Question about Cisco Win 16d-tel-100d Black 16 Button Display Speaker Phone Warranty Quantity Avail
16d tel-00d time change
I don't have a "conf" button on telephone
How do I set the timw
From port 01, usually the lowest extension #(Dial Feature 4 on each phone to find Tel 01 which is port 01)
Dial "Feature, 9, #"
Enter hours and minutes on the dial pad
Scroll to the left(*) and right(Conf) to sync properly
Then press "Feature" to write the programming.
Nov 11, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
I need to record something with Dictaphone 3750 - I have no manual and there is just a Tel. Rec button. Help
If you press and hold the 'Conf' button, the machine will record using it's built-in mic (located on the right-hand side of the machine, closer to the front). It is probably recommended to get a microphone that plugs into the machine for better recording quality. Depending on what you're recording, you could get a handheld microphone or a telephone record adapter that plugs into your phone and the back of the 3750 (press and hold 'Tel Rec' to use that).
Aug 08, 2009 | Dictaphone 3740 Desktop Cassette...
Flashing message indicator light is on but there is no message
from operators dss hit mw key then the ext you are trying to clear
May 19, 2009 | NEC 80570 Telephone
Foot pedal won't work with hands free microphone
The 3750 won't let you control the telephone record jack. The only way you can get a mic to work using the Tel Rec jack is by pressing and holding the 'Tel Rec' button for about 1 second. But this isn't compatible with the hands-free operation.
If you're looking to do hands-free recording, it uses the built-in conference mic. Press and hold the 'Conf Rec' button for about a second and it should start recording. This built-in mic is located on the right-hand side of the machine near the front by the headset jack.
If you want to control the machine via a foot control while in Conference Record mode, you'll have to change the 'Foot Control Dictate' setting in the menu. Here's how:
1) Press and hold the 'Erase' & 'Search' buttons for about 5 seconds until the menu appears.
2) Scroll through the options until you get to 'Foot Control Dictate' and set this to 'Yes'.
3) Press 'Stop' to exit the menu.
4) Press the 'Conf Rec' button to enter record mode.
Now you should be able to control the start/stop of the record function via the foot control.
Hope this helps...
Apr 13, 2009 | Dictaphone 3750 Desktop Cassette...
How to change the time
Press Feaure 4, should display Tel 1 or Tel 2, if not, can't change time. Must be admin phone.
Mar 14, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Set Time DTH-16D-1 (BK) TEL
Here's how you adjust the time:
1. Press <TRANSFER>
2. Press <CONF>
3. Press *
4. Press <TRANSFER>
5. Press <CONF>
6. Press #
7. "CAT MODE" displayed on LCD
8. Press <REDIAL or LNR/SPD>
9. "COMMAND" displayed on LCD
10. Press 02
11. Press <RECALL>
12. Press 2
13. Press <RECALL>
14. "02>2>Current Time" displayed on LCD
15. Input correct time using military time (HH MM SS)
16. Press <CONF>
Dec 28, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
CONFERENCE CALLING
CONFERENCE With call in progress, ask party to hold.
Press Transfer, receive interrupted dial tone.
Dial desired number
After call is answered, press Conf. Conf LED lights.
Three-way conference is established.
If one party hangs up, other two remain connected. Conf light goes out.
Dec 03, 2007 | NEC Dterm DTP 16D-1 Corded Phone
Cisco Win 16d-tel-100d Black 16 Button Display Speaker Phone Warranty Quantity Avail Logo
Top Cisco Audio Players & Recorders Experts
Prashant M
Prashant M
ray gallant
Steve K
Are you a Cisco Audio Player and Recorder Expert? Answer questions, earn points and help others
