Question about Epson TX700W Series
Epson tx700 unable to connect to pc via usb cable
The printer test for printing works ok
    Top Expert:
  • Epson Master
  • 11,573 Answers
Set up Epson XP-710 for non Wi-Fi use
you need to buy a USB-cable and connect the printer with it to the PC - see picture
- then download a driver at the link below:
http://www.epson.co.uk/gb/en/viewcon/corporatesite/products/mainunits/support/12463
Expression Premium XP 710 set-up-epson-xp-710-non-wi-fi-use-cetraao0zsf5cxvgwz0wg4tf-1-0.jpg
Dec 03, 2014 | Epson Office Equipment & Supplies
Epson UB-U03II not working
I had huge issues with my TM-U220. It does not play well with a Centronix-to-USB cable or with Windows 64-bit. I played for AGES to try and get it all to work.
I installed the USB device driver[1] I was able to print the Test Page proving that the connection between Windows and the printer sort of worked, but when I tried printing anything from Unicenta POS, it always failed.
I finally bought a new Centronix-to-USB and a new parallel port card, used Windows 32-bit, and problem solved.
They key is to uninstall everything, including searching through the Registry to delete everything.
[1] https://pos.epson.com/developers/techresdetails.htm?ProductPK=545
May 30, 2014 | Epson TM-U220 Matrix Printer
Cannot print from command prompt - Epson U220D Windows 7 32-bit New parallel port with driver New centronix to parallel cable Epson driver APD_455dE (I was using Windows 7 64 bit with a...
The Epson works fairly well with XP. It is to be connected to
a parallel port, usually LPT1
using an IEEE certified parallel printer cable. The computer BIOS
setting is best set for standard parallel port, SPP, bi-directional port
or similar. If possible, do not set it to ECP or EPP or ECP & EPP.
The only native driver for the printer is on the Windows CP CD. Install
using the Add Printer wizard.
The Epson LQ-860 drivers, and a few others, can be used. Using these
drivers, you will discover that the printer actually has some resident
fonts (in printer ROM) that are not accessible from the Stylus
driver. However, with this driver, graphics printing quality is
compromised.
Windows 9x drivers _cannot be used_.
Let us know.
Tom
MSMVP
Windows Shell/User
"the_best_of_fools" <thebestoffools@discussions.microsoft.com> wrote in
message news:E7A27E3E-81E7-46CC-B38E-C63AA474A239@microsoft.com...
:I have an Epson stylus color 600 I can't get to work with Windows XP.
This
: printer worked fine with my old Mac.
: I've tried everything I could and nothing is working. The printer is
: connected to
: the computer via parallel LPT1 port. I've installed the WindowsXP
resident
: drivers
: for this printer model (the Epson drivers are too old and not
verified). The
: computer doesn't detect the new hardware with Plug and Play when
turned ON
: (don't know why) so I had to manually Add Hardware (Printer Port) with
the
: Hardware Wizard. I'm not sure how to recognize if the LPT1 port is
active or
: not and set up properly in the BIOS? I read something about having to
set the
: parallel port to ESP or ECP depending on the printer's requirement
(which I
: don't know) in the BIOS?
: Everytime I send a test page or print from a command prompt or WordPad
: nothing happens for 1-2 minutes and then I get a "Printer Out of
Paper"
: message in the pop-up. Of course, the printer has enough paper (and I
can
: print a sefl-test page from the printer). I also tried with another
parallel
: cable and it still doesn't work. I've tried uninstalling/reinstalling
the
: printer's driver many time and it's still not printing.
May 13, 2014 | Epson TM-U220D Matrix Printer
Unable to install Epson TM-U220B[U220 with UB-U02III usb interface] on Windows 7 AND XP!
Hi!
Are you using a third party USB adapter or a USB interface? On the self test page that you printed does it say USB connection or something that will say about USB? or does it say parallel or serial connection? try to check the dip switches setting if its configured properly. visit epsonexperts.com site for more info.
Dec 24, 2011 | Epson TM-U220 Matrix Printer
Epson TM-T90 wont work with USB plug
I have the same problem...Epson does not work with a parallel to usb cable or adapter. If you still want to use this printer you will have to use the parallel port or change the interface on the printer to USB.
Nov 21, 2009 | Epson TM T90 Printer
Printer goes through the motions but text does not print
Let's first test the printer independant of your computer:
Try printing a test page using the instructions here: http://www.ehow.com/how_2006016_perform-test-epson.html. I hope your model printer is listed there. If not, try to find instructions specific to your model in your model's user guide or elsewhere on the internet.
If this works and printing from your computer doesn't, then:
(???Bad print drivers???) Reload the print drivers on your computer.
(???Bad cable???) Try replacing the printer/USB cable that connects this printer to your computer.
(???Bad USB port???) Try using a different port to connect the cable to your computer.
If none of this works you either have a faulty ink cartridge or a more serious issue with the printer. Depending upon the model, unfortunately, it might be cheaper to replace than repair.
May 28, 2009 | Epson Office Equipment & Supplies
New printer, cannot get the wifi or network to recognise
Is it possible that you have limited the number of nodes on the print server and need to reset that number?
Mar 29, 2009 | Epson Office Equipment & Supplies
RX620 wont communicate via powered USB hub.
on a windows system, go to printers and faxes, delete all icons there. unplug the printer, reboot your computer, then as soon as your computer is up, connect the usb cable... now wait.....
after about 5 mins, check printers and faxes if it has an icon for your printer, if it does then print a test page, if it does not show an icon, try another cable, try another usb port or try it on another computer entirely...
Sep 05, 2008 | Epson RX620 All-In-One InkJet Photo...
Unable to print through the print server
First, make sure that you can print with the printer connected directly to your computer using a usb cable.
- Make sure the printer driver is installed and you can print with a direct connection
- Get the print server's IP Address, NetGear should have already provided you with this info.
- If your'e using windows xp, go to control panel > printers and faxes
- Right click on the printer icon and go to properties
- Click on the PORTS tab
- Click on ADD PORT
- Highlight Standard TCP/IP Port then click on New Port
- Click next
- Input the WGPS606 IP Address
- Print a test page...
-hope it works!!
Apr 09, 2008 | Office Equipment & Supplies
Computers & Internet Logo
105 people viewed this question
Top Epson Computers & Internet Experts
teamtech
teamtech
Are you an Epson Computer and Internet Expert? Answer questions, earn points and help others
