Question about Celestron Handheld Digital Microscope
Message microscope is being used by another program and won't start up.
Keeps telling that microscope is busy or is being used by another program
I need dowland drivers to intel play model APB 24221 99A
Here are the instruction for installing the QX3 (or QX3+) Microscope with Vista and Windows 7. You must be using a 32-BIT VERSION. The QX3 is not compatible with 64-bit versions.
Note, DO NOT use the software from the CD that came with the microscope.
DO NOT plug in the QX3 microscope until Step 4.
Step 1. Download and install the QX3PLUS.EXE software from Intel:
http://tinyurl.com/QX3-Win7-Files
Step 2. Download and install the QCODINSTL.EXE software from:
Step 3. Download and extract the QX3 Drivers from:
Step 4. Now, plug in the microscope.
When the "Found New Hardware" wizard appears you will see a message saying that the driver installation was not successful. Click the Close box. You need to install the driver manually by following these steps:
a. Click START - Select Devices & Printers
b. Right-click on the Intel QX3 Icon and select Properties
c. Click the Hardware tab - click Properties
d. Click Update Driver - select "Browse my computer for driver software"
e. Browse to the folder with the extracted QX3 drivers from Step 3. above. The driver software should install successfully.
Before you run the QX3Plus program right click the icon, click on "Properties", click the "Compatibility" tab, check the box next to "Run this program in compatibility mode for:", then choose in the drop-down box "Windows 98 / Windows ME". You should also check "Run as Administrator" if your account is a "Standard user".
Step 5. Now double-click on the QX3+ icon on the desktop and the program should run.
Aug 13, 2014 | Intel Play QX3 Monocular Microscope
Qx3 microscope driver for Windows 8
Here are the instruction for installing the QX3 (or QX3+) Microscope with Windows 8 and Windows 8.1. You must be using a 32-BIT VERSION of Windows 8 or 8.1.
Note: The QX3 is not compatible with 64-bit versions of XP, Vista, Windows 7 or 8.
Step 1. Download and run the QX3plus.exe program from:
http://tinyurl.com/QX3-Win8-1
After the program installs, uncheck "I would like to view the README file." Click "Finish".
Step 2. Download and run the qcodinstl.exe program from:
If asked about NTVDM, click "Install this feature" then click "Close"
Step 3. Download IntelQX3driverXP.zip and save (do not open) the file from:
Step 4. Now, plug in the microscope. The driver should load silently.
If the "Found New Hardware" wizard appears and you get a message saying that the driver installation was not successful. Click the Close box. You need to install the driver manually by following these steps:
a. Right-click START - Select "Device Manager"
b. Right-click on the Intel QX3 Icon and select "Update Driver Software", select "Browse my computer for driver software"
e. Browse to the Download folder with the extracted QX3 drivers from Step 3. above. The driver software should install successfully.
IMPORTANT: Before you run the QX3Plus program for the first time, right click the "Intel Play QX3 Microscope" icon on the desktop, click "Properties", click the "Compatibility" tab, check the box next to "Run this program in compatibility mode for:", then choose "Windows 98 / Windows ME" in the drop-down box. You should also check "Run as Administrator" if your account is a "Standard user". Click "Apply" then "Ok".
Step 5. Finally, double-click the "Intel Play QX3 Microscope" icon on the desktop and the program should run.
If you get a message that the microscope is not plugged in, quit and restart the program.
If the program hangs or crashes, reboot the computer, then restart the program.
Comments and suggestions to mmehall [at] yahoo.com
Apr 05, 2014 | Intel Play QX3 Monocular Microscope
Windows 7 driver
Step 1. Download and install the QX3PLUS.EXE software from:
Jan 19, 2014 | Intel Play QX3 Monocular Microscope
QX3 microscope
Dec 30, 2013 | Intel Play QX3 Monocular Microscope
Digital blue qx3 drivers
Here are the instruction for installing the Intel QX3 (or Digital Blue QX3+) Microscope with Windows 7 or Windows 8.1. You must be using a 32-BIT VERSION of Windows 7 or 8.1.
Aug 20, 2013 | Intel Play QX3 Monocular Microscope
May 02, 2013 | Intel Play QX3 Monocular Microscope
My integral webcam for Lenovo laptop is not working.It gives a message " To turn off other programs in the background keeping the camera busy "
Usually you have a Webcam Software provided by HP, perhaps CyberLink, it will start at windows startup. I suggest using freeware CCLEANER: http://www.filehippo.com/download_ccleaner/ This freeware program has many useful tools, a cleaner, registry, to clean jnuk and free up HDD space. In the TOOLS section, select STARTUP, disable ALL unnecessary startup programs/processes, including webcam/cyberlink. You can also use Task Manager or Services. You may find it easier to use CCLEARNER.
Apr 15, 2013 | Compaq Presario CQ56-115DX Laptop
I have XP and the qx3 software runs but it won't recognize the microscope
Before you run the program, right click the icon, click on "Properties", click the "Compatibility" tab, check the box next to "Run this program in compatibility mode for:", then choose in the drop-down box "Windows 98 / Windows ME". You should also check "Run as Administrator" if your account is a "Standard user".
Dec 25, 2012 | Intel Play QX3 Monocular Microscope
It says office application version does not match every time I open my documents.
Firstly
When opening a Microsoft Office program or file you may get a message that says “Office Application Version Does Not Match Error”. This is most likely caused by having the Outlook 2007 Business Contact Manager installed on your computer. Many computers that come with the Office trial program installed will have this on their computer from when it was new.
There are a couple of ways to get rid of this error. First you can install the update from Microsoft that gets rid of the error.
Or you can go into Add and Remove Programs (XP) or Programs and Features (Vista) and uninstall the Outlook 2007 Business Contact Manager if you don ’t use it. It won’t affect any of your Office programs. You may get a message during the uninstall process that it can’t remove it from your Outlook profile but just click Ok and finish the uninstall.
or
Bit of an odd one this error message. It is issued when you start Microsoft Word 2007 (or indeed Excel 2007, PowerPoint 2007 or Publisher 2007) on a computer that has Microsoft Office Outlook 2007 with Business Contact Manager installed. You can download a a patch that will stop this error message appearing here.
Hope this will solve your problem
Please rate this and vote
Feb 20, 2010 | Microsoft Office Professional 2007 Full...
Error Message 103
I think it maybe because you haven't installed the "Driver" either at all, or properly. Uninstall any/all software. Reboot, DO NOT plug in unit. now, re-install the Software and Driver. Reboot, NOW plug in the unit, it should now be detected, and work.
You don't say what OS you are using? If Vista or Win 7, try installing as Administrator and also set Compatibility Mode for XP SP2 and run the main .exe as Administrator too.
Feb 12, 2010 | Digital Blue QX5 Microscope
Celestron Handheld Digital Microscope Logo
Top Celestron Toys Experts
ray gallant
Are you a Celestron Toy Expert? Answer questions, earn points and help others
