Question about Insignia Audio Players & Recorders
Transport mode is on
How do i turn it off
Can I select ferry alarm on my Heritage Softail Classic?
Hi Steve, your security alarm system comes equipped with a transport mode, for more information about your question please visit the websites below. Good luck and have nice day.
How to put Harley Davidson in Transport Mode Set Change Override Transport Harley Security Alarm PIN Code No Key Fob...
Jun 30, 2015 | Harley Davidson Motorcycles
Why do lights flash while on trailer on 2014 street glide
The bike senses movement (like someone is stealing it) and activates the "Smart Security System".
You won't have an actual alarm unless you have the optional alarm installed.
You need to put it in "Transport Mode"
In the transport mode, the Harley-Davidson Smart Security System is armed but the motion detectors are inactive.
The motorcycle can be transported on a trailer without activating the alarm while the starter and ignition remain disabled.
Here's a video how:
http://www.youtube.com/watch?v=tA35I8RWI_s
And written instructions:
With an assigned fob within range, turn the ignition switch to IGNITION.
Before the security system lamp goes out, turn the ignition switch to OFF.
Within three seconds, simultaneously press both the left and the right turn signal switches.
After the turn signals flash once, the system enters the transport mode.
With the fob removed, the motorcycle can be moved without setting off the alarm.
May 18, 2014 | Harley Davidson FLHX Street Glide...
Factory mode
Disabling Transport Mode
1.Place the ignition OFF.
2.Verify the battery is fully charged.
3.Place the ignition ON.
4.NOTE: Steps 4 and 5 must be carried out within 10 seconds.
Press and release the brake pedal 5 times.
5.Press and release the hazard switch 4 times (on, off, on, off).
I'd turn off the vehicle. Remove the key. Then try a restart, should be clear of "Transport Mode."
Here is a YouTube video (on a Focus, that shows the sequence.)
2013 ford focus focus ST out of transport mode
Mar 12, 2014 | Ford Escape Cars & Trucks
2010 Equinox has a mesage "transport mode on" & the battery indicator is on. What is the problem?
This is the mode that vehicles are shipped in so that the batteries dont die....It is easy to correct...All you need to do is turn the key to the on position and keep holding it as forward as possible for over 15 seconds...
A message will come up "Transport Mode Off". The battery light will go off and your clock will operate properly.
Thats the trick and works on 2010 Camaro, Equinox, Traverse, Lacross and other vehicles.
Sep 12, 2010 | 2009 Chevrolet Equinox
This light is on..transport Mode...what does it mean I can't find it in the manual...
"transport mode" means that your vehicle is running on a preset ignition program
similar to "limp mode" to get you into a repair facility instead of: stalling and, needing to be towed. the vehicle will not run at peak performance until repaired.
Jul 17, 2010 | 2009 Chevrolet Equinox
How to put bike into service mode to carry out work.
Hi Lincolnboy, for more information about your question please visit the websites below. Good luck and have nice day.
Apr 23, 2010 | 2005 Harley Davidson FLSTC - FLSTCI...
Transport Mode On message along with flashing battery light on.
Sep 23, 2009 | 2009 Chevrolet Equinox
Toshiba e-studio550 service code CD1, PLEASE help me to fix the problem and if there is any service call to reset it, thanks
CD1 indicates Abnormal drum cleaning brush motor.
U need to perform followings:
(1)Check if the cleaning brush, recovery toner transport auger and recycle toner transport auger are not locked (no extraneous material or toner clod in both the toner transport sections at the cleaner unit and recycle toner unit.
(2) Check if the connector on the LGC board and connector pins are not disconnected.
(3) Replace the cleaning brush drive motor and recycle toner transport motor.
(4) Replace the LGC board.
Mar 09, 2009 | Toshiba E-STUDIO 550 Copier
How that i drive BMW M3 GTR in carrier mod???????? Pleas help!!!
I am assuming that you are shipping or transporting your car.There is a factory transportation mode that can be set by any BMW dealer. After transporting you will need to have the transport mode deleted by a dealer.
Mar 08, 2009 | 2005 BMW M3
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
