Question about Huawei Metro Pcs M860 Cell Phone Touch Android Smartphone Tapout Special Edition
Phone says cannot connect to camera
1 click on camera and it pops up saying cannot connect to camera it has worked in the past it dont have a sd card does that matter
How to unbrick a android huawei835
This How To UNbrick your huawei m835 phone step by step.
To tell if your phone is bricked it should only show just the huawei logo or the android logo when you try turn it on and no key combination works to boot into recovery, if u can boot into recovery, dont use this guide.
1) Click This Link to download Huaweis Oringinal Software. ---->HUAWEI M835 - Huawei Device Co., Ltd..
a)Click on the software tab and select the first file there. It may or may not show an error but dont worry just refresh the page and the download will start.
2)When its done, open the M860V100R001C153B251SP03 folder (the folder you just downloaded).You should see another folder called dload and some instructions.If you dont understand what im saying then click the instructions in the folder.
3)Connect your SD card NOT your m835 phone into the computer.
4)Then drag the dload folder any were on the SD card.
5)When thats done take out your battery and put it back in.
6)Press and hold Volume Up + End Call + And The power button at the same time.(i know this sounds wrong but it works)
7)Its Gonna Update your firmware.
8)When its done Turn On your device and the screen that popped up when you first got your phone should appear.
9)Continue with that and BAM your phone is now UNbricked.
Oct 11, 2012 | Generic Huawei M835 M-835 Solid Black...
How to format a sd card
Hello and welcome to FixYa!
1- If you want to format it by keeping in digital camera then follow the given procedure:-
  • Put the SD card into your digital camera and then turn the power on. Press the button on your camera to bring up your recently shot photographs.
  • Press the "Menu" or "OK" button on the camera to bring up the photograph options. Choose the option that says either "Setup" or "Options."
  • Scroll over to the "Format" option and hit "OK." Choose the option to set the file format to "FAT16."
2- You can also format it by connecting it to computer through card reader, For it follow the given procedure:-
  • Turn on your computer and put the SD card into the card reader slot on the front of your computer or the external card reader attached to a USB port. Wait to see if your operating system automatically opens a window prompting you for information. Click on the option to "Open a folder to view files" if the window pops up.
  • Click on the "Start" button if your operating system does not automatically prompt you to open a folder. Choose the "My Computer" option to bring up a new window.
  • Right-click on the drive bay for your card reader, and then choose the option that says "Reformat" from the pop-up menu. Click on the option to set the formatting to "FAT16" if you receive a separate pop up window asking you which file system to set the card to.
You can also get help from the given video, if you choose second option
If you think this solution helps you then your token of appreciation in the form of Rating as Four Thumbs and a testimonial will be esteemed.
Thanks you for using FixYa!
Apr 09, 2011 | Vivitar ViviCam 3720 Digital Camera
I have a koadx camera and i cant download the software so that means i cant download my pictures, so what do i do? help me plzz?!.
1-Connect the camera put it on. Start/My Computer . The camera appears as E: or D: etc. Click on icon and folders until you see your photos there. Copy enclosing folder (Right-Click-COPY) and paste in My Pictures etc. (RIGHT-CLICK- PASTE). To erase the card right-click Format) but do that only after you have saved the photos to two locations for safekeeping.
OR
2- Take out the SD memory card from the camera and insert it in an SD card reader and connect the reader to the computer. Go to My Computer and see the photos there.
OR
3- Download free Picasa software , and click Import your photos after connecting the camera or the card reader.
Dec 21, 2010 | Nikon COOLPIX L18 Digital Camera
I can't get my daughters pictures to come up on my computer. what am i doing wrong?
Hi - I am not familiar with this camera, but it appears many users have encountered similar downloading problems.That is too bad - kids should not be made to feel cheated out of the wonders of technology.
1- Connect the camera to the computer and put it on. Go to Start/ My Computer  If the camera appears as an external memory volume E: or D: etc. , click on the icon and on any folders inside. The photos should be there. Copy the entire folder enclosing the photos (right-click/copy)  and paste it in any other folder where you have your files for example on the desktop.(right-click/paste).
2- If the camera does not appear in My Computer in step 1. check if it has a removable SD memory card. If it has one take it out of the camera and put it in an SD card reader (some computers like the iMac and other laptops have an SD card slot built in the side) . Connect the reader by its USB to the camera and check My Computer as in step 1.  Since the camera has a built-in memory as well as the SD card the photos you want may  be on the internal memory. So you need to go to step 3.
3-  If the camera does not have an  SD card, then your only option is to check the camera driver installation, and use. The manual and the following pages should help: Good luck it is frustrating to deal with driver problems.
http://www.fixya.com/support/t319068-download_photos
http://reviews.cnet.com/digital-cameras/disney-pix-micro-red/1707-6501_7-32159741.html#userOpinions
Dec 20, 2010 | Disney Pix Micro Digital Camera
LG KC550 PC Suite Problem
I speant Hours swearing at my phone because it would not read my music files, Tried the card on many different phones which would take Micro SD and all other phones read the music Just not the LG KC550.
I found that getting a Micro SD dongle reader, Insterting your 2GB Micro sd card in that and then putting your music files into the "sounds" folder works.
Instructions.
1. Insert Micro SD card into Card reader.
2. Insert card Reader to Computer Via USB.
3. Go to my computer and Open the USB Card reader.
4. Select the Music files from your pc Via Copy files
5. Go to open Tab (Where you can see your Micro Sd card) Open the sounds folder and Paste.
If you are finding it hard to get the 5 folders of images, Documents, Sounds, others and Videos on your Micro SD card. Format the card by going My computer, Right click the Card reader (with you Micro sd card inserted) and click format. Takes a few seconds. Insert the card into the phone, the phone will auto put the folders on the card. Then go to step 1 (above) and start again.
Hope this Helps guys.
Apr 04, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
D900 mp3 problem
Just try formatting the SD card. Hope it works fine.
Just connect the micro SD with computer.(You need SD adapter, SD card reader, and USB connection) Most computer will recognise the SD card automatically. Format the micro SD in the Window Explorer(or My Computer). Format menu can be found if you click right-button with cursor on the drive letter. After formatting, re-insert micro SD into your D900.
Some Korean experts says the problem might be caused by different file system (e.g. FAT, FAT32, etc) in each memory card. So they recommended not to share your memory card with different mobile phones as well as any electric devices (eg. MP3 player and digital camera).
Nov 24, 2008 | Samsung SGH-D900 Cellular Phone
Camera will not read SD card
1.) Mount your camera
2.) Open your dcim folder in your camera
3.) In whatever file browser you're using (Explorer, Finder, Nautilus, etc) enable show hidden files.
4.) Remove .thumbnails folder
5.) Be sure to empty trash
See if that works.
Nov 03, 2008 | HTC G1
Nokia N96 Corrupt Card
Open the card on your PC and copy all your files to a folder on your desktop. Then go to my computer, right click the memory card and format. When a little window appears just click start.
If your files are deleted then paste them from your desktop back onto your card. This should fix the problem.
Jun 23, 2008 | Nokia N95 Cellular Phone
Lg shine - cannot access micro SD card which i have inserted.
I just got a new LG shine CU720 to format the card you go to settings, reset settings, master clear, memory card, my security code was 0000. Hope this helps someone else looking.
Dec 26, 2007 | LG Shine KE970 Cellular Phone
Huawei Metro Pcs M860 Cell Phone Touch Android Smartphone Tapout Special Edition Logo
15 people viewed this question
Top Huawei Cell Phones Experts
Computer Repairing
Computer Repairing
honeybun1986
john h
Are you a Huawei Cell Phone Expert? Answer questions, earn points and help others
