#Chart.5B3.5D
Sep 22, 2013 | Office Equipment & Supplies
Is there such thing as an electronic hole puncher?
Yes there are a lot of electronic hole punchers, you can find them at stores like Office Max and Staples.
My paper will not feed. The printer will only pull a small amount down until it tells me that there is no paper!!! UGH! Can you help?
shut down the printer, remove all the papers, use a brush to clean the paper feed area slot, if you can open the front panel, clean that area too.
Dec 07, 2009 | Canon PIXMA MP470 All-in-One Printer
Lexmark 5400 series printer won't grab paper for printing
Whenever the printer doesn't pulls the paper please pull the pack of papers, browse through the papers with your finger and put them back gently.If it doesn't work it means the wheels that pull the paper are worn and you need to replace them.
For the second problem, this is not a printer problem but a software problem, please specify which software do you use so we can help you, as each software has individual options to print multiple pages. It will also be more logical to post the problem in the specific software area.
Good luck,
GetAFix99
Nov 17, 2009 | Office Equipment & Supplies
How to remove jammed paper in the Samsung ML-2240 laser printer
If there are papers stick out of the top in the recieving tray gently wriggle them back and forth until they are free. Then, open up printer and the remove the ink cartidge. The papers lying mostly on the inside need to be pulled from the inside. The papers that have just been picked up and are mostly still lying in the paper feeder can be pulled out from there as well (although you may want to remove all the paper that hasn't been grabbed yet). Just keep wriggling back and forth gently so as not to tear the paper and lose a little scrap inside.
Oct 06, 2009 | Samsung ML-2240 Laser Printer
The readout says Paper Jam, open front cover to clear, press i. There was no jam. A page exiting the printer stuck at the bottom end. I pulled it out easily and intact. Immediately, the red light went...
open the printer again.you didnot specify which kodak printer you have. take all papers out of paper tray .fan them properly to make sure that no two papers are sticking to each other. load papers again in to the printer,contact kodak @1800 421 6699 if u face problem again.
Jul 25, 2009 | Office Equipment & Supplies
Stuck and will not work and canot get papers out
Dina,
Lift the top off and turn it over on your lap. Check two things. There are probably contact points on the side that prevent the use of the machine when it is in the position you have it in. They are probably nothing more than a button pushed in when you return the unit to the receiving bin. Next with a pair of tweezers that work pull all the bits of paper out from between the blades you can. It is somthing you need to do anyway after a big job. There is also probably a light sensor where the paer goes into the shredder. Remove as much paper as you can if any is still sticking out from the shredder. Once you have removed all the paper bits from between the blades return the unit to the base. This will also have given it a chance to cool down. If there is a reverse switch use it to try and reverse the paper back out. If not try running it again. If this still does not work then you will have to physically take the shredding unit apart and dismantle it until you can get to the papers that are jammed. If you have a techie in the area or a guy with tools you trust, see if there are any screws that you can take the top apart and remove the jammed papers that way.
Richar
Jul 07, 2009 | Aurora Electronics AS1500CD Shredder
Bell & Howell Copiscan 8000 Scanner spins and doesn't take paper in auto position. Will slowly pull paper through with lever up in manual position but constantly multi-feeds. Have changed skimmer and...
Just check if the papers are sticky. Stapled papers even after removing the pins are held together at the point where the pin was! In the horizontal direction it can hold two papers together. Multiple papers can prevent loading of sheets. Clean the pickup  rollers with a damp cloth thoroughly, no solvents please.
S. Mohan, Chennai, India
Mar 03, 2009 | Bell & Howell Copiscan 8000 Spectrum...
Sparco High Volume Electric Three-Hole Punch 96003 SPR96003 Logo
44 people viewed this question
Top Sparco Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sparco Office Equipment and Supply Expert? Answer questions, earn points and help others
