Question about EverFocus Home Security
Setting up a user.
We have a EDVR9D1 EverFocus unit. We have a user that we would like to set up to view just one camera. Is this possible? Could a firmware upgrade solve this?
SOURCE: LYRA X3030 FIRMWARE UPGRADE RENDERED UNIT USELESS
I had a problem getting mine to boot but got it working by removing battery and removing AC, then pressing power button. Then plugged in AC and pressed power again. It boots. Then replace battery and cover.
As far as manuals, the official site is below. I'd download a new firmware upgrade and install is from another computer. Sometimes the computer downloading and running an install is
compromised and the virus scanner is not aware downloads are getting damaged upon arrival to your local hard drive.
http://support.rcaaudiovideo.com/manual.aspx?product=203
Posted on Dec 23, 2007
  • 20 Answers
SOURCE: impossible Firmware upgrade
That path should be location of the file you downloaded from trendnet site. The password is set up password for router. Hope you remember that one.
Posted on Jul 10, 2009
VinayT
  • 1884 Answers
SOURCE: nokia7710 upgrading
Get it upgraded from Nokia Care as they do it with their computer with minimum risk against your doing it over the net. I got my E61i busted doing that and thats how I learn this lesson. Go to www.getjar.com and you will find all the SW for 7710 that you will ever need.
Posted on Jul 24, 2009
  • 11967 Answers
SOURCE: How do I upgrade the firmware on my Pentax Optio
According to the Pentax web site, there is no firmware update available for the 33LF camera. As far as your pics are concerned, you can use a card reader to download them to your computer. Then, you can format the card in the camera and everything should be ok.
Posted on Jan 09, 2010
  • 661 Answers
SOURCE: I currently owned two everfocus
Hi Eileenmc0306,
Thank you for such a nice description of the problem that you are facing ,
Now as far as your caution regarding condensation is concerned , it's really appreciated , in addition to that you can take the below precautions with regards to preventing condensation.
Condensation occurs as a result of the fact that cold air is unable to contain anywhere near as much vapor as warm air.
Now to stop condensation you should realize that you should stop the flow of air so that the surrounding does not affect the camera or it's lens.
Now the easiest way out for you would be to get a AIR TIGHT , SEALED plastic bag for e.g. Ziploc Bag.
There are other substitute like a parka or down vest which have not been used for few days.
Also you can check out waterproof camera cases for that matter.
So now what you need to do with the above items with you , is that before taking out your camera to an environment that is different or warmer for instance , you need to place all the camera equipments or the camera mainly in the sealed plastic bag and make sure that it is completely air tight.
Then after doing the above step you can take your camera into a warm environment , but remember that you need to wait for some time while you open the sealed bag , usually 10-15-20-30 minutes or till the time you are sure that the the contents in the plastic bag have got the temperature equal as that of the outside environment.
To make this fast you can first remove the new camera and the new lens from the box or boxes before you actually place them in the container.
Hope this suggestion helps you out with the condensation problem ..:) It has really helped me out.
Posted on Jun 28, 2011
Cannot view cameras live
Make sure your monitor is pluged into the input that is labeled Main Monitor or the VGA . it cant be pluged into the spot monitors .
Its the one on the bottom left . you probebly have it pluged into the call monitor output.
Apr 16, 2014 | EverFocus Ecor264-9x1/2t Dvr Digital Video...
I want to find a good app to open copied video from everfocus home security cameras
You can use restore to take the computer back to a date that you know that it worked. You can use right click and open with to set the program, you can reinstall everfocus. You can manually set the file associations.
Dec 19, 2013 | EverFocus ECOR264-9X1/2T ECOR264 Series 9...
M Brand new DVR doesn't recognize its SATA hard disk? I have confirmed there is power on Hard disk. when it was not working. I format it by using windows 7 and reinstall it . what the reason?
is this the hard drive you recieved with the DVR? it is possible that the HDD is set up in the wrong format. windows sets up your HDD in a NTFS format which is compatible with most DVR's but i know there are some EverFocus units that read the HDD in a diffrent format. if this is the case you need too check in your owners manual in the HDD section, it should tell you what format it records onto, then place the HDD in your PC and reformat it to the right one.
Nov 03, 2013 | EverFocus EDVR16D1/500 16 Channel, 120...
One ptz camera not responding to controls
Cameras should have a reset button on the unit twords the back bottom, try this and re introduces the camera to the system.
If this does not work, try unhooking the power to this camera and reconnecting it . If that don't work recheck all your software setup and settings to see if something became corrupted. Other than that you may have a bad camera.
Oct 21, 2013 | EverFocus ECOR264-4F1/500 H.264, 4...
Forgot login password
Default User and Password on Everfocus is usually
Admin
Admin
Nevertheless, you should contact your local distributor, and after providing the product serial number, they can generate a reset user and password, that shall be used only once, and then, you must enter a new user/password combo.
Nov 16, 2012 | EverFocus ECOR264-9X1/2T ECOR264 Series 9...
I try to connect to my everfocus ddns cameras from my mac, but i only see a black page with the login, an still cant login. Do I have to download something to be able to see my cameras?
Everfocus remote viewing requres ActiveX, therefore it only works on MS Internet Explorer. You can log in to mobile view from your Mac, which will give a lower quality image by adding /m/live.htm at the end of ddns address, but this is only live view, no playback.
http://www.everfocus.com/downloads/Mobile%20Device%20Live%20Viewing%20Instructions%20Rev%201.pdf
Dec 18, 2010 | Computers & Internet
When I turn on my d90 all I can see is the ISO setting...help
restart you unit. it probably hanged.. . if the unit wont let you restart your cam, then pull off the battery and put it back after couple of seconds
Apr 30, 2010 | Nikon D90 Digital Camera with 18-105mm...
Olympus E520 digital slr. Only auto setting is working? On other settings, live-view goes dark(?).
SLR cameras are meant to be used with the viewfinder, not live view. Live View on SLR's is a luxury that point and shoot users have come to expect, sadly. I suggest you start using the viewfinder and disregard the live view altogether, since it doesn't always give you an accurate representation of what the photo will turn out like, and it consumes battery power at a ridiculous rate.
Jul 07, 2009 | Olympus Stylus 800 / ? 800 Digital Camera
Suddenly started taking photo's in the raw formant
Raw format pictures can be viewed only using fileviewer software, the Adobe Photoshop CS software program can already read raw file pictures. To change settings just push menu, look for the settings you want to set up. All digicam are user-friendly. If you cannot activate the menu button then your unit has a problem and needs to be serviced.
Aug 26, 2007 | Umax AstraPix 430 Digital Camera
Home Security Logo
22 people viewed this question
Top EverFocus Home Security Experts
Lawrence Oravetz
Are you an EverFocus Home Security Expert? Answer questions, earn points and help others
