Question about Minolta bizhub 350 Black and White Copier
C2557 olve
  • Minolta Master
  • 6,680 Answers
Sir, Mam, When the developer was changed did the tech use a vacuum cleaner if so he may have destroyed the ATDC sensor. Clear counters first EXIT once THEN POWER OFF Master Power Rear left side (DO NOT EXIT ALL the WAY OUT OF SERVICE MODE), dump old developer, install new developer run F8. Do not run copies or prints before running F8 Remove Ethernet cable and FAX line to prevent any printing.
Posted on Dec 30, 2014
Solution for konica minolta 250 malfuncion detected c2557
C2557 for Toner Density Control abnormality in Developer.
Try in this sequence..
1-Check Toner, if Empty, Reset code and install new toner bottle.
2- if not from above, Then replace Developer and Developing Unit.
3-if Not, then check Hopper Unit, Clean Sensor and Solenoid.
Jul 19, 2017 | Konica Minolta Office Equipment & Supplies
What is error c2557
Whatever it is, you need to call a technician to find out.
Mar 14, 2016 | Konica Minolta bizhub Office Equipment &...
How to reset c2557
i put in a brand new developer unit, using the new developer I had just replaced into the old developer unit, reset drum and maintenance counters, ran F8 again. The machine came into ready, ran (1) copy, jamed on fuser entry and C2557 fired again. I then reset the switch in the back (right hand side), reset the switch on the main board, reset drum and maintenance counters, ran F8 again. The machine came into ready, ran (1) copy, jamed on fuser entry and C2557 fired again.
Aug 13, 2014 | Office Equipment & Supplies
Problem with printer code c2557-due to this not able to print any document
Internal power supply need checkup to insure satisfactory power and stability
Jan 24, 2014 | Konica Minolta bizhub C250 All-In-One...
C2557
C2557 ATDC Sensor Failure
• The scanning value of the ATDC Sensor is less
than 7 % while the IU Motor is turning.
• The scanning value of the ATDC Sensor is more than 19 % while the IU Motor is turning.
This is form the service manual, The meaning is developer material or the worst case you should change the entire ATDC sensor.
Jan 23, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Ican't run F8 because of error C2557
Error c2557 means ATDC sensor abnormality.Most probably the developer is very low or weak in such condition.Check the developer.You can also increase ATDC GAIN in technical representative mode in order to get rid of this problem.
Also check the PC life/consumables life in "Counter"---"Special Parts life counter".Check if the life of PC Drum is 100% or near to 100 ten clear its value by pressing "C" button.Clear all counters to zero value.Now restart the machine and run F8.It will run smoothly.If you are replacing new developer then there would be no problem with it.
Jun 02, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
My Minolta Bizhub-200 prntr. has a C2557 error code. How do I clear it?
moz-screenshot.pngmoz-screenshot-1.pngC2557 - Abnormally toner detected black tcr sensor.
Reinstall image unit black
Reinstall toner cartridge
Change Image unit
Change toner carridge.
Jan 09, 2010 | Konica Minolta Bizhub-200 Minolta Printer
My NEC IT 2530 copier machine is coming up with an malfunction detected call for service C2557. I need to get the copier machine working.
C2557= ATDC sensor failure.
Did you run the machine out of toner? Or if you or a service tech recently replaced the developer then you need to perform the F8 adjustment in the service mode. Either way you will need a service technician.
Oct 20, 2009 | Office Equipment & Supplies
Bizhub 350 error code c2557, how can i fix this?
This code happens if you replace drum without replacing developer. Both must be replaced at same time.
Sep 30, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Minolta bizhub 350 Black and White Copier Logo
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
